Question about Kitchen Ranges
I have a ya4928 import export meter installed & the yellow s1 light is on, what does this mean?
How to import and export the mails in Gmail?
Import & Export Email In Gmail
Most of the internet users keep two or more accounts for their personal and professional requirements. When user wants to have his emails from one account to another then logical and best option is to move the emails from one account to another. This is called importing or exporting of emails. User can import and export emails as well as contacts too. This article states how to import and export the mails in gmail?
Import Emails
  1. If user wants to import emails from any other account to the Gmail account, then login to the Gmail account first.
  2. Then click on the gear icon drop down arrow.
  3. Then click on Settings.
  4. In the Settings page opened, click on the tab Accounts & Import.
  5. Then look at the link "Import emails and Contacts from : "
  6. A small window will open. Enter the email id of the account from which user wants to import and click on the button Continue.
  7. User will be asked to sign in to the another account. So after reading the terms and conditions, click Continue.
  8. The login page of that account will open.
  9. Login to that account and follow the instructions to import the emails.
Export Emails
Exporting emails means user can have the copy of emails or contacts in the hard drive of his computer or system. User can use Outlook or any email client application for that.
  1. First Add Gmail account to Outlook or any email client application.
  2. Open Gmail account in Outlook.
  3. From the Menu bar above, click on File and the click on Open & Export and then click on Import / Export.
  4. A Wizard will open. Select the option , Export to a File, and click on Next.
  5. Choose the file type as .pst Data File.
  6. User can export the file in excel format or text format or CSV format.
  7. Again , click Next and select the email account user wants to export and also check the folder which need to be export.
  8. Click Next.
  9. Now select the type of the file and the location.
  10. Click on Finish.
  11. User can add additional username and password for the saved data file.
https://www.linkedin.com/company/1-888-388-1436gmail-customer-service-phone-number
May 25, 2017 | The Computers & Internet
How can I re-install but keep current bookmarks
In all Browsers, you can select EXPORT, usually from the FILE pulldown menu. If you export your bookmarks to a place on your hard drive and then copy to a memory stick, you can then IMPORT them when you are done upgrading the OS. Or you can export directly to a USB attached memory stick. In any case, export before you do the upgrade and then bring up the new browser, and import the bookmarks.
Aug 02, 2014 | Mozilla Firefox
Where is the fuel pump relay on a 2008 jeep Liberty
Left side dashboard facing the door. Remove the oblong panel.
The fuse panel diagram is in your owners manual, if you don't have one, go to Jeep.com and download it for free.
Fuse Panel Description
Cavity Fuse Description
  • 1 15 Amp Blue Horn Relay, Power Sunroof Relay, Power Window Relay
  • 2 10 Amp Red Rear Fog Lights (Export Only)
  • 3 20 Amp Yellow Cigar Lighter
  • 4 10 Amp Red Headlight Low Beam Right
  • 5 10 Amp Red Headlight Low Beam Left
  • 6 20 Amp Yellow Body Control Module/Power Door Locks
  • 7 10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
  • 8 Spare
  • 9 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/ Cluster
  • 10 Spare
  • 11 15 Amp Blue Flasher
  • 12 15 Amp Blue Stop Lights
  • 13 10 Amp Red Body Control Module/ CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight Mirror/Light Bar Switch (Renegade Only)
  • 14 10 Amp Red PDC Fuel Pump/AC Clutch, Starter Relay/Engine Controller/Transmission Controller (Diesel Only)
  • 15 Spare
  • 16 20 Amp Yellow Power Outlet (Rear)
  • 17 15 Amp Blue Rear Wiper
Sep 02, 2012 | 2008 Jeep Liberty
Schematic to driver side fuse box
1) 15 Amp Blue Horn Relay, Power Sunroof
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
I have a video of a sailing ship entering harbour. The sound is not very good and I would like to change this to a suitable musical track.
If you have a PC with windows movie maker installed export your footage via USB2 into your video folder on PC then drag & drop or import your video into movie maker.Rip a CD music track in media player & drag & drop or import into movie maker.
turn down volume of original sound & replace with new soundtrack then publish the movie in format of your choice.
If you get stuck read movie makers help folder.
Aug 13, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
Hot to transfer messages from phone memory to memory card in nokia 3110
hi,
do this if you want to transfer message from phone memory to memory card..
1.) Connect the handset to the PC & select Nokia Mode/PC Suite Mode
2.) Open PC Suite (in PC) & select Messages (Communication Centre).
3.) Select the messages you wanted to save in the PC & click on File on the Leftside top of the PC Suite, you will find export/import.
4.) Select Import & the selected messages will be imported.
If you have not installed PC Suite, you can download PC Suite from www.nokia.com/pcsuite
i hope it will help you ,thanks for trusting fixya..
