Question about ASUS P5S800-VM Motherboard
I Have a motherboard p5s800-vm s will not start up board light is on hard drive have gone through and seams in good condition will give one beep on the odd acation and then will start but normaly a blank screen any sugestions please Regards Martin
  • ASUS Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your
hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on May 20, 2011
INSTALLED NEW MOTHERBOARD FROM ASUS A7N8X TO P5S800 NEW BATTERY BIOS SCREEN COMES UP ONE LONG BEEP CONFIGURED TO BOOT FROM HD BUT ALL IT DOES IS GOES BACK TO BIOS SCREEN MAYBE JUMPERS ARE INCORRECT HOW...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 13, 2010 | ASUS P5S800-VM Motherboard
PC Not Displaying anything on Powerup
check the cpu and try other memory modules or if you have more then one try them one at a time. try also reset the motherboard
May 28, 2010 | ASUS P5S800-VM Motherboard
Need driver motherboard asus p5s800-vm
Drivers for your P5S800-VM Motherboard can be downloaded thru manufacturer's Support site:
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us
Just select the correct Operating System you are using and you're good to go.
Hope it helps.
Feb 06, 2010 | ASUS P5S800-VM Motherboard
ASUS P5S8000-VM/S no bios screen no beeps
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
Jul 21, 2009 | ASUS P5S800-VM Motherboard
My computer needs the power button to be toggled several times before my computer will start. I hear a beep and a click (floppy drive)every time. I have just put in a new hard drive, cleaned dust from...
Substitute another power supply and see if that corrects the problem. If it's not the power supply, it's going to be the capacitors on the motherboard. Inspect the caps for any signs of swelling (tops domed). If they show signs, they're toast. They can be replaced if you have the soldering skills and eqipment, or know someone who does.
May 05, 2009 | ASUS P5S800-VM Motherboard
I still got the beeps
Yes it seems to me that ur CPU OR mother board have some defects...
Dec 08, 2008 | ASUS P5S800-VM Motherboard
NO SOUND - MOTHERBOARD ASUS P5S800-VM
According to specs the sound is " SIS964 " go to device driver and check to see if sound drivers installed if they are not it will have yellow mark on them.
Try downloading M/soft UAA drivers first and install them a lot of on board sound require them
then when installed go to drivers again and update sound one will go on net and download and install them
I have had boards that said one type of sound but used another driver to get working
Oct 11, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I have Asus P5S800 main board
dr-afacan, You unfortunatley are not giving me a lot of info to work with. There could be several things to try. First check your cases front panel to Board connections. Then if they are correct I would swap out the power supply with anything compatible to check and see. If that PS is really OK. If you do not have the info for the board go here http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5S800-VM/e1767_p5s800-vm.pdf
Next step would be to either check the processor, possible BIOS settings or update. Or you unfortunatley just have a dead board. Asus has a good customer RMA system... Just some thoughts.....PCdok
Oct 14, 2007 | ASUS P5S800-VM Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
