Question about Brother LS-2125 Mechanical Sewing Machine
I have been using my pe150 without problems than sat down today and started a pattern and it will not sew I keep getting upper or lower thread broken, they are okay I have changed the needle also. I don't know what else to try
  • 33 Answers
Sounds like you may have a burr, probably on the bobbin case will be very small can be sanded off, caused when the needle hits the bobbin case could also be on the walking foot
Posted on Sep 04, 2008
SOURCE:
I just got my sewing machine 2 months ago just started to use it icant because it keep breaking the thread ihave a fleeling i have it sat up wrong like the teason als may be t o tight thanks Jan from
***Upper tension setting
*** Put the pressure foot up.
***As you are threading give little tugs to check for snags. Snags must be fixed.
***When finished threading (not the needle) put the pressure foot down.
***Check the tension by starting at zero and increase the tension slowly and give small tugs to see if the tension is rising. (This is all done without the needle being threaded)
***When you feel comfortable this is working then thread the needle and set the tension at four.
***Set the bobbin tension. Attachment gives instructions.
Now that all of the tension has been set you can try for
Sep 30, 2015 | Singer Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Jul 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Lower looper
It is impossible for a looper to come unthreaded if you are holding one end and the other is still feeding off the spool. Somewhere a thread broke - must be either the upper looper or the needle. Try completely re-threading your machine. Many machines have an "order" they prefer to be threaded. Try starting from the right tension guide and work to the left.
Sep 17, 2007 | Janome MyLock 634D Mechanical Sewing...
Designer One "broken thread"
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Feb 05, 2007 | Husqvarna Designer I
Brother LS-2125 Mechanical Sewing Machine Logo
95 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
