Question about Arctic Pool & Spa
Arctic spa running all the time, the topside buttons won't shut off the air blower and all 3 motors, it seems to be stuck in clean mode.
    Top Expert:
  • Arctic Master
  • 8,686 Answers
Possible bad control board or stuck relay
Posted on Sep 22, 2017
3 Suggested Answers
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 368 Answers
SOURCE: Spa won't heat unless in spa mode, and if it is in
On the automated valves there are tiny switches on one end or under the valve actuator. When you switch to the spa mode the suction valve should should move to fully block pool drains. The return valve should fully block the pipes to the pool returns and spa fountain. If one or both of these valves is not fully blocking the pipes to the pool then the tiny switch on that valve is in the wrong position or an operator is defective. The middle position of either of these switches turns the operator completely off so it cannot move. That is the position to avoid unless you want to operate it manually. One of the other switch positions caused the valve to move in one direction and the other switch positions causes the valve to move in the other direction. If you set the switches so when in the spa mode water is circulating only in the spa then you have the valves in the right position. Next, place the system into the pool mode. Both valves should move to the other position. If not then the valve operator that doesn't move has a problem. It could be the operator, the wiring, the control panel or a stuck valve in that order. All of this sounds complicated but once you know how the operators should act when you flip those tiny switches and how the valves should act when in the spa and the pool mode then getting the switches set right is simple. I hope this helps.
Posted on Aug 08, 2011
Something seems to be wrong with my pump in my spa.
A loud, grinding, screaming, or screeching pump motor, will not show up on your Pumps Control Panel, with a fault code. Your bearings in the motor, are shot. And you will need to replace them, or the motor.
2nd possible problem - sorry : (
if nothing is displaying on your topside control panel, then your topside Control Panel appears to be bad, or the fuse that operates it has been blown. If there is a display in the readable part of the panel, but you have no access to make anything work, then you have some dead buttons, and once again you have a bad topside control panel.
Apr 11, 2015 | Intex Pool & Spa
Sparform hot tub blower won't turn off
When an appliance will not turn off, no matter what you press on the control panel, you have either a non responding (dead button) topside control panel, or your topside panel did receive the message to turn it off and the circuit board is not responding.
  • If you have some kind of indicator light when you press your Jet/pump button, if the topside panel is operational and does actually receive your request to either turn on or off an appliance, an indicator will appear - either a light or icon.
    • If one does appear when button pressed, then dis-appears when pressed, that means your panel is good - as it is responding to the pressing of the associated button.
      • Bad circuit board
    • If nothing appears when you press the button, no lights or icons - indication of topside receiving your request, then you you have a dead button.
      • Bad Topside Control Panel
May 18, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Dreammaker x-400 clicking sound and pump surge
This might be a problem with the topside control. When the spa is clicking, try unplugging the topside control and see whether or not the problem stops. If the jet button is stuck on the topside, the pump will turn on-off-on-off-on-off until the topside is unplugged.
If unplugging the topside worked, replace it.
Apr 11, 2017 | Pool & Spa
Topside control issues
Topside control is in "Locked" mode.
If you accidentally locked your control
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
or
One of the buttons might be stuck in the down position
If these do not help let us know your control make and model & we'll see what we can do to find out more for you.
Dec 31, 2011 | Dream Maker Spas Pool & Spa
Pool & Spa Logo
716 people viewed this question
Top Arctic Pool & Spa Experts
Mike Raino
Level 1 Expert
john h
David Spradling
David Spradling
Are you an Arctic Pool and Spa Expert? Answer questions, earn points and help others
