Hi there I have an AEG 519 Lavamat. The washing cycle finished and the lights turned off so naturally i tried to open the door to get my washing out. The door is jammed and just won't open. I have tried putting it onto a short cycle and leaving it to finish, but the door still won't open. I've also tried reaching the latch from underneath the machine but can't seem to get anywhere. What do you suggest? I'm sitting here freezing with all my warm winter clothes in the washing machine. :(
  • 1294 Answers
SOURCE: aeg lavamat 538
Your door will not open if there is water still in the machine. Try "spin only". If this fails, get a bucket, remove your outlet tube from the wall drain, put into bucket. Wall plug off first. After all the water is drained try the door, do not force it.
Then check your outlet filter; the water does not go thru for there may be a block in your filter, or tube from the tub to drain area. Or finally in your pump. Dont forget to refix drain pipe in wall in exact position.
And rate me pl.
Posted on Dec 01, 2007
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
  • 174 Answers
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Posted on Jul 24, 2010
Cycle won't start/start light flashing red
Probably a bad wax motor in the door switch or a bad control board.
Yeah you should call someoneif you're not a learned handyman.
Feb 06, 2014 | AEG Washing Machines
Can anyone help me with my washing machine (aeg lavamat 66840 l).After choose a washing cycle and the timer displays 2.20 h , the washing cycle finishes in 1.45 h !?Any ideas?
HI HAVE YOUR PUMP FILTER CHECKED IF OK CHECK HEATING ELEMENT ..SEE IF ITS IN CIRCUIT.. THATS WHAT NORM HAPPENS IF THESE ARE NOT HAPPY.BET OF LUCK.
MARK 07779933829
Nov 22, 2011 | Washing Machines
Hi, i have an AEG Lavamat 1100. Although the machine runs through the spin cycle, and shows the wash cycle as being finished, when i open the door there is still water in the bottom of the machine and the...
Hi bwileman435,
It may not be draining well, because it is dirty, did you clean the Drain Pump filter?
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | AEG Washing Machines
AEG LAVAMAT 75520 door light doesn't switch to green
untitled-rq2y3fnvghvfrpvxa33jafnd-5-1.jpg After turn and choose cycle by program switch, press the Start / Pause button otherwise the program will not start.
If you did everything right then the "Cd" should appear on the display, which means door lock failure.
green = The door can be opened
av = The door can not be opened at the moment
red = Door is open
Dado
Apr 01, 2017 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Nov 12, 2009 | Washing Machines
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG lavamat
For user's manual: Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, & your manual is on line. Wait for at least 3 minutes after the wash is complete, to open the door; do not force the door. The door will not open immediately on the wash being completed.
Dec 25, 2007 | AEG Lavamat W1050 Front Load Washer
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
regards,
Alf
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
Aeg lavamat 538
And rate me pl.
Dec 01, 2007 | Washing Machines
Door not unlocking
open the filter door at bottom turn screw with coin , door should open ,
Oct 02, 2006 | AEG Lavamat Lavalogic 1600 Front Load...
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
