Question about Cub Cadet Lawn Mower PTO Clutch Replaces CUB CADET 7173384
When pto is engaged it makes clicking noise - Cub Cadet Lawn Mower PTO Clutch Replaces CUB CADET 7173384
2 Suggested Answers
bcharais
  • 278 Answers
SOURCE: I have a 7264 when i engage the pto it makes lots of noise I had some one work on it replace all the gears and still makes noise ant answers
May be some of the bearings on the deck, or belts are too old/dried out and slipping/squealing.
Posted on Dec 17, 2012
John Deere eztrak mower went over a rock today and now the mower won't engage
hmm strange are the belts driving the blades ok if so then the PTO could be damaged but if there's no sign of damage it maybe a bit frozen up/locked up have the engien off but turn the key on and engage the PTO switch and manually turn the PTO (not by the blades please....dont want to have your hand taken off) turn by the PTO itself and if you hear any clicking sound disengage the PTO and engage a few times to ensure your hearing the clicking sound of the PTO turning on and off and it should be back to normal also check any connections going to the PTO before doing the manual work of repairing the PTO
Apr 22, 2017 | John Deere Garden
Any adjustment for hino dutro tipper pto.
When engaging the pto it is important that you have the clutch disengaged so that the pto gear is not spinning in the box.before it engages.
The pto gear runs off the counter shaft of the gear box and is spinning all the time the engine is running
when engaging the pto ,you are physically engaging a gear ( like selecting 1st gear) so you have to stop the counter shaft spinning so that the pto gear will engage with slashing
Jun 14, 2015 | Garden
THE BLADE DOES NOT ENGAGE WHEN I PULL OUT THE KNOB THAT IS SUPPOSE TO ENGAGE THE MOWER BLADE
"I have an Electric Clutch and my Blades will not engage when I operate the PTO switch."
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Is the deck belt intact?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared?
  • When you pull the PTO switch does the clutch make a "click"?
When you sit in the seat and turn the key, one click from off to run, you will hear a faint click. That faint click is the fuel shut off valve under the carburetor. It is turning on and off when you cycle the key from off to run. Do not confuse this click with the clutch click.
Leave the Key in the Run position, cycle your PTO Switch on and off. You will hear a click. This click will be twice as loud as the fuel switch click. This louder click is the Clutch engaging. If you do not hear this click, the PTO switch may be bad or the Clutch may be bad. This is assuming your battery is good and fully charged and that your Key Switch is functioning correctly.
PTO Clutch will Not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
  • It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 17, 2015 | Allis Chalmers AC130 46" 23HP All Wheel...
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
PTO clutch making a loud clicking noise.
I really need some more info from you...but here are a few things you should check? Since it clicks with or without the belt...it has to be an electrical issue! Check the switch, look for broken wiring, or loose connections. Another thing it might cause this is the battery or the charging system! If there is not enough voltage to hold the clutch engaged or what it is getting is shorting out then that would be your culprit! I hope this helps! "Be Easy!" Neighborsboy
May 04, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Pto will not engage
if something was stopping the blades the belt would make all kinds of noise if your hearing the relay click with a test light or volt meter check for power to the electric clutch if not check the safety switches start with the one under the seat
Apr 22, 2012 | Garden
Why won't my pto engage?
They are normally electro magnetic clutches, the click is the cluch engaging so i would guess it is working, arev you sure the belt is not broken or lose?
Feb 12, 2012 | Garden
Engine stopped while mowing...tried to restart...nothing.
I am having the same problem. The PTO in engaged and won't relase. The engine won't turn with PTO engaged, you need to disengage the blades to restart.
Jul 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Cub Cadet Lawn Mower PTO Clutch Replaces CUB CADET 7173384 Logo
66 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
