Question about Home
Hi my shower has suddenly started running cold what has happened?
  • 1,998 Answers
Depeding on how the water is heated in your house I would be checking the water tank to see if maybe your water heater is working properly Some water heaters run on electric some run on gas if the water heater is not heating your water supply then you would have no hot water If you have any further questions message me back Thanks Rick
Posted on May 20, 2011
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
When i switch on my iflo enigma shower the power indicator goes out and the shower runs cold
You should not be taking an enema shower, especially with cold water.
Jan 06, 2013 | iflo Home
My shower will run on hot water only. When the handle is in the cold position, nothing comes out. I have made sure the water is turned on and still nothing happens. It just started all of a sudden. The...
So sorry but you have actually posted onto the washing machine forum so you might not get another response ;-0(
Try reposting to one which deals with showers.
Having said that it COULD be a similar problem which washers have in that there is a fine filter in each of the inlet ports and your cold one is blocked with limescale. I suspect a plumber is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 30, 2011 | Frigidaire ATF6000ES Front Load Washer
After about a year after installation our mira thermo shower has started to run cold after about half a minute or so. The same thing happenned to a previous cheaper type of shower which is why we replaced...
Your shower valve has an temp equalizer valve in it, you will have to take it apart, clean all the calcium or debris from it. flush out the hot and cold lines with valve dismantled , cover drain to make sure you don't lose any parts. reassemble with Vaseline. good luck.
Mar 14, 2011 | Home
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Cold water suddenly shuts off during shower.
sounds like you may have "air" in the pipes and that bang has slamed the water reg valve shut hard
Mar 27, 2010 | Bosch AquaStar 2400ES-NG
Pressure is high can it be adjusted?
Is this a new install? Is this happening with cold and hot water, or just one? Is it just happening with the shower valve open if it's not a new install. it may be the shower valve bad. These can be replaced easily, Lowes $7-14 depending on brand. The water has to be shut off from coming in to the shower. If it is happening with the water running on either hot/cold, the each one has a valve like the shower knob. These go bad and are replaced the same. These release to much water when the rubber seal breaks down inside the valve. Let us know which way it's happening and maybe able to help more.
Jan 02, 2010 | Delta & Single Handle Shower Faucet
Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
WATER RUNS COLD
ITsounds like you still have air in your lines try bleeding lines out some times it takes a while .or your getting air in lines some where try looking at the boiler at fittings .
Jan 23, 2009 | Home
Home Logo
103 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
