Question about Minolta QMS PagePro 9100 Laser Printer
Printer reports Media Jam Fuser when there is none
I've removed and cleaned the fuser unit, plus all parts around the fuser, and the printer is still giving me this error. What other sensors (if not part of the fuser) can cause this error, so I can clean them or check them? We have a pretty dirty printer, so there's a good chance there's just a sensor that's so dirty it's picking up a jam.
  • knightspawn Aug 15, 2008
    I'm trying to avoid completely dismantling the whole printer. I don't do this for a living, and I'd rather just target the sensors that cause this error, not spend 8 hours cleaning the thing just to find out there's a bad sensor (which I wouldn't be able to spot just by looking at anyway).
  • knightspawn Aug 19, 2008
    There is no jam, but I don't know what sensor thinks there is a jam. I need someone to help me figure out what other sensors will report a jam in the fuser unit, because I've checked the sensors in the fuser unit and they're all clear.
  • 6,487 Answers
If you know how to dismantle the printer that will be better so you can clean the entire printer and check all the possible things that maight causing the paper jam....
Posted on Aug 14, 2008
  • Mark Gil
    Mark Gil Aug 15, 2008
    I understand but that's the best way to really figure out and solve this problem....
  • Mark Gil
    Mark Gil Aug 19, 2008
    If that's the case better take it to a repair center and let them check that sensor problem the sensor has the problem why its acting that way...
Toner cleaning off paper
Warning !! turn off power to printer before checking or removing fuser unit.
the fuser unit is not heating up the paper to 400 degrees celcius to fuse the toner to the paper. Would check fuser unit usually at back of printer. Warning !! turn off power to printer before checking or removing fuser unit.
You may have damaged it if you pulled it out while the power was still on to remove a paper jam or hopefully you just did not put it back properly .
check the temperature of the paper when printed it should be warm.
Mar 03, 2015 | Canon imageCLASS MF4150 All-In-One Laser...
I have a continous smudge on the right side of the page when printing on a 2420dn. I have replaced the cartridge with no success.
Your Fuser Film is the most likely cause. These do more often than not, fail prior to the fusing unit needing to be replaced. The test for this is to print a page then shut the printer off when the page is about 1/2 way thru the printer. Just kind of time it from the time it feeds the paper to when the paper exits the printer. Cut this time in half and use that as a guide to when to shut the printer off. Once you do this open up the printer where the toner cartridge is and remove the cartridge. If the page is about 1/2 printed then look at the edge where the smudge usually is. If it is not there then you know it is the fuser. You can either order in a new fuser unit or see if a local repair company will do just a fuser film for you. This is what I do. The fuser film plus labor is about $100.00
The fuser unit plus labor is around $250
Also if the fuser is at fault you will sometimes see part of the image from the top part of the page will get reprinted farther down the page in the area where the smudge is.
Good Luck and Thank You for using Fixya.
May 20, 2010 | HP LaserJet 2420 Printer
In Konica Minolta 2430dk, I had a media jam in the fuser. I cleared the visible paper, but there is still some stuck inside the fuser that is impossible to clear (I can't get my fingers to it), so printer...
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Jun 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
Paper Jam Around Fuser Unit
Remove the fuser unit and unwrap the paper. The instruction book should tell you how.
Feb 17, 2009 | Brother HL 1440 Laser Printer
What is media jam fuser error
It means there is a paper jam in the fuser (the hot part that fixes the toner to the paper).
Check if there is any sheet jammed inside your printer or if any sensor is in the wrong position.
If everything seems to be ok, you may need to replace the fuser.
Nov 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Media jam transfer roller
We have a Xerox 6120 which is mechanically identical to the 2430. It was reporting media jams. We determined after removal and careful inspection that the fuser roller and fuser pressure roller had been damaged by what looked like someone attempting to clear a jam with a sharp object. I cannot speak re: the 2430, but the fuser in the 6120 is not a FRU. The construction of the fuser doesn't tolerate any flaws on either surface. There was more paper jammed in the fuser where we couldn't see it until we had the fuser out of the printer. We are shopping for a new printer as the repairs will cost more than we paid for the printer.
Dec 10, 2007 | Konica Minolta magicolor 2430 DL Laser...
Reporting my inactive printer
To clear this error: Power the printer off and let it stand for at least 30 minutes to allow the fuser to cool. Remove the coating roller from the top of the fuser unit to reveal the orange fuser rollers underneath. Check to see if any paper/transparency has become wrapped around the fuser rollers or jammed in or above the fuser unit itself. Since some paper jams can be very difficult to see with the fuser installed, remove the fuser and check for paper/transparency jams under the unit as well. A jam in that area can cause 993 errors. If there is no media jam and the error remains after the printer is restarted, try replacing the Oil Coating Roller (OCR). The OCR comes with the black toner cartridge. (It can also be purchased separately. Click here to do so.) If the error remains after the OCR has been replaced. If that does not help I would highly recommend taking it back to the place you bought it from
May 06, 2007 | Lexmark Optra C710 Laser Printer
Minolta QMS PagePro 9100 Laser Printer Logo
306 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
