Question about Sony XM-1502SX Car Audio Amplifier
Installed amp and offset light comes on, no sound out of speakers
  • Sony Master
  • 3,018 Answers
  • You have a ground loop somewhere. You need to check where your amp is screwed into at and make sure it is not to the metal on the car itself. Check your Power and Ground wire connections good to. What's happening is your amp is generating unnecessary DC current. Find your loose or shorted connection and this will go away. The majority of the time you have a loose or insufficient ground connection.
Regards, Tony
Posted on May 20, 2011
  • sebring48566 May 20, 2011
    tried the ground, light stays on, no sound, offset light still on, what is offset
  • Iron
    Iron May 20, 2011
    • The offset light is an indicator of a ground loop somewhere. This is from the manufacturer. Here is some more info on it. Says check the ground and power wire. Check the remote wire too and make sure the amp is not screwed into the car frame itself. The amp is either common grounded to the car or your ground, power or remote wire is not fitted properly. This is the only thing that will set off this particular LED with this AMP. You need to check things again. What I have explained is the only thing it could be.
    Tony
Whenever i turn the volume up with the bass up the music cuts out and a light on the amp says offset. How can i make it stop or how can i fix it?
What size woofers are you running and what size is the amp? It sounds like you are overloading the amp.
May 20, 2011 | Car Audio & Video
My off set light is on even after i unhook my rca and speakers how do i fix this
offset light is on when coonected amp, groung is good, wires fine, tried another amp and works fine , what the heck. is the amp no good
Oct 27, 2010 | Sony XM-1502SX Car Audio Amplifier
DC Offsets on output - protection don't allowd to switch on
you don't want to do this( bypass the protection0
that d.c. output will burn the coils in your speakers with out making a sound!! you have a biasing problem
or like you said a d.c. offset problem it is best to work on this problem with out a load on the amp, this will allow you to trace back where the trouble is starting at. caps will cause this sort of problem but leaky transistors can also do this, even diodes.
this will require an experienced trouble-shooter.
Apr 26, 2010 | Audio Players & Recorders
What does the offset light mean on sony xplod amp
THIS IS "DC OFFSET". MOST AMPLIFIER PROTECTION CIRCUITS REACT TO THIS CONDITION BY SHUTTING THE AMPLIFIER DOWN. THIS IS A CONDITION, NORMALLY BROUGHT ON BY SHORTED OUTPUT TRANSISTORS, THAT ARE TRYING TO PASS THE POWER SUPPLY DC CURRENT TO THE SPEAKERS, WHICH IN A MATTER OF SECONDS, WOULD BURN THE VOICE-COILS IN THE SPEAKERS. MOST TIMES THIS WOULD BE CHARACTERIZED AS HOOKING THE SPEAKERS UP AND OBSERVING THEM SIMPLY POKING OUT OR IN CONSTANTLY WHICH CREATES MUCH EXCESS HEAT. THIS IS WHY THE AMPLIFIER WILL SHUT DOWN TO PROTECT THE SPEAKERS. YOU CAN TRY TO DISCONNECT THE SPEAKERS AND THE RCA INPUTS THEN POWER THE AMPLIFIER UP. IF THE DC OFFSET LIGHT STILL ILLUMINATES, THEN YOU WILL HAVE TO HAVE THIS UNIT REPAIRED. ONCE REPAIRED, BEFORE REINSTALLING IT, MAKE SURE TO CHECK YOUR SPEAKERS FOR DAMAGED VOICE-COILS, WHICH COULD HAVE BEEN THE PRIMARY CAUSE OF FAILURE. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Jan 10, 2010 | Sony Car Audio & Video
Technics SU-G75
I had the same problem. The solution to me was presoldering transistor Q708. http://www.flickr.com/photos/37147023@N03/3511227679/?edited=1
Feb 05, 2009 | Technics SUV500 2-Channel Amplifier
Sony car stereo
When the amplifier shows an offset fault, it's generally because there is DC voltage present on the speaker terminals. The amp has shut down to protect the speakers.
Aug 14, 2008 | Sony XM-754HX Car Audio Amplifier
Orion 12000
the speaker out let on back of speaker box went bad and burnt the circuits in the amp
Mar 15, 2008 | Car Audio & Video
Need a lil ore help!!!
If the overcurrent of DC offset lights are not green, the amplifier probably has blown output transistors.
To eliminate other problems, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally (all lights green), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 05, 2008 | Sony XM-2150GSX Car Audio Amplifier
No Sound/ lights flashing on Amp
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Jul 09, 2007 | Sony XM-752EQX Car Audio Amplifier
Sony XM-1502SX Car Audio Amplifier Logo
163 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
