Question about Philips 52PFL7403D 52 in. LCD HDTV
Where can i find a ir sensor for my Philips 52'' lcd tv model 52pfl7403d/f7 ?
  • 760 Answers
There are plenty of places you can look. Shopjimmy.com. Tiger parts direct. Encompass parts are just a few. Just google the part# and some part suppliers will pop up.
Posted on May 20, 2011
  • johnnyvan21 May 30, 2011
    Ive tried all of those part co, still no luck maybe you can help me with a part number for a 52PFL7403/f7 for the ir sensor
  • Matt Knopp Sep 29, 2013
    3139 123 63274
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
How to fix horizontal lines across whole screen on my Philips TV model# 52PFL7403D/F7?
The standard way to find out whether the issues on a tv are hardware related or settings environment related is to perform a reset to factory default through the menus available from the remote controlIf the fault persists after a reset and rescan the fault is almost certainly hardware related and will need the attention of a competent technician
Jul 03, 2015 | Philips Televison & Video
Remote sensor is bad on my Philips 42PFL3603D/F7 LCD TV. Can I fix it?
Yes just replace the IR sensor board very easy to do. You can get the repacement IR board from www.tvcircuitboards.com
Dec 13, 2012 | Televison & Video
Part # for 52PFL7403/f7 for ir board sensor sensor for philips lcd tv.
Look on Encompass Parts Distribution type in your Model Number .1-800-638-3328
Try Shopjimmy.com
May 30, 2011 | Philips Televison & Video
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
My remote has stopped working. We have replaced the batteries with no luck because of this we cannot switch between sources My TV is a Philips 42" Model # 42PFL3603D/F7 Serial # VA180905005250
Hi:
The IR remote sensor in side of the television need replacing, this is the sensor that receives the commands from the remote and relays them to the microprocessor of the TV. Have the remote sensor replaced.
Mar 10, 2011 | Philips Televison & Video
I have a 42" LCD
Some of these TV were equipped with very short connections from the infared board to the small signal board. Remove some of the shrink tubing from the wires of the IR cable to relieve stress on the individual wires. Trim the other end of the cable as well. We are talking about one half to three quarters of an inch.If this does not help you will need to order a new IR cable. Please show this info to an authorized Philips dealer and have them do this for you. Thanks for asking and show a few hands of support.
Feb 19, 2011 | Philips 42PFL5332D 42 in. LCD Television
52PFL7403D/F7 remote does not work with my TV
Hi
First thing to do is check your remotes by aiming them at a camera or the camera on your mobile phone then pressing any button you should see the led on the remote light up white, If this happens then your remotes are ok and you would then need to look further into the problem.
I would suggest the remote sensor in the tv being short or you may need a replacement AV board (the one that has the inputs and scart sockets are on )
Hope this info helps
Apr 05, 2010 | Televison & Video
Philips 52PFL7403D 52 in. LCD HDTV Logo
309 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
