Question about Garden
Try to start riding mower. it just clicks. I've got 12V to the starter. I thought starter was done so replaced it and no luck> still just clicks. I'd appreciate some help. OHVB 15hp Briggs&Stratton Model 28N707 Type 1118-E1 Code 010329ZE Thanks Gerry
  • 252 Answers
Hi jerry396
you say you replaced the starter - do you mean starter solenoid or starter motor ?
if you run battery jump lead from bat + to s/motor terminal and connect neg jumper lead to engine earth and other end of neg jump lead to negative bat post with key on - will the engine crank over easily and start - if so your starter motor is good if not problem is elsewhere.
check your battery - it could be a faulty battery , and earths, also 12 must be present @ solenoid from the key switch in start mode and check that the solenoid has a good ground
check the starter solenoid as well - it could have burned contacts adding very high resistance to starter cable , also check your starter cable - for resistance - it should have no more than 0.3 or 0.4 ohms
make sure all interlocks are operating - ie clutch brake, cutter attachment , nuetral switch , seat switch ,
cheers hope it helps
pauly46
Posted on May 20, 2011
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
My truck won't start
Click means loose or dirty connection. Use a ohm meter, when turning ignition to starting. Should read atleast 12v Read voltage at big termial on starter. If no or low voltage. Check solenoid, both sides to proper voltage.
Mar 25, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Engine ground wire
A click is a good sign
I'd touch a car jump lead direct from battery +ve to main terminal on starter motor. Just flash on for 2 seconds - It will spark a bit but it should turn the starter motor - regardless of key / solenoid circuitry.
If YES then trace the heavy wiring from batterry to starter via the solenoid and check for tight / non-corroded conections.
If NO then you have a either a faulty/flat battery or a starter motor problem (likely worn brushes - which are cheap to replace)
I doubt you have a ground lead off - because it wouldn't click if that was off!
Dec 30, 2013 | Garden
2006 Freestar. Ran fine last night. Wouldn't start
How many volts does your battery currently have? A cheap multimeter can tell you; I'm not saying the crew at Advance Auto aren't on top of their game, but they do work at Advance Auto... Anything less than 12v DC indicates a problem, and the battery probably won't have enough juice to turn your motor over with less than 10-11v. If your battery voltage is >12v it sounds like you've got a bad starter solenoid (some vehicles integrate these with the starter itself, some do not). Try giving it a few whacks with a rubber mallet or a hammer handle (aka the wooden part).
Nov 17, 2011 | 2006 Ford Freestar
I have a craftsman riding mower,I replaced the battery and the negative cable,but it still won't start.Why?It has a key starter,would it be the starter?
Who told you to replace the battery and cable without troubleshooting first?does it click,try to engage then click,do nothing or what?need more info.if you suspectthe starter,did the person who first looked at it test the starter?letbme know what is up.bart.
Sep 28, 2011 | Craftsman Garden
Mtd riding mower won't start clicking noise
Take some sort of 12V tester and measure voltage on the small terminal on the starter to ground. You should get close to 12 V with key turned. If you see the 12 V, test the incoming large battery terminal. It should also be close to 12V. IF that's ok, check the large terminal on the starter. If you have 12V here, then check for bad ground connection. If any of these are not 12V remove cable and clean connection. How are you sure the battery is ok?
Jul 23, 2010 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Need to replace selenoid in my craftman intekpluss 200 hv
Now just to be clear. You had to make 3 attempts to get the starter to kick in, and now the starter doesn't even try to start? No click or anything?
If that's the case, first make sure that the solenoid is getting 12V when you try to start it. If not, replace the start switch. If it does have voltage, check to see if it is offering 12V to the starter. No? Replace solenoid. Yes? Replace or fix starter.
Note. The solenoid will likely have 3 wires. One is battery power, another is switched power to the starter, and the third is 12V from the start switch that tells the solenoid to turn on and supply the switched voltage to the starter. There is actually also a 4rth connection which is connected either through a 4rth wire or directly to the frame of the tractor to the negative side of the battery.
May 01, 2009 | Craftsman Garden
Garden Logo
151 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
