Question about Bosch WTZ11310UC NA AXXIS Stacking Kit for WTE86300UC and WTV76100 WTZ11310
I have a bosch dryer which disarmed the wire circuits are up. could you send me a map to fix it please? thanks
    Sergeant:
  • 419 Answers
What is problem ???????????????
Posted on Feb 15, 2015
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
The dryer isn't getting hot. I know there's a
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTL5410 condensation dryer does not heat up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 03, 2009 | Bosch Axxis WTL 5410 Electric Dryer
My dryer will not tumble nor will it heat, we have replaced the thermador sensor but will not run. lights flash and can hear a clicking noise, sounds like a relay of somekind going on and off. Any...
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Nov 20, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Enquiry
Dear Abdelmotaal, Please give me the Brouchure of Washing Machine (Ariston AF552T) Function also.
Thanks
m_hashir@hotmail.com
Aug 31, 2008 | Bosch Classixx WVF 2402 Front Load...
Ge dryer not heating
Heating element
Thermal fuse
Wiring
Aug 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Bosch WTL6300 condenser dryer
From experience, it will quite probably be a fault with the PCB controlling electronics. Worth checking all wiring is in place as machines do vibrate and can cause wiring problems.
Aug 10, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Connection of new circuit board to creda tumbe dryer TVR2
Nee
d more info. Need dryer brand, model and serial numbers.
Nov 09, 2007 | Dryers
Dryer will not turn on
If some parts of the dryer works and others don't, then a connection wire is either loose or damaged. You can look up the model of your dryer online and find a wiring guide. Then open up the dryer by taking the front (depending on model) and look for a loose wire or any damage. If the dryer has never worked before, then you may need to rewire the plug, for example, in some older houses the wiring is not grounded and the ground wire needs to be connected with the neutral in order to complete the circuit.
Nov 07, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch WTZ11310UC NA AXXIS Stacking Kit for WTE86300UC and WTV76100 WTZ11310 Logo
138 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
