Question about SE Electronics Z5600A Professional Microphone
The mic is 'dead' the control box does not produce a 'hum' from the monitor amp when poking wire in the 8 pin Army connector.I think I will first see if the ECC83 htr is working before consulting you further!
  • 3 more comments
  • Michael Gamble
    Michael Gamble May 22, 2011
    Dear
    Team
    I have done a little checking with
    this microphone (belongs to a friend) to find out why it doesn't work. Here are
    the results of my tests:
    1. Dismantle mic to expose the tube
    and electronics pcb
    2. Turn on the power/control unit in
    the darkened workshop to check if any glow from ECC83A heaters
    (NO)
    3. Remove ECC83A tube and check
    heater contacts - Pin-outs 4 - 5 and 4 - 9 and 5 - 9 (YES to
    ALL)
    4. Turn on power/control unit and
    check voltages (DC) at Pin-outs 4 - 5 (180v DC !!! ?) I am using a small multi
    meter - nothing exotic.
    Wondering if my interpretation of
    the Pin-out is correct. Looking 'down' on the 9 pin SOCKET I am counting from
    the gap in a clockwise direction starting from 1. This means if I check the
    Pin-out of the ECC83A the numbering will be Anti-Clockwise starting again from
    the 'gap'.
    5. Remove mic. cable from
    power/control unit and turn it on in order to check voltages at cable Pin-out.
    These connectors are 8pin 'Army' type and the pin Nos are given at the base of
    each pin.
    Results:
    1 (+) - 2 (-) = 134v
    DC
    2 (-) - 3(+) =
    12v.DC
    2 (-) - 4(+) = 50v
    DC
    2 (-) - 5 (x) = 0v.DC or
    AC
    2 (-) - 6 (x) = 0v DC or
    AC
    2 (+) - 7 (-) = 7v
    DC
    1 (+) - 7 (-) = 420v
    AC
    1 (+) - 4 (-) = 250v
    AC
    1 (+) - 3 (-) = variable 200v. AC
    depending on position of Polar Pattern control
    knob.
    Please
    comment!
    Michael
    Dear Team
    I have done a little checking with this microphone (belongs to a friend) to find out why it doesn't work. Here are the results of my tests:
    1. Dismantle mic to expose the tube and electronics pcb
    2. Turn on the power/control unit in the darkened workshop to check if any glow from ECC83A heaters (NO)
    3. Remove ECC83A tube and check heater contacts - Pin-outs 4 - 5 and 4 - 9 and 5 - 9 (YES to ALL)
    4. Turn on power/control unit and check voltages (DC) at Pin-outs 4 - 5 (180v DC !!! ?) I am using a small multi meter - nothing exotic.
    Wondering if my interpretation of the Pin-out is correct. Looking 'down' on the 9 pin SOCKET I am counting from the gap in a clockwise direction starting from 1. This means if I check the Pin-out of the ECC83A the numbering will be Anti-Clockwise starting again from the 'gap'.
    5. Remove mic. cable from power/control unit and turn it on in order to check voltages at cable Pin-out. These connectors are 8pin 'Army' type and the pin Nos are given at the base of each pin.
    Results:
    1 (+) - 2 (-) = 134v DC
    2 (-) - 3(+) = 12v.DC
    2 (-) - 4(+) = 50v DC
    2 (-) - 5 (x) = 0v.DC or AC
    2 (-) - 6 (x) = 0v DC or AC
    2 (+) - 7 (-) = 7v DC
    1 (+) - 7 (-) = 420v AC
    1 (+) - 4 (-) = 250v AC
    1 (+) - 3 (-) = variable 200v. AC depending on position of Polar Pattern control knob.
    Please comment!
    Michael
  • Michael Gamble
    Michael Gamble May 23, 2011
    I posted more about this SE Electronics Z5600 mic problem today but I cannot find any reply from Fixya even though told a reply is available. Maybe I'm pushing the wrong buttons!
  • Michael Gamble
    Michael Gamble May 24, 2011
    The mic. is on the bench just waiting for some help. What I need for starters is basic understanding of the pin-out of the ECC83A - which pin is No.1 on the tube and which pin is No.1 on its socket. Obviously they will correspond! That done I can more intelligently pose questions and give the results I am seeing. The voltages shown in my earlier message were taken at the socket of the 8 pin 'Army' female connector on the power/control box to which the multi core cable to the microphone is connected. It would appear that as much as 180v.DC is being delivered to pins 4 & 5 (reading clock-wise on the tube socket) and yet there still is continuity across 4&5 pins on the tube. As this is a double triode there's also a centre pin (9) to the heater which is also showing continuity. Yet 180v.DC should surely have blown that heater element! So where is the 180v. coming from? Is it a 'bogus' reading? Does anyone have the Cct. Diag. for this SE Electronics Z5600A ii microphone unit with voltages at the pin-outs? Again, I am using a simple multi meter with AC, DC and Ohm reading.
    Comments please
    Michael
  • Michael Gamble
    Michael Gamble May 26, 2011
    Hello! Is there anyone there who can answer my questions about the sE electronics Z5600Aii microphone? I have posted the problem to do with there being 180DC applied to what appears to be the heater pins (4-5-9) to the ECC83A tube. I have given the readings I established at the 'Army' 8 pin socket on the control/power unit. Does anyone have the Cct Diag. for this unit showing the correct voltages to be seen at the 'Army' connector? I have had no answer to my postings for 3 days. Please help! Michael
  • Michael Gamble
    Thank you. I do hope you find the Circuit Diagram for this Z5600A ii microphone control/power unit. I am getting nowhere with it as yet.