Jun 19, 2010 | Nokia 3110 Cellular Phone
How do I convert Outlook 2003 address book to contacts so can be used in Outlook 2007.
click on file..import /export export everything as a PST file (export to a file option) this file can be used to import everything back into 2007. If you are upgrading to 2007 it should sort itself as it upgrades
Dec 30, 2009 | Microsoft Office Outlook 2003 for PC
How do I import information from one company file into another?
Intuit QuickBooks can export lists, such as customers, vendors, items... Under file choose Export.
Once the lists have been exported, they can be imported into another file.
Feb 26, 2009 | Intuit Computers & Internet
Please help me...!
Outlook Express First, you need to start Windows XP and launch Outlook Express. If you have a dual-boot configuration (Windows XP and Windows Vista) you should export everything to a location that is accessible from both operating systems. If you have Windows XP installed and you plan to erase it and upgrade to Windows Vista, we recommend that you save everything to a back-up disk and import from it later, after you install Windows Vista.
Exporting the Address Book
Go to the File menu, select Export and click on Address Book.
The Address Book Export Tool will be launched. Select the second option - Text File (Comma Separated Values) - and click on the Export button
You will be asked to select the path where you want to export your Address Book. Click on Browse, go to the folder where you want to save your Address Book, type the name of the file in which it will be saved and click the Save button.
The CSV Export window will open. Here you will have to select which contact details you want to export. Select the ones you want or, for more safety, select all the fields and then press the Finish button.
The Address Book has now been exported to the chosen location.
Exporting E-mail Accounts Settings
In Outlook Express, go to the Tools menu and then select Accounts.
A window with all your internet accounts will be opened. Go to the Mail tab and from the list of e-mail accounts select the first you want to export. Click on it and then press Export. You will choose the folder and the file name where your settings will be exported. After that, click on Save.
Repeat this procedure for all the e-mail accounts you want to export to Windows Mail.
Exporting E-mail Messages
Go to Tools and then select Options.
Go to the Maintenance tab and click on the Store Folder button.
A small window will open and you will see the location where Outlook Express stores all your e-mail messages. Copy that location, close Outlook Express, open that location in Windows Explorer and then copy all the content to a different location.
If you have a lot of messages, the process will take quite some time to finish.
Windows Mail
After you have finished the export process, reboot and start or install Windows Vista. When you are ready to import all your e-mail accounts, messages and address book to Windows Mail, go to the Start Menu - All Programs and launch its shortcut.
IMPORTANT: during the importing process we recommend that you run Windows Mail as an administrator. If you do not run it as an administrator the import process might fail.
Importing the Address Book
In Windows Mail, go to the File menu, select Import and then Windows Contacts.
In the Import to Windows Contacts window, select the first option - CSV (Comma Separated Values) - and press the Import button.
Now you have to Browse to the file where you exported the Address Book from Outlook Express and then press Open. When you are done press Next.
In the CSV Import window choose the fields you want to import. If you are not sure which fields to select, select all of them and press the Finish button.
Now the Address Book has been moved from Outlook Express to Windows Mail.
Importing E-mail Accounts Settings
First, go to Tools -> Accounts. In the Internet Accounts window, press the Import button.
Now you have to browse to the location where you exported your e-mail accounts settings and select the file containing those settings.
Repeat this procedure for all your e-mail accounts. All the restored accounts settings will be listed in the Internet Accounts window.
Importing E-mail Messages
Go to the File menu, select Import and then click on Messages.
In the Windows Mail Import window, you need to select the third option - Microsoft Outlook Express 6 - and click on Next.
Select Import mail from an OE6 store directory and press the OK button.
Now you have to browse to the folder where you exported all your e-mail messages, click the Select folder button which takes you to the next screen at which point you then press Next.
Select the message folders you want to import and press Next.
After the import is finished, the wizard will show a Import Complete message. Press the Finish button.
Now all your e-mail messages from Outlook Express will be available in Windows Mail. By default, all your imported messages will be placed in the Imported Folder. You can move them to any other folder using the drag and drop procedure.
Aug 27, 2008 | Computers & Internet
Audiobahn A3200E Yellow light
THER likely means it thinks it's overheating (thermal protection). This is not a common failure.
Sometimes, low voltage can cause strange problems so you need to check the voltage on the B+ and remote terminals. Place the black meter lead on the ground terminal of the amplifier when checking the voltage. The voltage should remain above 11 volts. If it's below 11 volts on either the remote of B+ terminals, you need to trace down the problem. If the voltage remains above 11 volts, the amp probably has an internal fault and will have to be repaired.
Nov 26, 2007 | AudioBahn A2300HCT Car Audio Amplifier
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
