Question about Go Software Inc. PCCharge Pro (100PROL0000) for PC
When i try and open pccharge i get a invaled null and when i hit ok it closes out what can i do to fix it?
    Problem Solver:
  • 19 Answers
Invalid null refers to a database issue with the one of the fields in the database, or that one of the files being loaded when PCCharge starts. I'm guessing that you are probably getting an error 91 before comes up, then an "invalid use of null". Typically this indicative of windows not being up to date. The best solution for this would be to download the latest Microsoft Runtime Library.
This can be found by going to microsoft.com and searching for the phrase 'windows script'.
What this does is updates your system so that the newest components can "talk" to the database and the file that are being loaded when PCCharge runs.
Posted on Jul 16, 2011
Runtime error 94 in pccharge
I just had this same problem, I managed to fix it by starting PCCharge and typed in "SYSTEM" for the user and then clicked the password box and selected "forgot my password" it should prompt you for a security question, and then it let me log on without issue. After 7 years of dealing with PCCharge I can honestly say it is **** and if you have any choice switch to another payment software. If not, best of luck and I hope your experience is better than mine. CHEERS!
Oct 11, 2012 | Go Software Inc. PCCharge Pro...
Hello I use verifone PCCharge, when I turn it on , an error message pops : "Password backup update failed.Shutting down PCCharge payment server"
PCCharge uses Access database, which is stored in .mdb file. Locate this file. Mine was in C:\Program Files\PCCW\PCCW.mdb.
- Back up this file.
- In the same folder where you found the database, there should be a program called VISDATA.exe. Double click on it to start it.
- Go to File > Repair Database, and point it to your database file (pccw.mdb).
- It will ask you if you want to open db, say no.
- Go to File > Compact Database, and point it to your database file.
- It will ask you if you want to compact to 2.0 or 7.0. I was told to use 2.0.
- It will ask you if you want to replace database, say yes.
- For encrypt, choose No.
- For open, say No.
- Close VISDATA.exe
- Try running PC Charge now.
- If it still gives you trouble, and if you don't mind losing all your history, move the pccw.mdb file out of PC Charge folder (C:\Program Files\PCCW\). Keep it somewhere else for backup, just get it out of PC Charge folder. Now, start PC Charge again. A new database will be created.
Mar 16, 2011 | Computers & Internet
I can open the door, but can't close it. This only happens when the sun is on the door. Other time the door close fine. Why?.
What are you talking about? What door? var fctb_tool=null; function FCTB_Init_527e2c659ada4217b29c35d0747f15b1(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_4e5ab115e88d4bde9df6496547427bbb(t) { fctb_tool=t; start(fctb_tool); }
Dec 06, 2010 | Computers & Internet
Can shutting down your computer improperly cause harm to your computer hardware,the installed hardware, or your data on the computer?
It can't really hurt the hardware. By not shutting it down properly, though, you can lose data or damage programs. In order to shut down, all the open files must be closed and this is what the system is designed to do. By just turning off the computer, some files may be left open and not finish writing to the hard drive. This results in lost file clusters and the resulting loss of data. Much can be fixed by running a scandisk, but there's no guarantee. var fctb_tool=null; function FCTB_Init_17db2df8e38d488da43eb7f6457b238e(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_80bb9b0587c1423a8a9869cc1228ee62(t) { fctb_tool=t; start(fctb_tool); }
Nov 14, 2010 | Computers & Internet
When I try to get into Farmville it shows INVALED
This is just a common Facebook error. Clear your cache & browsing cookies and then close your page.
Re-open and it should work fine
May 20, 2010 | Dell Dimension 2400 PC Desktop
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.0.3705; .NET CLR 1.1.4322; Media Center PC 4.0; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET...
This error message is not an issue on your computer. Check the following code:
'length' is null or not an object Line: 1
This is error in coding.
If you want you can reset your internet explorer settings by following the steps below:
1. Go to control panel and open internet options.
2. Click on advance tab on the top.
3. Click on the button says restore defaults or restore advance settings
4. Click on ok.
5. Close internet explorer and try again.
Regards,
Rashish Sharma
Mar 20, 2010 | Microsoft Internet Explorer 8
I get a certificate error when i login in to my gmail account.
