Question about Samsung CLX-3160 All-In-One Laser Printer
Black copy usually is too light to read except for an inch on left edge, put in brand new black toner, same problem
    President:
  • 670 Answers
It could be that your imaging unit has a problem with the developer blades. If your printer looks faded like this: black copy usually is too - slamfix_53.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Posted on Jun 03, 2011
Blue appearing all over copies, lines on left edge about an inch long and inch apart, what is causing this
sounds as though your toner has leaked and contaminated the drum. New drum unit required I'm afraid!
Feb 20, 2015 | HP Laserjet Cp2025n Printer
I have a Samsong CLX-3160 FN printer. Not too long after refilling the black toner cartridge, I noticed that the black printing was not an even black. I followed the instructions that you provide for...
the problem okurs when the drum unit is not work 100% this is normal after a number of copys, I had the same problem in first stage I reset the color management to a higher denesity but this worked only temporary, so I renwed the drum unit, now works as new.
Apr 20, 2011 | Samsung Office Equipment & Supplies
We have a Canon PC 400 copier. When making a
Remove the toner/drum cartridge. Carefully rotate the drum, via the end with gear, to check the edges for toner spots like appear on the copies. If located on drum, GENTLY wipe off with a dry cotton ball. Reinstall cartridge. Check to see that spots are gone. If spots reappear, replace with new cartridge (drum most likely damaged)
Sep 11, 2009 | Canon Office Equipment & Supplies
,my copies are almost to light to read, ive only had the printer for a couple of weeks the printer is a lexmark c750 laser
How many pages do you think you've printed?
If this was a brand new printer it might already need new toner. The "starter" toner they give you with a new printer usually doesn't last long.
Jul 03, 2009 | Lexmark C750 Laser Printer
Black lines on every copy
Good morning Jean,
A mark that is three inches apart can either be the drum, which is part of your toner cartridge, or the fixing assembly, which heats the toner and makes it stick to the paper. With both problems you are describing it could be either of these. The easiest way to figure out which it could be would be to replace your toner and see if the problem persists or if the machine is fixed. If you rub you finger on the left side of the page where the problem is does the toner rub off? If this happens then the fixing assy needs to be replaced. It could also be a combination of both problems. If you replace the toner it could fix part of the problem or vice versa.
Hope this helps
Dec 01, 2008 | HP LaserJet 3200m All-In-One Printer
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
Lexmark E320 - new cartridge poor print quality
Have you cleaned the print head surface lately? It is located directly above the top of the toner cartridge which you need to remove to do this right. Now using a dry soft cloth reach inside and find the narrow slot and carefully go back and forth with the cloth (sharp metal edges be careful). If this does not solve the problem next try removing the toner cartridge and clean the metal contacts inside the printer on your bottom left side when looking into the open printer also it would pay to remove the transfer roller on the bottom inside this has two black tabs that release the roller the one on your left (again looking into open printer) should have a metal strip that should be free of toner on both sides this will also cause poor print.
Luck
Mar 13, 2008 | Lexmark E320 Laser Printer
Black Streaks on Edges of Paper
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Nov 17, 2007 | HP LaserJet 4L Printer
Vertical streak near left edge of printouts....only affects black portion of print image
Where best to look will depend a little on the nature of the smudge. If what you're looking at is white, then you might just have a little heap of toner or paper dust on part of the LED array that paints the picture onto the photoconductor drum (look for a narrow unit that stretches full width, adjacent to the drum. Dark marks may, if you're lucky, be down to dirt on charger wires. Both respond well to cleaning with a vacuum and a soft cloth (be very gentle if cleaning the wires). I would be inclined to trust the existing photoconductor unit unless you know it's been abused (e.g. by leaving it lying around in daylight) or the coating on the drum is visibly damaged. A.
Apr 11, 2007 | Ricoh CL3000E Laser Printer
Samsung CLX-3160 All-In-One Laser Printer Logo
44 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
