Ummmmm,..........No
1) First check the surge protector the computer is plugged into.
I have had several surge protectors, that just THE receptacle that the computer was plugged into, was bad.
"Hmmm, surge protector power on LED is lit, monitor has power, printer has power, and so does the router?"
Using a table lamp to check with, THAT receptacle was bad, and the others are not.
2) You're sure you have power going to the Power Supply, the next test is to see whether the problem is a $5 Power On switch, or the Power Supply.
Power Supply Fuse? Doubtful, but the holder is accessible from the outside of the Power Supply's case, (Rear), if so.
If you do not readily see one accessible from the outside, you're done.
Why?
Because there are Electrolytic Capacitors inside the Power Supply.
Even after the Power Supply is unplugged from power, these 'Caps' can hold a charge for weeks, months, sometimes over a year.
Stored charge could be released to YOU!
Shock is Bad to FATAL.
[ Radial Aluminum Electrolytic Capacitors, to be more exact,
http://en.wikipedia.org/wiki/Switched-mode_power_supplyhttp://en.wikipedia.org/wiki/File:ATX_power_supply_interior-1000px_transparent.png
In this top view the blue Electrolytic Capacitors marked with the letter B, are used in the Input Stage. These 'caps' are capable of storing Up To 100 Volts!
Can put X's in your eyes.
A tech Properly discharges them before working on the unit.
Most of the time the result is not worth the expense, or labor, in consideration of the easy availability of a Power Supply.
For a non-tech IMHO the only option is to replace.
The Asus P5G41-M LE motherboard uses a 24-pin ATX main power cable,
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41M_LE/
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24The Power On switch is bypassed, to see if the problem is the Power On switch, or Power Supply.
The test does not directly involve the Power On switch.
In the last link above, view the photo all the way to the right.
The Green wire is the Soft Power On wire.
ALL the Black wires are Ground wires.
A jumper wire is used to briefly connect the green Soft Power On wire, to ANY black Ground wire.
The preferred jumper wire is a straightened out paperclip, then bent into a U-shape.
The top of the U is wrapped a few times with black plastic electrical tape. The taped area is for your fingers, and thumb to hold onto.
U-shape turned upside down the 'legs' are used.
They go down into the socket holes, at the Back of the 24-pin ATX main power cable's connector.
The back is where the wires go into the connector.
One leg goes down into the socket hole with the Green wire in it, RIGHT NEXT TO the wire's insulation, and touches a metal terminal at the bottom of the green wire.
At the bottom of every wire going into the main power cable's connector, is a metal terminal. The tips are shown in the center photo.
This is what those female metal connectors look like, not installed,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-USThe right side is the tip you see in the center photo.
The left side is crimped around the insulation of the wire. This is what the leg of the jumper wire must touch.
The other leg of the jumper wire goes down into ANY socket hole, that has a Black wire in it.
Power Supply plugged into power, power cable plugged into motherboard as shown in the right photo, the connection made with the jumper wire is no more than 2 seconds.
The Power On switch is a Momentary Contact Switch.
Power Supply comes on? You have a bad Power On switch,
http://www.directron.com/atxswitch.htmlPower Supply does Not come on you have a bad Power Supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
[Note*
The dangerous voltages are contained inside the case of the Power Supply. The Power Supply is a converter. It converts the AC electricity from your home, or business, into 3 Low DC voltages;
3.3 Volts (DC)
5 Volts (DC)
12 Volts DC.
The Soft Power On circuit uses 5 Volts DC.
In comparison two D cell flashlight batteries store 3 Volts DC ]
