Question about Video Game Consoles & Games
I have a file folder in my external hard drive. it is now renamed usbc with some other characters. cannot open the folder anymore.
  • 915 Answers
Try running scandisk to check the drive for errors. If a directory or file has a name containing invalid characters then you cannot access it. This can happen if the file allocation table gets corrupted. Unfortunately there is no easy fix if you need to access any files in the folder. You may need to find some data recovery software if the data is important.
Posted on May 20, 2011
Iomega hard drive won't let me view files on my TV
I have suggestion for you please scan your external hard disk with a good antivirus and then anti malware bytes. Possible your problem will be solved. Thank you so much....
May 06, 2012 | Iomega Select 1TB USB 20 Black External...
Rename toshiba external hard drive
Check to see if there is a file in the root directory called "autorun.inf". If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
If you don't see the new name take effect right away, Safely remove the drive, unplug it and plug it back in. The changes should show up immediately.
Mar 19, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
When renaming sony handycam files .. they don't work.. it says no applicable files available?! .. i have to rename the files like "M2U00348" .. is there a better and a quicker way??
why are you trying to rename these files
why do you have to rename these files
by renaming individual files this might make them incompatible
if you make a folder named M2U00348 then put the files in the folder
hope this helps you
Mar 08, 2012 | Sony Handycam SR68 Red 80GB Hard Disk...
How do you download files from external drive to a hard drive?
Select the file you want to download to the computer hard disk, right click your selection and click on copy. Open the folder you want to download the file to and right click a space in the folder and select pest. The file will be downloaded to the specified folder.
Aug 08, 2010 | HP SimpleSave 1 TB USB 20 Hard Drive
What do I have to do to start copying file to the external hard drive. Looks like I am just getting shortcuts. The file folders have the small black arrow indicating a shortcut
Hi right click on the file you want to put on the ext. hard drive. You will see a option "send to" click that then choose the ext hard drive. This will sent the whole file and not just a shortcut. Thank you for using Fixya.com
Feb 11, 2010 | Computers & Internet
Weird folder/filenames that will not delete There is a folder on my WD 250 GB Passport Flash drive who's properties show it to be using 157 GB of memory. The Read Only attribute was set, unchecked it. I...
Problem: Folders / files in USB flash drive got named with weird strange characters & those folder / files cannot be copied or deleted.
Reason: Virus infected
Solution:
1. Click on "Computer"
2. Right click on the drive that contains USB flash drive
3. Select "properties"
4. Click on "Tools"
5. Click on "Check Now"
6. Check disc options will appear on screen, put a tick mark in the box in front of Automatically fix file system errors
7. Tick mark in the box in front of Scan for & attempt recovery of bad sectors is not necessary.
8. Click on "Start"
9. Upon finishing of this task, screen will show message "Your device disc was successfully scanned" and bla bla. Close it.
10. After this process the undeletable folder in USB flash drive can be deleted by selecting it & deleting it. The contents of affected folders files cannot be recovered.
After lot of struggle I got this solution on my own by the grace of God.
Sure it will work for others too.
Thanks and regards Raju
Nov 25, 2009 | Western Digital Passport 320GB External...
Wd my book hard drive wont transfer some files
I suggest you take a note from the message of which file/files is/are causing the problems and rename them. The whole file path counts toward the length, so if a number of files are under a folder with a long name, they might all be triggering the problem, and renaming the folder with the long name, to a shorter name, could solve many of the individual file problems. Aim for a full path name length of less than 256 characters.
And for files with symbols it can't read, have a careful look at all the characters in the full path name, and re-name any files using unusual characters. Stick to using alphabetic and numeric characters. If you know some files with special characters that you have successfully copied, then those characters would be OK too. I think comma, space, plus sign, minus sign, underscore, parentheses are OK, and there are some others.
Some applications will let you save files with long file names in their working folder, without checking the full path name, then when the operating system comes along and bulk-copies things, it's dealing with the full path name and stalls.
Another possibility I haven't tried, is to go into a folder with long file names, and compress everything into a zip file (give it a short name), then when the bulk-move utility moves it all, it doesn't have to deal directly with the long file names. You can unpack it at the other end. As I said, I haven't tried it, but it might work well for you if you don't want to rename the individual files.
Good luck on the big move.
Aug 04, 2009 | Western Digital My Book Essential Edition...
Western digital my passport 320 file path too deep
The "path" is the full name of a file or a folder, e.g.,
C:\Documents and Settings\User\Local Settings\Temporary Internet Files\Content.IE5
If the path has too many characters, you get the error-message that you reported.
If you can, rename one of the folders, using a shorter name.
Jul 17, 2009 | Western Digital My Book Essential Edition...
Can I drag and drop files to my external hard drive
yes u can just make new folder on hard drive right clik anyware in it then new folder rename it pics or whatever drag in stuff from c drive over k
Oct 15, 2008 | Toshiba Computers & Internet
Hi i need your help with micro SD
Firstly, you need to install FExplorer, a free file manager that allows us to browser through S60 file system.
Next, launch FExplorer and then browser to c:\system folder. There is a file, called mmcstore.
Rename the file to mmcstore.txt and then open it. Your password must be several characters at the end of the file.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Video Game Consoles & Games Logo
457 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
