Question about Garden
My murray 10/30 ride on mower with new battery, will not start. I have no manual so need some help.!
    President:
  • 1,545 Answers
You may be able to coax it into running by introducing some areosol type carb/choke cleaner spray into the engine. You can try this. Remove the air filter on the carburetor. Open the throttle all the way. Spray a couple of good shots of the carb spray into the throat of the caburetor. Then immediately attempt a start, choked and all. If it "pops", then we are on the right track and know it is not "spark" related. If it "pops", then do the same thing again. Try it a few times, and if it runs fast for a few seconds, then we know it is probably a fuel delivery problem. By doing this, we are hoping the intake vaccuum actuates the function of the carburetor and it starts drawing fuel from it in a normal manner. If it doesn't pop at all, spark will have to be checked and possibly even the valves adjusted if it has an OHV (overhead valve) engine. Try this and post back. We are here to help and will get your reply.
Posted on May 20, 2011
I am looking for a parts and repair manual for a 2004 model #385016X78A Murray ride on mower.
Murray went out of business and was bought out by new outfit. Do not know if new Murray (kept the name) manufacturer will support the older products produced previously. You can always check and cross your fingers.
Sep 29, 2016 | Murray Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Murray select riding mower model 309000x8NA won't start?
check ground wire and posts for continuity between battery and starter, if you don't have a multimeter, remove, clean and replace all ground connectins. If that isn't it and you are sure that your battery is good and you've got good juice to the starter than the starter needs op-checked, remove it from the engine and engage it, if gear shifts out and spins rapidly you may have engine problem. Hope this helps...
Mar 28, 2010 | Garden
Murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Oct 04, 2009 | Garden
Murray riding mower
You may have to change the magneto.
That's the return circuit which charges the battery.
Jul 26, 2009 | Garden
I Have a Lawn General Riding Tractor, I think it's made my Murray. The drive belt keeps falling off. It is model #42504x71a. Ser. # 7386702081f00626. The belt is not real old. A service center says that...
Hi, service manual and parts can be found on amazon, here:
manual: Amazon com lawn general riding mower manual
parts: Amazon com lawn general riding mower parts
after reading manual you can be able to detect your problem and see if you need new part or just small fix. I hope this helped you. Have a nice day
Jun 04, 2009 | Garden
Murray riding mower Mod. #30575x8a will not start.
Hello:
You can View a Schematic at the Following Site Addy. Select the OEM Briggs and Stratton (Murray Power).
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Garden
Garden Logo
406 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
