Question about Vacuums
This was my mother's machine and was a work horse for her. I am making a camouflage quilt for my army son and would like to use the necchi. Unfortunately juice is going to the machine--turning the wheel but the needle is not moving. Any ideas?
  • Vacuums Master
  • 5,370 Answers
Make sure the presser foot is raised and the needle is in the highest position. Move the needle up by twisting the nob on the right side of the machine toward you.
And rotate the nob on the left side until the needle goes all the way down and up again. Always rotate toward you or you could damage the needle.------------ Other possibilities to be checked are :----
Bobbin winder shaft was left in winding position- Move bobbin winder shaft back fully to left.---
Hand wheel out of gear unit loose- check tightness of the hand wheel bobbin winder unit.---
Buttonhole lever was not lowered when machine was placed in buttonhole mode- Lower buttonhole lever.---
Motor belt slipping- reset or replace belt.
Thread lock, threads wrapped around bobbin case- find and remove threads from bobbin case area.---------
This should help.thanks.Helpmech.
Posted on May 20, 2011
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
Hi, I have a silly question. How on earth do I thread my Brother Xr-65 sewing machine?!! I have misplaced the users manual during my recent move. It seems to take thread a little differently than my...
The XR-65 and the XR-65T are the same except that the T indicates the sewing machine was sold with the Quilting Table and some accessories for quilting.
To thread the sewing machine, first lift the presser foot and use the handwheel to raise the needle to its highest position. The thread take up lever should be at its highest point. Place the spool of thread on the horizontal pin secured with the appropriate cap. Make sure that the thread comes off the spool from the bottom front, (Also check that the catch (for holding the thread when not in use) on the spool is at the back of the pin.) Then bring the thread to the thread guide at the back of the machine then down past the reverse lever and back up the the thread take up lever. Wrap the thread around the take up lever so that it slides into the slot and then goes through the hole in the take up lever from right to left. Bring the thread down again and place it behind the guide above the needle. Then thread the needle from front to back.
Brother has the manual available for download: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000061/xr52c65txl64526562ug01enesfr.pdf . See page 31 (43 of the PDF) for the pictures of the upper thread path.
I hope this helps.
Jul 29, 2011 | Vacuums
Where can I order a quilter attachment, seam guide attachment, embroidery attachment, for my necchi heavy duty 3205FA sewing machine?
Hi malonicus121,
Welcome to fixya!
You can order the quilter and seam guide attachments at: http://www.allynint.com/access.htm
Here is their homepage with phone numbers: http://www.allynint.com/
Since they are Necchi importers, I would guess that they could order the embroidery unit for you. Couldn't find an embroidery attachment available for this machine except on ebay. You might want to watch ebay for this.
Also, here is the website for the "SewVac Doctor": http://sewvacdoctor.com/
Not only does he give lots of answers, he does repairs. He probably would know where you could get an embroidery attachment should you have trouble finding one.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 13, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I've lost my user manual for my necchi sub22 sewing machine and can't for the life of me remember how to wind the thread onto a bobbin. Not a big issue, but it's really bugging me, because I...
You could email: spares@aeuk.co.uk and ask for a manual or call (+44)1322 291137 x 2 between 10:00 and 14:30
Or (Thanks to an article 10 months ago from Farmerbear) you could go to allyint.com
They are the sole US importer of the Necchi machines and I believe they stock replacement manuals. Their number is: 1 800 525 9987 ex 20
Jun 30, 2011 | Vacuums
I have a Necchi model 3205 in December 2010 and For no reason the upper tension knob pop off and all the inner springs and the washers like things went accross the floor I would like to know the name off a...
Email or contact these folks and see if they can help you:
Mario Necchi Import & Export Inc.
Fax: (450) 653-6160
Saint-Bruno, Quebec, Canada
E-Mail: necchi@total.net
or
http://www.necchi-importexport.com/contact1.htm
Email for main corporate site: info@necchi.it
Thanks for choosing FixYa,
Kelly
May 17, 2011 | Vacuums
I have Necchi Lydia 544, inheretade, and don't know which way the needle is fixed! what side does the flat part of the needle face? Also, what are the two bobbin holders on behind the main body of the...
Here are some websites with useful information on your machine:
http://www.free-guitar-tablature.com/Lydia.html This one shows how to take the bobbin case out with pictures.
http://www.youtube.com/watch?v=FbEMwLNzsG4 This one is a video to show how to thread it.
Here is a site where you can buy a manual. Couldn't find a free one for you: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/542_544_Lydia_MK2_Instruction_Manual.htm
Here is a site where you can also buy a pdf download document: https://2instructions.com/search.php?cmarque=NECCHI%20LYDIA%20MK2&modele=%20TYPE%20544
And, lastly, I'm including this website which has a lot of information where you can also write in and ask the "doc" questions: http://sewvacdoctor.com/index.asp
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 18, 2011 | Vacuums
Free owners manual for Necchi 575FA sewing machine
Find the Vintage Necchi page on Facebook. Lots of FREE NECCHI MANUALS there. I will have the 575FA manual posted there in less than a week. These other answers are posted by m0r0ns who are sending you to sites that CHARGE. I guess these stoopid jerks don't know what the words FREE MANUAL mean.
If you go to the Necchi-USA website, they will refer you to a website that sells manuals because they don't want to be bothered by the old machines. Keep that in mind if you consider buying a manual from a company that washes their hands of their products when they decide they can't make enough money from selling parts and keeping free manuals for them.
Mar 22, 2011 | Vacuums
I need to download a manual for model 555SU sewing machine, or just tell me how to free sew for quilting. Thank you
The manual is located at this site:
http://www.riccar.com/ftp/whitepapers/7500-Owners-Manual.pdf
Can't help you with the quilting instructions though, but youtube.com has some free motion style quilting videos.
Hope this helps
Jan 30, 2011 | Vacuums
My Necchi supernova ultra mark 2 (50 year old) sewing machine's belt broke (13 inch length). I'm having trouble finding one on-line. Any idea where to get one?
I have the same machine and I see the belt has been replaced. It's a Singer belt. You might wanna try that.
Oct 03, 2010 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
