Question about Garden
What is the fuel to oil ratio? - Garden
  • 3,740 Answers
Since you did not include a model number we don't know what it is you need a fuel to oil ratio for. Speaking in GENERIC terms if you have a new 2 cycle engine in the US the ratio is 50:1 for anything manufactured within the last 5 years. (2.56 oz per gallon)
I like to use this on line calculator for mixture quantities:
http://www.csgnetwork.com/oilfuelcalc.html
Thanks for choosing FixYa,
Kelly
Posted on May 20, 2011
    Problem Solver:
  • 5 Answers
For most mowers it's just straight gasoline, but there are some that vary slightly. Check the manufacturer website to make sure, but again, most (about 90%) mowers take just straight gasoline.
WHATS THE FUEL AND OIL RATIO FOR 25HR 2CYL OUTBOARD MERCURY
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
reference
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
Lost the manual and need to know what the fuel and oil mixture ratio is
Hi Barney:
Fuel oil mix ratio for almost all newer 2 cycle motors is 50:1
Cheers
Apr 16, 2016 | Garden
Fuel ratio on a titan 50?
books say 50.1 ratio is best
use the correct 2 stroke oil as normal engine oil is not the best oil to use.as it dilutes too quickly and doesn't provide proper lubrication to the moving parts
A proper ratio is when you can just seek blue from the exhaust
no smoke is too lean on the oil
Mar 29, 2015 | McCulloch Garden
Fuel/oil mixture
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
From Poulan website:
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas. If you have other brands of equipment that require different fuel/oil ratios and you don't want to mix separate fuel cans, you should use the lowest numerical ratio. For example, if you have products requiring 40:1, 50:1, and 32:1 ratios you should use the 32:1 ratio for all products. This may cause slight smoke increase in the exhaust in the 40:1 and 50:1 products due to more oil in the fuel, but it won't damage either of the engines.
Aug 15, 2011 | Poulan Garden
Fuel ratio for 1968 mercury 9.8 outboard
The fuel ratio is 50/1. Eg.50 gallons of fuel to 1 gallon of oil.
On an older motor and newer cleaner burning oils,you may bring that down to 45/1.Hope this helps
May 28, 2010 | Boating
Need to know the gas:oil ratio for weedeater FL1500
100 ml of 2cycle oil to 4000 ml of fuel..Which is 40/1 ratio
100 ml of 2cycle oil to 5000 ml of fuel.. which is 50/1 ratio
4 o/z is 118.29411875006815 ml to 1 gallon of fuel (3.79 litres or 3790 ml) Which means 32/1 ratio...I find that to confusing,so it is easier to say 100 ml of oil to 3200 ml of fuel ===32/1.
Oct 27, 2009 | Poulan Featherlite Gas Blower, with Low...
What is the proper fuel mixture for a husqvarna chain saw ?
The Correct Fuel Mixture Ratio
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils. I once used an old chainsaw probably from the 1960s, that had a sticker on it that said to use a 25 to 1 fuel/oil ratio, but that would have been using two stroke oils of the time period the chainsaw was manufactured. In that chainsaw I used 50 to 1 ratio with no problems. Today's two stroke oils compared to yesteryears are more efficient at lubricating. It is like comparing today's synthetic motor oil to motor oils of decades ago. All the equipment I use in landscaping, anything from a weed eater, leaf blower, chainsaw, hedge trimmer, use 50 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 liter fuel can and use it in all of the equipment for my customers and for my landscaping. To calculate the ratio is simple. For instance , if you have 1 gallon of fuel it is best to break it down into smaller units, like ounces. One gallon = 128 oz. You then divide this amount by the ratio of the mixture which is 50 to 1 (50 parts fuel, 1 part oil). So therefore 128 oz of divided by 50 = 2.56 oz (you would just measure out 2.5 oz ) of two stroke oil. If using metric, say a 5L gas can, you would break this down to smaller units, which would be milliliters. 5L = 5000 ml. 5000 ml of fuel divided by 50 = 100 ml of two stoke oil.
Jul 25, 2009 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
