Question about Zebra LP 2844 Thermal Printer
My zebra prints blanks. Tried resetting the mode. Turned it off. Held the feed button, turned it on, and when it flashed red I let off. It stays green and doesn't flash again. What am I doing wrong?
    Problem Solver:
  • 3 Answers
My work has the same label printer and when installed had the same problem. be sure that your settings are correct. underr the start buttton on the task bar click on "printer and faxes" find the "zebra 2844 " and right click on the bottom of this sub menu click on "properties" there should be two rows of tabs to choose from click on "printer settings" then select "printer default" on all available ie: fonts, spoolong format, line sub. click "apply" then "ok".
Posted on May 20, 2011
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
May 15, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
Blank labels being fed
Re-calibrate the printer by switching the printer off, press and hold the feed button whilst turning the power on. Release the button when the light flashes red. Once calibrated try again, if no joy then try a different driver
Oct 08, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
Just tell me how to reset printer into factory settings. I have tried it by LPT1 connection and commands sent from command prompt, but doesn't help. The problem is that printer after print request...
To reset the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 28, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Tlp 2844 printing first page ok then prints another blank
First thing to try is a reset of the printer.
5) Push feed
David
Jan 03, 2009 | Zebra LP 2844 Thermal Printer
MY UPS PRINTER IS NOT RUNNING ZEBRA: UPSLP2844
Bit of a tough one to know where to start "Printer is not Running"
They usually sit on a bench and do not run anywhere :-)
Is your power supply plugged in?
Is there a green light on the power Supply?
Is the printer turned on?
Does the green feed button cause a label to eject?
If yes to all the above then try a reset
5) Push feed
David
Dec 09, 2008 | Zebra LP 2844 Thermal Printer
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Firmware corrupted? Only prints some random computer text
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Apr 17, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
109 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
