Question about Samsung Dryers
My Samsung dryer is not collecting enough lint in the filter. When I called the serviceman he came and took the dryer apart and the lint had collected all around the drum. He cleaned it and the dryer worked better for a while but it is doing it again and I assume that it's being collected around the drum again because there is always only a little bit of lint at the very bottom of the filter screen...what would cause this problem?? I hate the cost of a service call to regularly clean around the drum....is there a way I can do this myself? It looked a bit complicated the way he took it apart.
catriver
  • 878 Answers
SOURCE: kenmore gas dryer
kuki, on a gas dryer, if the thermal fuse is blown, it will rotate but will not heat. If your dryer front has a lower panel, the fuse will be in front behind the blower housing. If not, it will be in back just like this pic. Ohm it out or jump it out temp to see if that is the problem. Post back, Catriver
Posted on Aug 31, 2007
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
mek363
  • 18 Answers
SOURCE: The drum is spinning, the heats working, not drying
Try washing both lint screens with soap and water and letting them dry.
Posted on Aug 16, 2009
jsrock516
  • 5911 Answers
SOURCE: Dryer is not drying. Lint is not collecting on
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust.
However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. With a clog comes condensation and longer dry times. The dryer will continue to run inefficiently and cause the heating circuits to work harder and overheat. This will eventually lead to a failure of the heating circuits. If you are seeing condensation inside the dryer, it is strongly recommended the you inspect and clean the dryer exhaust vent hose. You should repeat this a couple of times a year to ensure it remains obstruction free.
The most frequent causes of dryer vent clogs comes from the following:
1. Ducting that runs in an upward direction in homes that have an attic exhaust. This is a stupid design that gravity will always win. When the dryer shuts offf, anything left in the vent will fall down the ducting to the base of the wall and accumulate. Over time, this forms a clog.
2. Ducting that runs under the home in a crawl space. If not correctly hung from the rafters, the ducting will develop sags causing choke points where lint can accumulate. Leaving it on the ground is not the answer, either. This gives opportunity for rodents to possibly chew through it. This will cause leaks which exhausts warm moist air under your home resulting in mold and mildew.
3. Using plastic dryer vent hose. This type of hose is not recommended because it kinks easily and can get crushed, causing an obstruction where lint can clog. Rodents can also chew through it easily. Pushing the dryer up against the wall and crushing the hose is a common cause. Use the semi-rigid metal type ducting that resists crushing, kinks and rodent infestation.
4. Rodents. Mice love lint. If given the access to it, they will build inside the dryer vent hose which provides a nice warm place to live with lots of bedding material. Make sure you exhaust vent on the exterior of your home is about 12 inches from the ground.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not become clogged.
6. Excessively long vent hose. The rule of thumb when it comes to dryer vent ducting is: The SHORTER and STRAIGHTER the run, the BETTER. Excessively long dryer vent hoses will clog due to the fact that the blower fan is not able to push all the air and lint all the way to the exhaust.
7. Kinked, Excessively Bent, or Crushed vent hoses. If the vent has any choke points due to kinks, bends, or gets crushed behind the dryer, you will develop ponts where the exhaust vent will clog.
The following link may also help in providing some basic guidance on how to install dryer vent hose:
http://www.fixya.com/support/r389357-dryer_ducting_installation_tips
I know it may seem that I'm beating this point to death, but it is important to provide good air flow for your dryer. The number one cause of dryer failures and house fires comes from poorly maintained and poorly installed ventilation ducting.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 07, 2009
  • 84 Answers
SOURCE: the lint from my dryer is not collecting in the
Here are a few ideas:
1) check the filter screen for holes,
2) check the screen for shape
3) check the screen for tight fit (it should fall/snap into a snug fit)
4) check the drum for a loose fit (there is a felt kit you can buy for this)
5) unplug the dryer and get old lint out of the duct in the unit and between the unit and the outside
and
TRY it again!
Posted on Dec 26, 2009
Dryer starts but after a few seconds shuts down
In the last 6 months, I have fixed 3 dryers with your symptoms. In each case, after taking the dryer completely apart, I found it plugged up with a huge amount of lint. This lint was not caught by the filter screen, it had collected all over the inside of the machine. It required dismantling the machine completely to clean,. Each dryer then worked fine.
Be blessed.
Jan 03, 2014 | General Electric Profile DPVH880GJMG 7.5...
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
I took out the lint filter to clean and it will now NOT slide back into the slot. It just stops about 1/4 of the way up the screen. This is the first time this has happended in the 2 years that i have owen...
you need to clean out the dryer or have someone come in to do it.unplug the dryer,remove the lint filter and then you have to remove the duct that the filter slides into and clean that but you have to take the dryer apart to do this,next you have to vac out the cabinet where the motor is and clean out the vent line,if it's a long run i use a leaf blower to do this,remove the vent line from the back of the dryer,go outside and make sure the vent is clear then go back inside stick the leaf blower into the vent line and blow all the lint outside.you have lint stuck in the tracks that the lint filter slides into,get a skinny long screw driver and poke out the lint,if you have an electric dryer you should do this once every two years if it's gas once a year so you don't have a fire,next time send the model number and the name of the machine you need help with so i can help you better,if you don't know how to take apart the dryer send the model number and i can help you but there is lint stuck in the tracks that the filter slides down into and if that's like that then you need to clean out the dryer
Dec 23, 2010 | Dryers
F @ P DEGX2 lint trap problem
If you are collecting more on the outside of the house means the lint filter has a tear in it and the lint in being pulled through the tear and pushed out the exhaust. It sounds like you need a new filter but this isn't cheap. If you do it your self it will run about $70 if you get a repair man it will cost about $150.
Feb 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Our GE gas dryer is burning clothes that are fleece fabric or blankets. Any suggestions?
I recently solved this problem on my ELECTRIC dryer by taking apart the lint collection area. Some dryers allow you to do this by removing a couple screws surrounding the lint screen holder. Others require some dis-assembly of the top and front panel.
Once you have access behind or below the lint screen, use your hands or a strong vacuum (shop-vac) to clean out any collected lint that has fallen below the collection screen and settled in the exhaust duct. I pulled out about 100 cubic inches (~1.6 liters) of collected lint, cat hair, and debris that was obstructing air flow.
Obstructed airflow can cause metal parts near the electric heating element to overheat and scorch clothing and is a serious fire hazard. I expect similar problems can occur with gas dryers.
Dec 28, 2009 | GE DBL333GB Gas Dryer
My dryer is blowing lint out through the vent outside, I clean my lint trap every load, but it still sends lint outside
this is normal for lint to blown out the ducting because not all the lint will be collected on the lint filter when you remove the filter some lint may fall of down into the duct housing.there is nothing ot worry about
Sep 19, 2009 | Samsung Dryers
Is there supposed to be a hole on the side of my dryer
Well, though it be simple, you might clean the lint filter everytime you use it. Over time a dryer even with lint filter cleaned will still collect small amounts of lint inside it. You shouldn't worry much but you could call the maytag man to come and take apart the dryer and clean the inside. <;O)
Sep 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Lint CollectorModel LGL88580000- Built: 1995.
the fan that work to collet lint is not working at all or working slow.so if your cloth are not drying in the time you set up. than that proublem.
Dec 19, 2007 | Whirlpool LGQ9858P Gas Dryer
Dryers Logo
48 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
