Question about Sebo Air Belt K2 Bagged Canister Vacuum
Replace cord on Sebo Komfort K1 - Sebo Air Belt K2 Bagged Canister Vacuum
reddevil6
  • 1673 Answers
SOURCE: sebo airbelt k1
No screws under the castors. There is 3 case clips, the bumper hides them, maybe this picture will help:
Posted on Feb 07, 2008
reddevil6
  • 1673 Answers
SOURCE: Sebo Airbelt K1 Electrical Problem
Remove the belt or seal that goes around it, there are some clips to take out, then it will separate.
Posted on Mar 04, 2008
  • 389 Answers
SOURCE: Will Sebo K1 blow as well as ****?
Sorry, but the answer is - no, it won't!
Posted on Aug 02, 2009
  • 389 Answers
SOURCE: I have a Sebo air belt K1 How do you open the outer casing.
OK, but be warned... it's not so difficult getting the thing apart, but making a neat job of reassembly has been known to drive grown men to despair. And that's because you have to remove the airbelt. But first things first:
1. remove the hose
2. remove the hose-retaining ring
3. remove the flap that covers the green filter.
4. remove the screw beneath that flap nearest to the handle (there's a deeply recessed screw on the other side, but you can ignore that)
5. remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver)
6. this is where it begins to get interesting. The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The first challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else. (The second challenge is getting it back neatly!)
7. remove the ends of the foam strip far enough to reveal two plastic clips that hold top and bottom of the body together
8. prise those clips off with a screwdriver.
9. it should now be possible to lift the top cover off. It can be a bit fiddly getting it off over the neck where the hose plugs in, but it does come off.
10. the cable rewind spool is now revealed in all its glory.
11. if you've found my advice helpful so far, here's a final piece... don't try to fit a new cable to the old spool - fit a complete new spool.
12. good luck!
I value feedback, so please remember to rate this response.
Posted on Jan 13, 2010
Testimonial: "Followed your directions and were fine.I joined a new lead close to the end of the spool by soldering the wires together and covered with tape. Now ok"
  • 389 Answers
SOURCE: taking off the bumper
First, remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver). The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else.
Posted on Apr 10, 2010
How to remove retention clip on sebo x4 to repair electric cable
Check out Espares video on how to repair and replace cable on the SEBO X1. It is the same machine as the X4, only difference is a different motor and cosmetic differences. I rely on this video and a few of the others that this company have done on You Tube for SEBO repairs.
Don't forget to rate, thanks.
May 20, 2015 | Sebo X4 Bagged Upright Vacuum
Changing sebo telescopic slide button, how to
go to :http://www.sebo.co.uk/support/downloads/
download your instruction manual, and proceed according with common sense forchange your parts.
God bless you
Jul 15, 2012 | Vacuums
THE BRUSH ON MY HEAD FOR THE SEBO K1 HAS STOPPED SPINNING WHY???
Check the brush roller at each side to see if threads are wound around it. Also, check the brush to see if there are threads wound around it. This is what generally stops the brushes from spinning. It will take sometime to unwind the threads/lint and you may need scissors and tweezers to fully remove all of them but it will be worth it!
Nov 01, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
How to fix sebo air belt k1 hoover
what is the problem first, I need to know before I can help
Jul 29, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
Taking off the bumper from A Sebo K1 Airbelt
Apr 10, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
Aug 02, 2009 | Vacuums
No power
This is a dead motor. the electrical motor is experiencing windings failure and will have to be replaced or rebuilt. Just to be safe, remove the switch and test with voltage needle to see if the problems here. i suspect total motor failure.
Mar 01, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
Mar 03, 2008 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Sebo airbelt k1
Feb 06, 2008 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Feb 21, 2007 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Sebo Air Belt K2 Bagged Canister Vacuum Logo
64 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
