Question about Saeco Royal Professional Espresso Machine
Our Saeco Royal Professional has been working well but has started ejecting steam out of the steam wand and cappucino spout.
    Sergeant:
  • Saeco Expert
  • 223 Answers
Sounds like your machine needs a new steam valve plastic. Because it is worn the part is allowing steam to come out of the steam wand when it should be closed.
Hope this helps.
Posted on Jun 08, 2011
Cappucino don"t work
Make sure that, Capucinatore is pushed in all the way And cover closed tight OR,S are in place, not crystallized Vinyl tube tight Milk cold and 2% and higher Container level with unit Steam present
Jul 08, 2013 | Saeco Royal Professional Espresso Machine
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
I have a Seaco Royal Professional coffee machine and it is telling me to ventilate, what does this mean and how do I fix this problem?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out. This mean that any steam or air blocked in the water system must get out from steam wand.
Good luck
Jul 26, 2010 | Saeco Royal Professional Espresso Machine
The ventilate notification doesnt disappear on my saeco royal cappucino even i flushed with 4 loads of water
Please release hot water as well as steam by selecting both the selector switches( press hotwater button and open the steam knob).
Still you have the same problem,better you have to consult with service technician( there may be problem with boiler section)
Jul 24, 2010 | Saeco Royal Cappuccino Espresso Machine
I have a saeco Royal Professional and have noticed that although the steamer appears to have sufficient pressure it is taking longer to heat the milk via the wand and that it appears to be steaming up...
Very good description. The problem is very simple. Inside the machine behind the steam wand the secure nut on the pipe coming to the wand is loose and you can tight it back in place very easy. You will need to remove the top plastic cover to see where the steam is leaking.
There is a chance that the pipe or nut is proken but this is very rair.
Good Luck
Mar 27, 2010 | Saeco Royal Professional Espresso Machine
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
I have anew royal professional the milk throther,
Aren't you supposed to foam the milk in a seperate container with the steam wand?
Jul 02, 2009 | Saeco Royal Cappuccino Espresso Machine
Cappucino setting won't pump
Hi
The steam solenoid is stuck. Have you descaled the machine? You might try that first, but if it has gone to long it might not work.
Mar 31, 2009 | Saeco Royal Professional Espresso Machine
Saeco cappuccinatore
also check that the milk is cold. temperature makes a big difference. also try pulling the "pin" on the side up and down to get the milk flowing.
Jun 10, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
221 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