  • 1,238 Answers
Good day!
Ok try to check it first.
If you have any question just add a comment.
Thank you
Posted on May 22, 2011
  • 1 more comment
  • bonifacio gomez
    bonifacio gomez May 22, 2011
    OK that's good.
    Thank you.
  • bonifacio gomez
    bonifacio gomez May 23, 2011
    ok I don't know what is happening on your questions.Maybe hitting a wrong button or there's no expert answer your question.
    thank you
  • bonifacio gomez
    bonifacio gomez May 26, 2011
    OK I search the diagram
Senheiser freeport no sound
If it seems as though the transmitter signal is being received but there is no audio, disconnect the 3 or 4 pin connector of the mic and touch the different pins while transmitting to the receiver. If there is audio hum or buzz, the mic itself is probably dead. A wire could be off inside its connector.
Mar 04, 2014 | Sennheiser Audio Players & Recorders
Heil icm plug wiring diagram
The Heil "ICM" microphone is designed to be used with certain Icom brand ham radios. These have a 8-pin round plug. Describing the pinout to you will depend upon your perspective, whether you are looking at it from the microphone plug itself, or the microphone socket on the front of the radio. Therefore, from the perspective of looking at the mic plug on the end of the mic cable, note that there is a notch or dimple in the plug that also lines up with the screw. Going clockwise from the notch, the pins are numbered 1 thru 7. Pin #8 is the center pin.
Pin 1 = mic input
Pin 5 = Push-to-talk (PTT)
Pin 6 = PTT ground
Pin 7= Mic ground
From the standpoint of an Icom transceiver, the remainder of the mic connector pins are as follows:
pin 2 = +8 volts DC (output from the radio)
pin 3 = frequency control up/down
pin 4 = squelch switch
pin 8 = audio output (level varies w/vol control)
Hope this helps
Jan 03, 2014 | Heil Sound Audio Players & Recorders
Connecting r21s to laptop
The input to the laptop usually requires a stereo or TRS type 1/8 inch plug If the mic has an XLR type connector, you need a special cable that connects the XLR pins 1 and 3 (adjacent pins) to the shield of the 1/8 inch plug and pin 2 of the XLR connector to BOTH the tip and ring of the little stereo jack. Such a cable is not commonly available so the best is to make one from parts you get at Radio Shack.
Mar 12, 2013 | Samson R21S Microphone
I'm trying to wire a galaxy desk mic to a cobra 200 10 meter mobile
  • The Galaxy desk mic (power mic) is already wired four pin and the Cobra 200 is a 4 pin already as well. So unless someone has messed with them the mic will plug right up to the radio as is.
  • But if someone has repined the mic then follow the pinout I listed below to get it rewired for the Cobra 200
  1. Pin #1 on mic connector - Black wire.
  2. Pin #2 on mic connector - White wire.
  3. Pin #3 on the mic connector - Blue wire.
  4. Pin #4 on the mic connector - Red wire.
  • If you look on the end of the mic connector it will have the imprint of the number for each pin on the mic.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 02, 2011 | Cobra Radio Communications
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
I would like the color breakdown on the wiring diagram
colors are on the bike side of the connector are spelled out in the shop manual, however they do not include what is used for the headset side of the connector. These are the three pin numbers on the connector that appear to be the ones for the microphone portion. Hope it helps. For the whole setup the passenger uses 5 pins and a tab; while the driver uses all 7 pins plus a tab. So, on a HD three wires will not correctly interface with the system.
pin 4 =BK = MIC Common
pin 2 = passenger gy/bk & Drain = MIC Shield
pin 2 = front y/bk & Drain = MIC Shield
pin 1 = red = MIC
Jul 19, 2009 | 2008 Harley Davidson FLHX Street Glide
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Mic wiring problems.
I have one for a Cobra CA50 may work
pin-1 shield or ground
pin-2 audio lead
pin-3 tx
pin-4 rx
there are one more
pin-1ground
pin-2 audio
pin-3-rx
pin-4 -tx
Nov 18, 2008 | Radio Communications
Galaxy 33
well 1st a good radio fragile it is but it kicks **** well
well that hum might be something being lose on the board itself
try to poke the board as you have the radio power with a plastic stick see by pressing you can pin pont the area where something might be lose if you feel risky try soldering yourself.
that's how you learn that gelly rubbery substance inside the radio means cratical part of the bord should be play with unless you are a professional no doubt I hope I help you a bit no doubt
Jun 03, 2008 | Galaxy Radios DX-33HML 40-Channels Base CB...
Cobra 148 gtl
First off check to see if your mic gain is turned all the way down. Second; if you have a power mic is the battery dead ir the volume of the mic turned down. If these check ok, look for a loose or broken audio wire in your microphone, and the connector (both ends can break). I have seen the wires break as far back as 4 inches from the mic head and the connector depending on how the user held the microphone, or pulled against the wire. if the problem is not found to be any of the above I suggest you take the radio to a qualified technician for repair.
Dec 11, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
SE Electronics Z5600A Professional Microphone Logo
Top SE Electronics Audio Players & Recorders Experts
Michial Gueffroy
Willem.
Willem.
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
