Question about Toshiba TZ50V51 50" Rear Projection Television
Please Help hello : ) When i turn on the TV the whole picture does not show all the way.The top half shows and bottom half is black. It's like the picture is compressing. Is that the picture tube going out? If so how can i fix it, can't afford to hire a repair man. Thank you : )
Sounds like it's a high voltage problem. The flyback is putting out low voltage. Common problem. Flyback is ready to burn out. Most flybacks are 30 to 100 bucks.
Posted on Oct 08, 2008
  • Toshiba Master
  • 19,396 Answers
The problem is probably a faulty IC (chip) or capacitor on tv main board.
Only simple things you can do at home are hard reset and whacking test.
To do hard reset leave the power cord unplugged for two hours; then power up again. This will drain power from tv and will restore all eproms inside the set to factory defaults.
to do whacking test. Just bang (not too hard) your fist on the top, back, sides, etc., to see if you can restore the picture, this can fix bad connectors etc.
If reset and the whacking doesn't help, then the problem is in some faulty or burnt component on main pcb inside tv. Often the jungle IC chip. The jungle IC handles all the video, color and control signals to the projection tubes. It is quite expensive to replace. In this case you will need a tech to test and diagnose the exact failure so that the right outboard parts are replaced at the same time.
The set should be nearly 10 years of age; so, it should have a few years of life left in it, as average life for a Toshiba is around 15 years . So, if you have to spend $300 to fix it and you get another 5 years of life or so out of it, it may be worth repairing, as the only other option is buying a new TV.
Posted on Aug 15, 2008
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
My screen is black at da top and bottom but its a pic in the middle.its just not showing the whole picture
it sounds like you have a widescreen video on your 4:3 tv. the black bars on top and bottom widen the screen picture.
Nov 05, 2011 | Symphonic ST419E TV
When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
May 10, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Part of Picture is black
chances are your close captioning has been turned on go into cutomer menu setup and see if it on.
Oct 26, 2008 | Sony KP43T75GRAY 43" Rear Projection...
Old tv only shows half picture
it looks like some caps are bad in the set.
Have it serviced by a TV repair shop
Aug 02, 2008 | Televison & Video
Sanyo dp42746 half screen blacking out
http://cgi.ebay.com/philips-plasma-Y-board_W0QQitemZ270262136649QQcmdZViewItem?hash=item270262136649&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Jul 20, 2008 | Sanyo DP42746 42 in. Plasma Television
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Half a picture in black
Witch part of the screen you loose?if is the bottom or the top it could be a problem in the vertical IC circuit if is the left side or the right side is a problem on the horizontal deflection circuit(very rare),try taping on the set when it does it and see if the pix reacts ,if it does one way or the other you have loose conections and some resoldering need to be done.If you are familiar with tv circuitry you will have no problem.If you are not be safe and call for help.
Sep 19, 2006 | Mitsubishi (WB2000)
Toshiba TZ50V51 50" Rear Projection Television Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
