Question about Buffalo Technology Terastation Live HS-DH2.0TGL/R5 (747464113319) 500 GB Network Storage Server
Help DOA HS-DH0.0TGL/R5 I have a Buffalo HS-DH0.0TGL/R5 that is having some issues. There was a power outage and my Buffalo never came back up. When the unit is plugged in, the fans come on, but no display or hard drive activity. Can anyone help or suggest anyone to repair this unit? I would even be happy with just getting the data off. Please let me know.
SOURCE: my external hard drive is corrupt, i want my data back.
Dear,
Data can be recover but the drive must be accessible by OS. As you write windows vista says drive is not accessible and that the disk structure is corrupted and unreadable.Do one thing try the same drive at another PC. If it run on that PC copy the data to that PC. Now format the drive and paste the same data back to your drive. But, if same thing happend then there are chances of fault in the driveand for this you shuld visit to the service cetre but, they are not responsible for the data.
Thanks & regards,
Rakesh Kumar
Posted on Apr 06, 2009
Crankstart
  • 696 Answers
SOURCE: My DEll PC runnig XP SP3 cannot
Yes the drive is compatible with XP. I have seen a slightly higher than normal # of problems with their 1TB models so this may just be a batch problem. My suggestion if there's nothing crucial on the drive is to return it an purchase a different brand.
If it's not returnable you'll have to settle for asking Buffalo for a replacement. If there's crucial data on it you will need the help of a recovery pro. In that case, comment back with your Country, State and City and I will point you to a nearby Recovery facility.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
greg_margo
  • 1959 Answers
SOURCE: External hard drive not recognized
Some of the externals have mapping issues in Windows.  Although the TB shows in devices, you may need to remap it (right click on My Computer for mapping options) and in some cases, changing the drive letter will fix your problem.  There's really no 1 definitive solution for these.  If you're unable to fix the problem by remapping or changing the drive letter, you can partition the drive to recover your data.  As far as the slow transfer rate goes, almost all externals are formatted in FAT.  This has issues of its own with safely removing devices and slow transfer rates.  I prefer to format my externals and flash drives in NTSF for more reliability.  Best of luck.
Posted on Jul 21, 2009
aberry9036
  • 49 Answers
SOURCE: problem with buffalo 1tb external hard drive
If you're using windows XP then go to start > control panel > administrative tools > computer management > disk management. See if the disk is showing up there but hasn't been allocated a drive letter, if it hasn't then right click on that drive and press "assign drive letter". Be sure to do it to the right one, you could quite easily change another drive's letter by accident otherwise.
Posted on Aug 04, 2009
Crankstart
  • 696 Answers
SOURCE: Hi. My Buffalo 1tb hard drive is not mounting.
Hi Paul,
Sounds like you're running a stripe array which is great for performance but lacks any resiliency at all to this type of shutdown.
If there's no data on the drive which you need you should be able to simply reformat the drive using the buffalo utility that came with it(may require a pc).
If you have data on the drive which you need recovered you will need the help of a data recovery pro and Disk Warrior and other simple data recovery programs simply don't have the capability to recover complex drives.
If this is the case you can submit the drive to www.armor-it.com for a cost effective recovery, or reply back with your location(Country, State and City) if you need a rapid recovery and I can refer you to someone in your area.
Crankstart
Posted on Jan 08, 2010
Bootmgr is missing
if you can get hold of a windows installation disc, you can boot from it and use the repair option.
Sep 21, 2012 | Buffalo Technology BUFFALO WS-6V12TL/R5...
How to install antivirus in Buffalo Tsx40tlr5 Terastation
You have antivirus installed on this NAS system? You will want to look up the product manual for that product and see if it allows antivirus programs to be installed. Some NAS stations come with built in anti virus. You could even contact their support to get a list of "SUPPORTED" anti virus software. At which point, you will have to telnet or console into the data storage system and install the software. You could probably install the files through a CIFS connection but it would be best to contact Buffalo support as they can walk you through the proper steps.
Aug 05, 2012 | Buffalo Technology Buffalo Tsx40tlr5...
Need to open up hs-dsgl to check the hard drive
Slide the side off after removing the screws in the back. The harddrive has 2 cables running into it, one is long with many pins, the other is small and square. The square one is the power, the other is the SATA cable. Remove both and replace the hard drive. Good luck! Please leave me a good rating, thanks! :)
Jul 27, 2011 | Buffalo Technology 250GB USB SATA 2.0 HD...
I need to reset the IP address, subnet, etc, of my TeraStation 1.0TGL/R5, but I cant do with the nav tool on the computer. Is there any way to manually reset it? Thank You
click start run and type in cmd click ok when ms dos prompt up in that type ipconfig /renew then you will see the renewed ip address subnet mask etc
Apr 01, 2011 | Buffalo Technology TeraStation Pro...
New Fan for buffalo terastation ts-1.0tgl/r5
just the fan, with 3 wires, as long as it has the 3 wires then you can adjust the speed... most fans do come with this 3 wires setup now adays
Apr 15, 2009 | Buffalo Technology TeraStation Home...
Buffallo terastation
How can you loose the password? if your that stoopid then i think you shouldnt own TS,or is it you have bought second hand only to find its password encrypted? either way if you cant read then you shouldnt own a TS instead why not see if you can swap for an external HD ;D
Jan 25, 2009 | Buffalo Technology TeraStation Home...
Buffalo Technologies Linkstation Live 500 not working
All sorted - I installed a later version of the firmware & this seemed to fix the problem.
Mar 07, 2008 | Buffalo Technology Computers & Internet
Buffalo Technology Terastation Live HS-DH2.0TGL/R5 (747464113319) 500 GB Network Storage Server Logo
399 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
