Question about Sharp Aquos LC-37D90U Television
THE SET WILL NOT POWER ON. The blue power light blinks every second. I have unplugged the set several times for longer periods each time without change to the problem. The set is a Sharp LC-37D90U. The set always had little mysterious problems that seemed to cure itself since new. One problem was that the set would not turn off and produced a picture as if you were looking through a window screen and a not so clear hazy two tone gray picture. That only happened twice. Otherwise the picture was very sharp.
    Top Expert:
  • Sharp Master
  • 75,235 Answers
You have a shorted printed circuit board.
Posted on May 16, 2017
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
  • 84 Answers
SOURCE: flat screen needed
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv.
My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
  • 5 Answers
SOURCE: Sharp Aquos turns itself off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Posted on Aug 16, 2008
SOURCE: Turns itself off
Sharp LC-13AV4U - turn it on and in ten seconds it turns off.
Happens every time.
Any Ideas?
DO THIS AT YOUR OWN RISK!
This is NOT a fix, this is a permanent band-aid.
All you need is a phillips head and tiny diagonal cutters....
Heck, even a nail clipper would do it.
Just disable that faulty protection shut-down circuit!
Remove all the screws from the back cover
and look at the main board with the
unplugged! power cord towards you.
In the upper right corner of the board, you will find
a tiny red-striped zener diode, labeled as D409.
It is to the right of an electrolytic capacitor marked C403.
Snip this diode, at either end, or snip both ends and discard it.
Re-assemble the TV.....and you just got your tv back!.
I only run mine when I am sitting in front of it,
I never leave it running unattended....just in case!
Don't blame me it yours burns up....but mine is just fine.
The Robot Doctor.
Posted on Dec 13, 2008
  • 8457 Answers
SOURCE: sharp lc-46d64u blinking codes. power blinks 3
Very common in Sharp,tries unplug,replug back in,tries again off/on couple times,still happen blinks than ur main video board it dead.
Posted on Nov 12, 2009
I have the vs 60719
This set was made around 2001 and should have the self check feature. Unplug set and then plug back in and try to turn set on----if green power light comes on for a few seconds and goes off--ON the front of the set press and hold menu and input buttons together for several seconds and then release--------------power light should blink a two digit error code and repeat it several times.
1 blinks, 2 blinks a pause and then repeats(1,2 is no error found.)
Let me know what you find and comment here.
Nov 17, 2011 | Mitsubishi VS-60719 60" Rear Projection...
My sony bravia kdf-50e300 tv will not turn on. the green power light blinks then goes to a red blinking light 5 times. I tried unplugging it numerous times. Some forums suggestn it is the power board....
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 05, 2011 | Sony KDF-50E3000 Television
Red standby button comes on after power comes on. It blinks 13 times, pauses few seconds, then 13 more blinks
May 25, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My standby light is red and blinking 6 times then quits, then blinks 6 times again then quits every time i try to turn on my tv
Apr 06, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
My standby light blinks 7 times ?
Feb 25, 2011 | Sony KV-40XBR700 40" TV
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sharp Aquos LC-37D90U Television Logo
43 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
