Question about Toshiba Satellite Laptop with Intel Centrino Processor Technology - Flare Carmine
Can only work in safe mode with networking. - Toshiba Satellite Laptop with Intel Centrino Processor Technology - Flare Carmine
  • Twisted-Mind May 20, 2011
    Is this a problem with your internet or will your computer not load to normal Windows?
    If I can give you answer for which ever one you are having problems with.
    Oh, one more thing. What's the Operating system? XP, Vista or Windows 7?
    Thanks,
    Problem Solver:
  • 10 Answers
If its your internet only working on Safe Mode with networking then you can try the following steps.
First, you need to get to the System Configuration panel
If you have XP: Press Start then go to RUN. Type MSCONFIG and press ENTER.
Ifyou have Windows Vista or Win7: Press Start then type MSCONFIG (it should show on the start search box) then press ENTER or left-click on the item that shows on the top left of the menu msconfig
Now when you have the panel up you need to go to the START-UP tab.
To do this you need to go and click the word "Start up" on the top right of the panel right before the "Advanced" tab.
You can now click DISABLE ALL button on the bottom right of panel.
Then you need to RESTART the computer.
This should disable all the programs that would automatically start when you first turn the unit on.
I would strongly suggest that you disconnect the internet connection temporarily to avoid getting any viruses on your computer.
If this would fix the problem then that means one of your programs installed on the unit is not letting you connect to the internet.
You can find out which program it is by going back to the Start-Up tab in the System Configuration panel (MSCONFIG) and then click one program to enable it (it would have a check indicating its enabled) and restart the computer. See if it will connect, up if it doesn't just enable the next program on the list until you get to the program that will cause your computer not to connect.
*Note: There could be one or more programs causing the problem so you may want to continue enabling the programs even if you found one out already.
After all these steps and you found all the programs causing the issue, then you can go ahead and leave them disabled or uninstall them completely (you can call the software manufacturer for assistance).
If its the computer not letting you go to normal Windows then you can just use system restore.
Just click START then go to ALL PROGRAMS and then go to ACCESORIES then go to SYSTEM TOOLS then left-click on SYSTEM RESTORE.
Just click NEXT once then choose a date at least a day before you had the issue. then click NEXT until you get to FINISH.
Make sure the computer does not lose power. Plug it in.
Once it restarts it should restart to normal Windows already.
Posted on May 20, 2011
Laptop toshiba can't find my wireless router realtek rtl8187b wireless 802.11b/g 54mbps usb 2.0 network adapter
Try checking your computer's driver. Right click on Computer. Go to Device Manager. The device drivers are listed in the device manager. Drivers are used to make your computer parts communicate with the operating system. If it has a problem, then the part won't work.
Check for your wireless driver - update it. If no go, then try turning off your wireless adapter in your computer and turn it on. Check = if no go. Try going to safe mode with networking.
To go to safe mode. Do the following:
1. Restart your computer. While it's starting or booting, keep tapping F8 until you see the options to go to safe mode with networking. Use the arrow keys to highlight safe mode with networking.
2. Let your computer start in safe mode. Check if wireless is working fine.
If you want to avoid this kind of problem in the future or if you want to make sure that your computer is running well, then install Radarsync.
Nov 26, 2012 | Realtek Semiconductor Realtek RTL8187B...
Tip
How to make windows installer work in safe mode
Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
To make Windows Installer work under safe mode, you need to create a registry entry for every type of safe mode you are logged in to.
1.Safe Mode.
Type this in a command prompt:
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service"
and then
net start msiserver
This will start the Windows Installer Service.
2.Safe Mode with Network
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MSIServer" /VE /T REG_SZ /F /D "Service"
and followed by
net start msiserver
on Mar 15, 2010 | Computers & Internet
Tip
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
  1. Safe Mode.
and then net start msiserver This will start the Windows Installer Service.
  1. Safe Mode with Network
and followed by net start msiserver This will start the Windows Installer Service.
on Mar 15, 2010 | Microsoft Windows XP Professional
Cannot get on line in safe mode
safe mode is normally used to troubleshoot problems especially software and drivers. where you use this the computer boots up with minimum software running so you can fix problems. I am sure the modem or network drivers are not loaded and ect.
Jul 12, 2011 | Computers & Internet
Websites not getting ( for all browsers) on user desktop. After system restarting, it works fine. Hard to find a solution for this . Ping,Nslookup,tracert all shows normal outputs.
this can be a conflict with your security software or firewall. Restart system in safe mode with networking and see if you have the same issue.
for booting in safe mode with networking. turn off the system.
turn on the system and after 3 seconds start tapping f8 key which is in the top of the keyboar.
you will get option of safe mode with networking and select it using keyboard as the issue system mouse wont work.
Once you are on desktop check with the issue. you can try this by booting multiple times in safe mode with networking.
Mar 22, 2011 | Microsoft Windows XP Professional SP3 Full...
My toshib a-135 does not allow me to go into safe mode when i reboot and hit f8 and choose safe mode it takes me back to the admin log in screen where i have forgotten my password
You may want to try Safe mode with networking. Safe mode with networking works just like your normal mode and you don't have to login as administrator and you can use your normal login credentials if any.
Dec 19, 2010 | Toshiba Satellite A135-S2246 Notebook
How do I get into safe mode on HP mini 1000? XP OS
To get into safe mode on any computer running Windows you press F8 before or right after the Windows splash screen comes up. You will have three options for safe mode:
Safe Mode: Only the absolutely necessary drivers load.
Safe Mode with Networking: Same as above plus the ability to use the internet/network access
Safe Mode with Command Prompt: Boots into safe mode with a Command Prompt for command line work.
Hope this helps.
Jesse
Jan 08, 2010 | HP Computers & Internet
Mine only works on safe mode with networking
System Restore to an earlier date in Safe mode.
Jan 10, 2009 | Acer Aspire 5520-5908 Notebook
When I start my computer it goes to a black screen that tells me my computer did not start successfully and that that I can pick to start my computer in safe mode, safe mode with networking , safe mode...
while you in the booting screen like safemode , safemode with command prompt In that screen press F8 key you goto the other screen like safemode etc., select Enable Vga mode and select the operating system.If it is not work properly then you have reinstall the missing file in the operating system that means you have Repair the operating system.If you dont know how to repair the operating system plese inform to fixya.com
May 13, 2008 | Computers & Internet
Toshiba Satellite Laptop with Intel Centrino Processor Technology - Flare Carmine Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
