Question about Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XTI Ef-S Lens stuck
The zoom of my EF-S17-85 IS USM lens is stuck in the 17 mm position. I can't turn the lens to change the focal length. It feels like if a lock as in my tele-lens is on, BUT this lens does not have a lock. Any advice is appreciated.
Like to shoot again in Pittsburgh
  • aralani Sep 05, 2008
    I have the same issue--stuck at 17mm with the 17-85mm EFS. Would love some advice!
    Problem Solver:
  • 6 Answers
Hello Pittsburgh! I lived there for 3 years! Dreadful city. :-)
Now, your lens must have a problem with the guide rails/pins. If you dropped it or bumped it, you might have broken/damaged those guide rails. Another reason might be sand/grit in the zoom mechanism.
You may try stripping the lens slowly and see if you can identify the problem. Most lenses are easy to disassemble, you start from the rear mount area, take off screws, and parts one by one, and be organized (i.e., take photos for every step and don't mix the screws).
Good luck.
K.
Posted on Sep 21, 2008
Best telephot zoom lense for my canon 1000d
That's a decision only you can make. What's most important to you? Long focal length? Wide zoom range? Lens speed (maximum aperture)? Weight? Cost?
Also, what do you want to do with the lens? The best zoom lens for taking wedding pictures is not necessarily the best zoom lens for taking sports pictures.
Jan 25, 2011 | Canon 75-300mm f/4-5.6 III USM EF Lens
Item: Canon EF-S 17-85mm 1:4-5.6 IS USM Camera: Canon 20D Problem: At a focal length of below 35mm with the aperture set smaller than f4.0 in any programme mode an Err 99 appears in the view finder,and...
Check this article which will lead you through diagnosing the problem and a possible fix.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Sep 20, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Digital Rebel XT / EOS 350D Digital Camera with EF-S 18-55mm Lens: my rebel xti won't shoot a macro shot. There's pl...
There is a minimal focusing distance for all lenses. If you move closer to the subject than that distance then the camera won't focus on it. Check you lens manual for minimal focusing distance. It is 11 inches for Canon EF-S 18-55mm f/3.5-5.6 USM, for example.
May 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon Zoom Lens EF-S 17-85mm 1:4-5.6 USM: I
I hate to re-invent the wheel (and I don't want to cut 'n paste someone else's hard work to present as my own) so please click here for a likely practical solution which usually works and for Canon's own suggestions on the error 99 fault.
If this has assisted you then please rate my answer; if not then add a comment to provide feedback and I'll attempt to provide an alternative solution.
Mar 01, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
My Canon EFS 17-85 MM is locked at the 17 MM position (although it doesn't have a "locked" feature. What is the problem?
Try taking the lens off AF mode and manually turning it and trying to focus. If that doesn't help then it sound like you have an internal fault.
Jan 11, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
If I buy a Canon EOS 500D body wil my 500n AF lens fit it and operate OK?
All canon EF and EF-S lenses work with 500D /T1i model.(yes all)
If your lens is removed from old 500N body and if it has EF marked it will work for every Digital camera model of canon.
Note: its focal length will be multiplied by 1.6 X factor.
(mean 18 mm lens will become 29mm approx.)
If you find this of help rate me.
Nov 23, 2009 | Canon EOS 500D / Digital Rebel T1i Body...
New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
Jun 10, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Canon xti low lighting
In low light you need a high ISO setting, probably 1600.
You also could do with a lens with a low F number to let in lots of light. You can get a fixed focal length F1.8 cheap but might find the lack of zoom a problem.
A decent zoom with a low F number is going to be expensive.
The EF-S 17-55mm F2.8 IS for instance has a list price of around £800 / $1200 !!
You can get a non-Canon one which would be more affordable and you also won't need the IS at short focal lengths (although it always helps). Have a look at Sigma and Tamron in the F2.8 to F4.0 range but check the online reviews to make sure they are of reasonable quality.
Nov 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Jun 30, 2008 | Canon Cameras
Canon Rebel XT / EOS 350D Digital Camera Logo
525 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