Make sure that the time and date on your computer is correct.
  1. Double-click the time in your taskbar to open the Date & Time Properties menu.
  2. From the Date & Time tab, verify that the appropriate month, day, and year are selected.
  3. Click Apply to save any changes you make.
  4. From the Time Zone tab, verify that your time zone is selected. If the time zone in which you are located is not displayed, select your time zone from the drop-down menu.
  5. Verify that the box beside Automatically adjust clock for daylight savings changes is checked.
  6. Click OK.
  7. Close all your browser windows, restart your browser and try logging in again.
if(document.getElementById('kb_ff3') != null) showLayer('kb_ff3'); if(document.getElementById('kb_ff3_win') != null) showLayer('kb_ff3_win'); if(document.getElementById('z_ff3') != null) toggleZippy('z_ff3'); if(document.getElementById('z_ff3_win') != null) toggleZippy('z_ff3_win'); if(document.getElementById('kb_ff') != null) showLayer('kb_ff'); if(document.getElementById('kb_ff_win') != null) showLayer('kb_ff_win'); if(document.getElementById('z_ff') != null) toggleZippy('z_ff'); if(document.getElementById('z_ff_win') != null) toggleZippy('z_ff_win'); if(document.getElementById('kb_win')) showLayer('kb_win'); if(document.getElementById('z_win')) toggleZippy('z_win'); if(document.getElementById('kb_winxp')) showLayer('kb_winxp'); if(document.getElementById('z_winxp')) toggleZippy('z_winxp'); if(document.getElementById('kb_PH')) showLayer('kb_PH'); if(document.getElementById('z_PH')) toggleZippy('z_PH'); if(document.getElementById('kb_non_US')) showLayer('kb_non_US'); if(document.getElementById('z_non_US')) toggleZippy('z_non_US'I hope this helps.
Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated.
Feb 17, 2010 | Google Gmail
HOW TO USE text.formatDouble in java
You can use these calls:
formatDouble(double inVal, int inDecs, int inLeftOfDec)
formatDouble(double inVal, int inDecs, int inLeftOfDec, boolean recursing)
inVal - double number to be formatted
inDecs - minimum significant figures
inLeftOfDec - number of fixed decimals
As far as I remember java, you use it like this:
String s;
s.formatDouble(34.5566, 2, 3);
Oct 07, 2009 | Computers & Internet
Error 3343 when I start PC Charge, how can I fix this?
error 3343 is a database error. Unfortunately, PCCharge is still in the stone-ages of computer technology and they think VB6.0 and MS Access 2.0 are stable and secure ... At any rate. 3343 is simply an unrecognizable database, in this case due to corruption. There is a program in the PCCharge directory called VisData. This will allow you to run a repair and compact the database. To use:
First make a backup of your PCCW.MDB database in your PCCharge directory (C:\Program Files\Active-Charge (PaymentServer); C:\Program
Files\PCCW (PRO)).
Execute VISDATA.exe.
File -> Repair MDB.
Select the PCCW.MDB database from your PCCharge directory.
Select 'No" to open Repaired Database.
File -> Compact MDB ... 2.0 MDB
Again, Select the PCCW.MDB
It will then prompt for what you want the database to be named. Simply select PCCW.MDB again, select 'YES' to replace existing database.
Select 'NO' to encrypt database.
Select 'NO' to Open Compacted database
Exit Visdata and start PCCharge.
It would also be a good idea to go ahead and update to the latest available Scripting Runtime library. This can be found by going to microsoft.com and searching for the phrase 'windows script'. (To my knowledge, 5.7 is the latest version).
Jul 16, 2009 | Go Software Inc. PCCharge Pro...
Open Questions:
Go Software Inc. PCCharge Pro (100PROL0000) for PC Logo
280 people viewed this question
Top Go Software Inc. Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Avishek Samaddar
Avishek Samaddar
Are you a Go Software Inc. Computer and Internet Expert? Answer questions, earn points and help others
