I cannot use the remote at all. It lights up but does not function.
  • 53 Answers
Its probably not sending the right signals so take out the batteris and hold down the number 1 for about a minute it should reset it.
Posted on May 20, 2011
Dish Network Remote Codes? Can't seem to get the few I have to work the dish remote
If your remote is a learning remote (has a little black glossy square on the top left side of the remote) you don't need a code, you just need the original remote. Place both remotes on a table, or other flat, sturdy surface, with the original TV remote facing the square on the DISH remote. Make sure both remotes have functioning batteries. On the DISH remote, hold down TV until the button blinks three times, then hold down record (for 5+ seconds) until the TV button lights up and stays on. Then, slowly, for each key you want to use, hit the key on the DISH remote (TV light blinks) then the corresponding key on the original remote (TV light blinks). For example: DISH Volume Up, TV remote Volume Up. When you are done learning all the keys you want to train, hit SAT. The TV light will blink three times, then the SAT light will light up for a moment. Try the DISH remote on your TV functions.
Nov 15, 2013 | Emerson LC320EM8 32 in. LCD TV
The remote transmitter for My Hampton Bay Windward III 54" ceiling fan operates all fan functions properly; however, the lighting functions do not work with my remote. How can I check out problem?
The good news is that the fan functions properly. Now, do the following.
1. Turn off power to fixture at the breaker
2. Remove batteries from remote and press all buttons to eliminate a stuck button as a cause. Reinstall batteries
3. Turn on power and test operation of remote. Be sure to hold dimming button down until lights respond
Jan 29, 2013 | Hampton Bay Dryers
My 5.3ir remote quit working for sattellite and tv functions,how would i go about re-programming it
Michael Jewer,
I can definitely help in programming your remote Michael. I have put below the steps to program a remote to your receiver and TV. This link will provide you with the codes for any equipment you wish to program.
Codes link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
If you require any further assistance let me know here!
Tommy Faust
DISH Network
Oct 31, 2011 | DISH Network IR Remote Control
Have Samsung HP-S4253. Dish remote does not change HDMI imputs but does change others!!!
diggerkeatin,
Some codes programmed into a remote do not give full functionality.
Follow this link:
http://www.dishnetwork.com/SupportSection/remote-setup
You will be able to find various codes for your setup and system. Once you have the codes you can use the steps below to try programming it in.
May 15, 2011 | DISH Network IR Remote Control
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
I have a sharp 52". the remote will adjust the volume but, i can't change the channel. Help? Out of nowhere I could no longer change the channel. The Mrs is getting tired of standing next to the tv so I...
Sometimes, if certain remote control keys are used over and over again the rubber on the bottom of the buttons wears off onto the inside contacts, breaking the electrical connection. This is common on power and channel keys, especially. If you can get the remote opened up, you can clean the contacts with a cloth and it might help. Otherwise, it may be worth buying a universal remote. Good luck! Der Strom
Apr 05, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Universal remote - program digital converter box and Roku?
if you still have your remotes you can program the buttons for each funtion.
1. Hold down P until the red light blinks
twice.
2. Press 9 7 5. The red light blinks twice.
3. Press the device key that corresponds with
the desired device's remote (TV, CBL/SAT,
DVD, VCR or AUD).
4. Press the desired learning key. The red light blinks rapidly.
5. Place the device's remote control head-to-head
(about 2 inches apart) with the
11
Gamer Remote.
6. On the device's remote control, hold down the key to be learned until the red light on the Gamer Remote blinks twice. If the red light does not blink twice, repeat Steps 1- 5.
7. To lock in learned functions on the Gamer Remote, hold down P until the red light blinks twice.
8. To test a learned function, press the learned key on the Gamer Remote and use the function as usual.
Jan 14, 2010 | Radio Shack (15-2147) Remote Control
My remote control stopped working
try with simple test. with any camera (mobile) check for any light (infrared light is not visible, only cameras see the infrared light) in front remote control, while press a key, if a flashing light deteted the remote control is ok, and the problem maybe on remote function is selected, normaly using tv and select VCR or AUX, may occur this problem. or a defective receiver sensor.
Jan 02, 2010 | Televison & Video
My tv remote and sky remote wont change channels, Ive replaced the batteries and still nothing
Get a Video camers or mobile with video function
switch it on and and focus it on the remote IR and press the remote simultanusely and then check of any white light visible on the LCD screen of your camera or mobile
if visible your remote is functioning properly ...
and the problem may be in the TV sectio
if there is no white light visible .....the remote is 100% not functioning
may be your remote IR(infrared LED) needs replasement ........or sometimes best option is to get the new remote for your TV of its brand
Sep 20, 2009 | Hitachi 43FDX01B TV
My viper 2 way pager remote will not arm or disarm the alarm. it still shows a trigger when the door is open though. how do i reset the alarm remote to the vehicle?
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
Aug 18, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
