Question about Dell XPS M1730 Laptop Computer PC Notebook
Black screen after going into sleep mode and closing the display
5 Suggested Answers
  • 188 Answers
SOURCE: nb acer aspire 7520G - black screen (no light) on startup - starting from sleep mode
Pull the battery and unplug it.
Plug in the AC adapter and see if it boots.
if it does shut it down and reinsert battery, problem solved.
if that doesnt do it then i would check that your ram is seated properly and try swapped between 2 ram chips in both sockets (if your laptop has 2 sockets.
Hope this helps!
Posted on Jan 10, 2008
Coldcut
  • 1554 Answers
SOURCE: Compaq Presario V2000 Screen went black
As you can see the screen with a flashlight then the lcd and video card and cable are fine,
That leave the inverter and the support cable to it.
if you installed another inverter then the lamps are bad, but you have to be certain the inverter is putting out HV, else the support cable and circuit that turn on the inverter is at fault. it is best to trouble shoot in the bios screen , and be certain that you have the brightness turned up.
Posted on Apr 13, 2008
Geekman
  • 32281 Answers
SOURCE: ACER ASPIRE 5610z BLACK SCREEN
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 19, 2009
  • 1481 Answers
SOURCE: screen goes black after boot
RAM is corrupt...check / change the RAMs
Posted on Jan 16, 2010
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
en.community.dell.com/support-forums/laptop/f/3518/t/19496556
Dell
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from en.community.dell.com
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
I cant enter sleep mode on my acer aspire one zg5. How do i fix?
Your settings in power mode have changed. Open up display and go to the screen saver tab (win 7) you will see the power savings option at the bottom. Go into that and change what the buttons do. You will have 3 situations to change. What happens when i close the lid, power button and sleep mode. Chances are you gave everything set to do nothing
Nov 22, 2015 | Acer Computers & Internet
My monitor is black stand by mode is locked can't see to change the resolution
By default, Windows 7 is configured to go in sleep mode whenever you close the lid on your laptop. While this is generally preferred by most users to preserve the laptop's battery life, it might be useful to disable this process. Many laptops provide the ability to connect an external display. In this case, closing the lid would also prevent any signal going to the external display. If you would like to stop Windows from shutting off your monitor when you close the lid, access the Windows Power Options component and disable this feature.
So try this, t
ake a look at this KB.
http://support.microsoft.com/default.aspx?scid=kb;en-us;977307&sd=rss&spid=14481
Else try .http://www.prevx.com/blog/140/Black-Screen-woes-could-affect-millions-on-Windows--Vista-and-XP.html
for computers originally meant for win XP but after upgrading to Win7, this is a common problem.
May 23, 2012 | Computers & Internet
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
My laptop shows black screen after turn on the system there is no start up display in screen.
Possible faulty backlight. Wait for boot-up and then close the lid or press the power button to put the laptop into sleep/standby mode. Open it up again and see if the screen comes on.
Aug 30, 2011 | Computers & Internet
The screen is going black like its in sleep mode when i open it up
I had the same problem. While rebooting the laptop the screen would be on for a few seconds after it finished rebooting then the display would go black. If you looked very carefully at the screen you could see the image was there but there was no light behind the screen to make the image visible.
I removed the black plastic display bezel cover that goes around the edge of the display screen to check out the lights and wiring. I found a small magnet that belongs inside the display bezel had fallen out of it's slot in the plastic bezel and was stuck to the inverter pcb (printed cicuit board). To fix this problem I secured the magnet into it's slot inside the display bezel with a bit of glue. After fixing the problem and putting the display bezel back together the laptop worked normally.
This magnet is how the laptop knows the lid is closed. When the laptop is closed the magnet is moved closer to a magnetic switch on the inverter pcb and activates the switch. The laptop thinks it is closed and shuts off the lights behind the display screen. When the magnet fell out of it's slot and stuck to the inverter it activated the magnetic switch all the time whether the laptop was open or closed. This caused the laptop to think it was closed and shut off the lights behind the dispaly screen as soon as the reboot finished.
Jul 17, 2011 | Compaq Presario CQ61-310US Laptop
The Laptop can't get to sleep mode
Do a system restore ro a point that you remember it working properly.
Jul 17, 2008 | IBM ThinkPad T41 Notebook
Sleep mode
Does the monitor go to sleep when you unplug the video cable? If so, then the computer is still sending a signal, if not, check the monitor menu settings for no signal settings.
Apr 25, 2008 | ViewSonic VX2435wm (Silver, Black) Monitor
Dell XPS M1730 Laptop Computer   PC Notebook Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
