Question about Palm TX Handheld
Palm keeps retting.
My memory is full and I wish to delete some applications but the palm keep resetting itself and I can't get back to the application site.
  • vknight3 Aug 22, 2008
    my palm t/x keeps trying to power on but does not. I am unable to power off. I have hit the reset button several times but this has no effect.
  • jlee419 May 07, 2009
    Palm keeps resetting, won't stop. I let the battery drain then partially charged, no luck. Help!
I followed the instructions posted by bab2000 in brighthand.com. I pressed the UP scroll button and then press and release the reset button. It took awhile and several tries but it worked. I then hotsynced and voila I am enjoying my palm TX again.
Thanks.
Posted on Aug 17, 2008
Phone keeps showing "C Phone memory full delete
phone memory should always be free... its the ram for your phone... you shoul keep all your files , applications and messages in memorycard ..... if memory in phone is low it will work slowly and you will not be able to open large sized applications in your phone
Oct 11, 2011 | Nokia N73 Cellular Phone
My nokia N79 is getting restarted frequently. kindly help & do the need full. Rgds Vara Prasanna
Mostly phone that keeps on restarting is due to lack of memory requirement that the phone needs. If your phone memory does too many data stored such as messages,video,games & application etc. it will not run smoothly and keeps restarting because it needs a space to generate any operation on your phone.
To get out of this madness, delete some files and stuffs of your so the available phone memory space will be free.If still the problem occur then you need to reset your phone. But before doing this be sure all files of yours are backed up because everything will be erase and then it will be back on original settings.
By doing reset, just type in *#7370# then wait until the phone restarts.
or you can do hard reset by long pressing ( * ) ( 3 ) ( call key ) then power the phone on (continue pressing the 3 keys and wait until the phone restarts.
Good luck....
Jun 24, 2011 | Nokia N79 Cellular Phone
Memory full delete some data or close some application
You need to Format or Reset your mobile.Even you delete some other files or erase everthing,it will keep popping on your screen that message.
this is due to phone memory corruption,this is happening when your phone free space memory is too low and can't be able to operate any functions on your mobile such as sending messages,taken photo or videos etc.and the result,phone is hanging,sluggish or phone is restarting.
To be able to fix this,here is a simple way to make your phone back to normal.
* On your Home screen, just type *#7370#. This process will reset,format your phone and it will go back to original settings.To make sure your file is kept.back up your contacts and other stuff cause all files will be deleted after this method.
hope this solution helps...
Jun 21, 2011 | Nokia N73 Cellular Phone
I have a nokia 6730c, that keeps saying phone memory full, delete some data i cant text or use functions because of this. The phone memory has 2.4mb free i have deleted loads, but it still comes up...
Most garbage comes from bad behaving third party application and it is impossible to tell which data is good and which is bad. You need to make hard reset, it empties all memories (including memory card).
So remove memory card, press *#7370# on the keyboard and hope for the best. Use external charger, so the phone does not run out of power, when it is programming itself.
Then you have brand new phone with 50MB of clean memory
Feb 15, 2011 | Nokia 6730 classic Cell Phone
Palm z22. wont startup without holding the up arrow key and doing a soft reset. Then Task icon wont load and some of the other applications wont load
Try doing a hard reset. Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
Here are the directions:
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
The progress bar On some devices, you may see a Palm or palmOne logo and a progress bar first. Do not release the Power button until the second, circular Palm Powered logo appears. From there follow the on screen directions and then do a HotSync. Best wishes
Oct 25, 2009 | Palm Z22 Handheld
Not texting (Nokia N95)
i had the same problem its easy fixed u just the code i got it from another website typed it in and the phone resets itself , you will have to back up your phone first bcause al your data will be deleted
Apr 20, 2009 | Nokia N95 Cellular Phone
I want to delete all information from my Palm Z22
do a hard reset...press and hold on/of button while simultaneously pushing reset button on back. Keep on/off button held in until Palm Powered screen appears.
Mar 04, 2009 | Palm Z22 Handheld
Keeps saying "Memory full" even though all my messages are deleted
Go to settings, applications, manage applications, click on an app in the list, click on Force Stop, click on Clear Data, you will receive a warning, proceed anyway. Repeat these steps for each app, then reboot the phone. Worked for me.
Jun 15, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Treo 650 keeps shutting itself down
Hi muchlove,
Please backup your palm to memory card using palm backup application or hotsync it to your computer, then you do a zero-reset. Here's the step by step how to zero-reset:
http://tinyurl.com/babb7
If this solve the problem than it caused by software conflict. Please let me know the result.
Nov 02, 2007 | Palm Treo 650 Handheld
Palm tx
Fixed - Hotsync all your stuff to your desktop. Remove any cards, and do a cold boot (press reset while holding down power button)
Then synch everything back again. I'm never buying another palm again.
Sep 24, 2007 | Handspring Visor Deluxe Handheld
Palm TX Handheld Logo
95 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
