Question about Nikon COOLPIX L20 Digital Camera
I can turn the camera on then when I try to take a picture it says "Objektivstorung" with a red exclamation point at the bottom of the screen and none of the inside buttons work and the screen is blury
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedure in this tip.
Posted on Jun 03, 2012
3 Suggested Answers
virtualhost
  • 2185 Answers
SOURCE: everytime my boyfriend tries to
If this happens only if you are trying to take videos, then you might be having memory issues. Do you have a memory card inserted on the camera? If there is none, then the camera is using its internal memory which is only 45MB; this is too small if you have stored a lot of pictures on the camera already, thus it runs out of memory easily.
However, if you are using a memory card, try to free up some memory on it since recording videos requires a lot of space and when the camera detected that problem, it automatically shuts itself off. If this does not solve the problem, try to format your SD card using your camera. Just be advised that doing this would delete all stored pictures or videos on the memory so make sure you copy them first on your computer.
To format your memory card,
Tap MENU, then select the "wrench" symbol or the Setup Menu. Then select Format Card. You will be asked to Format the card so just click Yes. Wait for the process to finish and then try taking videos again.
Please let me know how this goes. Thank you for using FixYa.
Posted on Nov 13, 2010
  • 11967 Answers
SOURCE: when turning coolpix on it starts to open normally
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 17, 2011
Nikon coolpix troubleshooting
I think and it sounds like a hardware failure of the screen, have it serviced.
Nov 22, 2013 | Cameras
There is a red exclamation point on the camera screen that won't go away. What is the problem?
Just got one of these cameras from a charity shop and after only a short use same problem.
Try connecting camera to PC as an external drive and delete (all) files..... This, too, may not work, in which case reformat the whole drive representing the camera - quick format will probably do.
Once you take a photo the directory path: DCIM/100IMAGE will be recreated.
I'd recommend reformatting quite regularly - after each time you download the photos off the camera.
Apr 04, 2013 | Lego Digital Camera.
When taking a picture a message pops up that says "cannot be written to SD card"
Checks to make:-
1) Is there an SD card in your camera?
2) Is the SD card compatible with your camera?
3) Is the SD card write protected (Check notch top left hand corner of card)
4) Is the SD card full or nearly full?
5) Are you trying to write a file type (.raw) which is bigger than the capacity of the card or the remaining capacity on the card.
Nov 01, 2011 | GE X500 Digital Camera
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
Oct 14, 2011 | Dell 1710 Laser Printer
I bought a new sandisk for my camera yesterday (4gb), took pictures of my party and now I want to load the pictures to my iPhoto program but I get a flashing yellow "!" (exclamation point) when I...
Hi it looks like your card reader do not read this type of card. Try use different card reader or connect your camera using cable. Let me know if it help. Regards Please rate it.
Feb 27, 2011 | Office Equipment & Supplies
I just powered on my Droid 2, but it isn't loading correctly. It has been on for over half an hour, but the screen is still showing just the droid "red eye" thingy. What do I do?
Sounds like its bricked. You can try to do a factory reset. 1. Turn Droid 2 Off by pulling battery.
2. Press 'X' on the physical keyboard and then Press and HOLD Power button until the Exclamation Point/Android picture shows(after motorola symbol).
3. To access menu options Press the "Search" button depicted by the Magnifying glass on the Keyboard and the menu items will show up.
4. Use the Volume Down key and select the "wipe data/factory reset "option with the Camera button all on side.
5. After thats finished, reboot the phone
Feb 18, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I downloading my pictures to my pc. I went back to view them on camera and now some photos says picture error. it is a black screen and an orange exclamation point. please advise
once you have moved all the pictures to your computer make sure to disconnect your camera. no need to keep going back and forth.
on your camera try turning it off, pulling the battery out for a couple of minutes. insert battery. turn on. wait until it is fully on, navigate to view pictures.
if black screen is still present you might have zapped your camera while connecting and disconnecting the wire to the computer repeatedly.
repair is available http://www.teleplancamerarepair.com/
Aug 04, 2010 | Cameras
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
After every picture I have to turn camera off to take another
the red clock means to things :
time and date are not set or the battery that keesp the time and date is drained and needs to be replaced (you can't do that yourself)
Apr 15, 2007 | Nikon Coolpix 7600 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
78 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
