Question about Packard Bell Computers & Internet
I cant get my dvd drive to eject, and its not recognising that there is a disc in the drive. I do not have a small hole to stick a pin inside as instructed by others as my pc is a PB OneTwo L5710 and as far as i can see there is no hole as the dvd drive doesnt have a tray, it simply ejects the disc itself. Any help will be appriciated! Thankyou!
  • Packard Bell Master
  • 27,725 Answers
You might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 20, 2011
How do i eject a dvd from dell laptop insigna model windows 7
There should be a small pin-hole on the face of the cd dvd player, shove a paper clip in the hole until it opens the player and ejects the disc.
Dec 29, 2012 | Teac (DW-224E) DVD Drive
Dvd/cd will not eject,,,, what is the solution?????
First , you need to locate the small circle hole on your dvd then
use a pin (make sure that the pin that you're going to use will match going to the small hole located on the dvd )
Second insert pin inside the small hole and once the tip of the pin reaches the end inside the hole pull the pin and then after pulling the pin automatically the dvd drive will eject/open
You don't need to worry because it is 100 percent safe it doesnt matter if its the unit is off or switch on
Jul 31, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
DVD drive will not open
There should be a manual open button on the front of the drive. Look on the face for a small indent of hole. You will need a pin or something small. Stick it in there and gently push it and it should pop the tray out. Let me know if you have any trouble or can't locate it.
Dec 08, 2010 | LG GDR-8164B DVD Drive
Hp pavillion dv9000 dvd drive will not eject cd. The orange light is on and the drive and fan run ci ontinously like its forever trying to load the cd. Please help. I have Norton 360 and it finds no...
Maybe the ejectable part of the dvd is not functioning. Use a pin to eject dvd disc insert the pin to the small hole you can see in the front of dvd drive and push. Now you can get the dvd disc.
Mar 25, 2010 | HP Pavilion dv9000z Notebook
DVD will not eject
To eject a disc.
  1. Use the eject option in the menu bar by selecting open from the drop down menu.
  2. Press the eject or F12 key on the keyboard.
  3. Open the drive face plate and insert the end of a paperclip into the small hole under the drive tray area. This will pop the tray open.
Hope this helps. Don't forget to vote or leave feedback, Thanks.
Feb 23, 2010 | Apple eMac G4 Desktop
My disc drive wont open, i tryed hitting it, prying, and even tearing off the front off my tower! any ideas?
in front of your cd rom disc drive you will see a very small hole, try to insert a small sharp object or pin that will fit in the hole, that is the bypass key to open the disk tray
Nov 14, 2009 | Gateway GT4016 Desktop PC
Cant eject my disc
Dear! It is the fault about belt of a CD/ DVD Rom. You can remove this fault if you can change the belt that is inside the CD/ DVD Rom. And if you want to eject your disk as soon as possible? Use a pin and put inside the very small hole of CD/ DVD Rom and press under your controle slowly. Your disk will open.
Thank you.
Jul 26, 2009 | Sony PlayStation® 3 (80GB) Console
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
May 29, 2009 | Dell Studio XPS 16 Notebook
My dvd cant eject
You need to provide more information.
A CD-ROM/DVD drive only needs power to eject a disc. It does not care if the drivers are installed, for that function, it only needs power.
If this is a new drive it might be a bad one. If this is a drive you have used before, it might have gone bad.
If you have a Disc stuck in the drive, you can always use a paper clip to preform a manual eject. Just unbend a paper clip, and stick it in the pin size hole on the front of the drive. Keep pushing until the drive door opens.
If this is new drive, make sure it is connected correctly.
Nov 10, 2007 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Computers & Internet Logo
287 people viewed this question
Top Packard Bell Computers & Internet Experts
carey w mason
carey w mason
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
