Question about Fisher Price Toys
WE BOUGHT A FP VIEW MASTER PROJECTOR FOR OUR GRANDSON AT OUR LOCAL GOODWILL, BUT WE WOULD LIKE TO HAVE INSTRUCTIONS FOR IT. ARE THEY ON LINE? IF SO COULD YOU PLEASE SEND ME THE LINK... THANK YOU: bahleshe@aol.com
  • 3,018 Answers
Regards, Tony
Posted on May 20, 2011
Bought a dimension 4700 at the local goodwill and am having trouble getting it working
It sounds to me like the on-board HDD controllers are dead. Have a look at the motherboard... I'll wager you'll see a fried capacitor right in the middle. Common Dell failure :(
Jul 20, 2014 | Dell Dimension 4700 PC Desktop
Tip
Appreciate your response and while im sure it works, drilling more swiss cheese...
Are you experiencing cross-draining problems with your older Fisher Paykel double dish drawer? Have you had a succession of technicians and service companies try to solve this problem, only to have it return again?
There is a reason this is happening to you and there is a way to fix it FOREVER.
In most cases, this problem can be traced to an improper installation. Fisher Paykel double-dishdrawers are in effect TWO dishwashers with two seperate drain hoses. Often times they are installed with an "air gap" which is required by many municipalities for code compliance. Installers who are used to installing "single" dishwashers often install a "single air gap" with a Y-adapter that connects both drawers to a single air gap, and to be fair, this is shown in the install instructions for the product. However it will usually not work for very long. The reason being, there is a small neoprene "check valve" in the base of the pump on both drawers. It is designed to keep the water from the last drain cycle from running back into the machine once the cycle stops. It was never designed to prevent the cross-drain condition. Over time the pressure from the water that wants to come from the other drawer will weaken that flap, causing it to "leak" and the result is when one drawer is run, the dirty water from one drawer drains partly into the other drawer. (YUCK!) Most techs will replace the flap, thinking they have solved the problem, and for awhile, yes, it will.
But this can get kind of expensive having to call for repairs every year or so.
The proper and permanent fix for this situation if to install a DUAL AIR GAP which can be purchased from Fisher Paykel parts: http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
This device is totally "co-axial" in design and will not allow water from one drawer to get into the other. It also is "kosher" in that some Jewish families have a "meat" and "dairy" dishwasher and the two can never be mixed. If there is cross-draining going on, that is "not Kosher!" (pun yes, reality also!) This part will insure no cross-contamination.
These dual air gaps come with everything you need to replace a single air gap, and fit in the same hole. You can even transfer most decorative style covers that the customer may have on the single air gap (such as Bisque/Brushed Aluminum/Brass etc.) The feedback we have gotten from our own customers after instaling one of these is extremely positive, some going so far as to say it is like they have a new appliance, as it is now cleaning better than ever and there is no longer an objectionable odor coming from the drawer.
This is an excellent and PERMANENT code-compliant solution for cross-draining on older Fisher Paykel Dishdrawers. Try it. You'll like it!
on Jul 19, 2009 | Fisher DD603B / DD603W / DD603H Dishwasher
I just got a Pregex digital safe from goodwill. Batteries are dead and I don't have the master key to unlock it. I found a number where the key goes. It's J044470
Go to the safe manufacturer's website and contact them with the model and the number you quoted. If they aren't around, check with your local locksmith.
May 07, 2014 | Home Security
Dell genesis
try this portable program, you don`t need to install nothing
http://www.gratisprogramas.org/descargar/iobit-driver-booster-pro-v1-1-0-546-portable-ul-bs-clz-fs/
make sure you have installed video driver, and try to change a different resolution for screensaver
Dec 17, 2013 | Microsoft XP Computers & Internet
Where I can find a service manual and maintenance for a projector Elmo FP-C?
I "Googled" the projector name & found service documents for it at: www.photobooksonline.com I hope this helps!! Jim
Feb 18, 2013 | Office Equipment & Supplies
I recently bought a Dell inspiron 5000e from the local Goodwill store and I don't know the username required to use this laptop.Is there a way to unlock or reset the computer profile?
Check with your local Goodwill store. they might have set the password from their store. If not, then since the system is new, you can just reset it back to factory image.
Restart your computer and when you see the Dell logo, keep tapping F8. Select "Repair Your Computer". It will give you options how to recover your system to factory image. Otherwise, if you're required to type the password since you don't knows it, you might end up re-installing the Operating system.
May 21, 2010 | Dell Inspiron 5000 Notebook
I just replaced the lamp, but the projector won't power up. It has 2 solid red lights
To resolve the issue, follow these steps:
1. Turn off the master power switch, disconnect the power cord, and then wait a short time.
2. Reconnect the power cord, and then turn on the master power switch. 3. If the previous steps don’t resolve the issue, the lamp might be at the end of its life. (double check that you get a good one lamp, and that are installed correctly)
4. If your projector still doesn’t turn on, turn off the master power switch, disconnect the power cord, and then contact your local repair shop for Fix the Board on the prjector
Mar 11, 2010 | Mitsubishi HC3000U Multimedia Projector
I want to know how to rewind a film reel or reverse an Elmo FP-A movie projector. I have an old Elmo FP-A movie projector that works fine. I do not have the instruction manual that would explain how to...
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Mar 10, 2009 | Fuji Photography
Missing assembly instructions for Simba SuperPlay Pirate Ship
Hi there, I bought a simba pirate ship today, the 20th of December, in a Lidl shop here in Portugal. It will be a christmas gift but after the gift is opened I can, if you still want, scan the instructions for you(although I am sure your grandsone built the ship without them anyway:) ). Cheers
Rui
Dec 04, 2008 | Simba Toys
Toys Logo
75 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
