My canon ipf750 keeps replenishing with ink, getting 70% of the way through it and then will have a hardware error saying that the printer needs to be turrned off and on, when i do it says starts replensihing again and it all happens again. I am over run with prints and cant afford to keep wasting ink so need to open up the printer when it is off and release the carrage so i can cean around the ink drainage area so that it wi work again, i have seen an engineer do this but dont know how to do it myself.
SOURCE: I have a canon MP630,
I've had the same problem with my MP630, and have tried everything to fix it - still not working properly. I've washed the print head, changed settings, changed printer drivers, upped the cyan on my preferences, but still get poor quality blue, which in turn skews all other colours. Can anyone help???
Posted on Dec 10, 2010
  • 3 Answers
SOURCE: printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Posted on Dec 29, 2007
SOURCE: Ink tank lamps - the magenta horror
here is the advice that Canon Customer Support give -------
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query please be advised that you should try to remove the ink tank and reinstall it in the position. In case the error message will appear, please try to unplug the device for 1 hour from the power source.
In case after re-plug the device will show again the error message regarding the magenta ink tank, please be advised that you might either test the device with a new magenta ink tank in order to find out if the device or the ink tank is the faulty one, either contact one of our service centers for further examination of your device. We are sorry for the inconvenience.
Please click on the link below to visit the Canon UK website where you can find details of your local Authorised Service Facility as well as other important information needed to send your Canon product for repair:
https://self-service.canon-europe.com/uk/pages/ss_Layout.cgi?LINK_ID=8270&LANG=en&build_frames=1
Yours sincerely,
Canon Support Centre
Posted on Feb 09, 2008
Mike258
  • 1498 Answers
SOURCE: Canon Pixma ip4200 printer, error 1414
Hello there,
I've gotten in touch with Canon and have something a little different to try. At the very least the error should change. (Sorry, gallows humor). Please read this entire response before taking action.
After the upcoming test procedure, I have included a link and procedure to contact Canon tech support. The assure me they will replace any faulty tanks.
The purpose of this exercise is either rule out ink tanks that are behaving or isolate the one(s) responsible for the 1414. You should write down the results of this test. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error 1414 Ink tank problem on my Canon PIXMA iP4200
The error won't go away.
I have replaced the <color in question> tank, reseated it, yet the error remains.
You will also need to list what inks are being used in the printer. State the type of ink that is being used and the order that the tanks are installed in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Mike
If you could take a moment and rate this response, I would appreciate it.
Posted on Jul 31, 2008
SOURCE: "used ink tank is full"???
OK, Boys and Girls...here finally is the complete answer to the problem of the waste ink tank counter reset for Canon i250 and i350 printers.
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...It did for me.
You May Thank Me NOW!!!!
I must say...I went into the "GUTS" of the beast and cleaned out the PADS (they are actually vacuum pads that the INK is sucked through during a HEAD cleaning) a very messy undertaking.
I'm not sure how much life this will add to your printer.
Good Luck
Posted on Sep 26, 2008
Canon iPF750 error message: E161-4050, all the ink cartridges and the maintenance unit have all been replace twice, but I still receive the same error message.
The error refers to a purge motor failure. Which could explain why the printer is saying that you do not have enough ink.
You can solve this error code by removing the purge unit.
You have to replace the purge unit with a new one.
You also need to check the gears by turning the unit upside down.
Sep 25, 2017 | The Office Equipment & Supplies
Error e161 403e en canon ipf750
Canon IPF750 Error Code E161-403E - so, I understand this means the printer head is shot & needs to be replaced.
Feb 03, 2015 | Canon Office Equipment & Supplies
Canon ipf750 error 2F30
Esse error ? relacionado a troca da cabe?a de impress?o.
Nov 07, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Canon ipf750/upgrade firmware
I would first check the linear scale.That`s a small plastic strip ,positioned along the total lenght of the rail.Mind you ,I don`t have a ipf8000.But maybe the systems are the same.The linear scale is under tension ,by a metal spring.Check if the strip is not hanging loose.Also check the strip (linear scale) on dirt or ink splashes.If so clean it with alcohol (that`s what I did on a ipf5000).The scale runs through a slit ,at the back of the carriage.There are light grey patterns on the scale.The sensor on the carriage reads them ,and thus knows the position of the printheads ,with respect to the rest position.Check if the scale runs smoothly through the slit.
Feb 27, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Canon ipf 750 e161-4050
The error refers to a purge motor failure. Which could explain why the printer is saying that you do not have enough ink. You can solve this error code by removing the purge unit. You have to replace the purge unit with a new one.
Read more: E161-4050 on iPF750. error not in manual. Cleaned print head? - What is this? Not on internet anywhere. I`m sure others have had this issue. :: Ask Me Fast at
Jan 11, 2013 | Canon iPF700 InkJet Printer
IPF700 keeps replenishing with ink after power went down
I am also getting the same error.....No idea what to do? Help me please if anybody solve this issue
Nov 29, 2012 | Canon iPF700 InkJet Printer
Canon ipf750 error 03130031-2618
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit.
Mar 01, 2012 | Canon imagePROGRAF Office Equipment &...
Error messages: U150 + Ink tank errors have occured
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
