1999 BMW Z3 Logo
Posted on May 20, 2011
When I accelerate quickly in first and second gear I hear a vibration that sounds like it's right under the center console. I think It might be the bushing thing that connects the front part of the drive shaft to the back part. I want to know what's wrong and what would be the easiest fix.
juhalag
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 20, 2011
juhalag
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1586
Points
15
The two most likely causes are a worn front universal joint - a relatively easy fix but probably fairly expensive if done by BMW- or more serious, but lees likely, a worn bushing in the transmission tail-shaft housing. The latter will be more difficult and costly to repair but doesn't happen very often. A worn universal joint is much more likely. Dr.J
2003 F350 6L Diesel, 6 speed manual transmission. Vibration/noise right front when under medium to heavy acceleration, vibration/noise becomes very prominent starting at 1900 rpm in all gears (still can...
Rob, assuming this is a 4X4? Sounds like a bearing. They can vibrate, snap, clunk, all kinds of terrible noises or vibrations.
Axle u joints will also do this. Is it all wheel drive?
Jeep Cherokee Sport 1997 vibrates between 30 to 40 miles
Check your diff and transmission oil levels if ok then have the bearings on the diff checked
2answers
High pitched noise and Rattling in gear box.
sound like main shaft bearing assuming it is manual( if it comes on all the gears)
if it is automatic it must be your torque converter bearing
My 02 freelander vibrates when accelerated
A VIBRATION in the drivetrain is going to be noticeable both during acceleration and deceleration . Sounds like engine skip under a load.
1helpful
Vibration on right side when accelerating
could be jimmy, if lug nuts are tight, and wheel is balanced, the cv joint may be the culprit, are the boots torn ? if so, all the grease flew out, can you hear grinding when your turnning sharply ? back in the day when cars had drive shafts and the universal joints went bad, same thing, V-I-B-R-A-T-I-O-N ...............................
1helpful
2answers
2010 honda pilot center console removal due to vibration underneath
slide both seats all the way forward remove screws in sides of console if no screws on sides slide seats back and pull center from inside remove two bolts remove side skirt on each side screws under them remove ashtray center pocket screws under it also unplug wire connectors and remove
Weird noise when accelerating.
almost sounds like a clogged catalytic converter, hard to say not knowing the miles and how long since any maintenance and what was done.
When accelerating through the gears as i drive. I get a vibration when i hit second gear. Then when i hit 3rd gear, it feels like it slips and revs around 3,4k rpm, accelerating really slow. When i hit 4th...
sounds like 3rd gear/clutch is worn.I don't think a service will do any good.But if you remove the pan and find debris you know you will need a trans in the near future.
When I accelerate I hear a vibration noise from under the center of the car, it only last a few seconds but happens just about everytime I accelerate.
You have a 100.000 mile powertrain warrenty on your Tahoe. You can take it to the dealership and have it fixed for free, as long as there is a true problem.
Vibration When Accelerating
Did you machine the flywheel? Because if you replace the clutch without machining the flywheel. The flywheel will have high and low spots on it. The new clutch is perfectly flat, and the old clutch was worn into the flywheel. Thus, vibration! I sincerely hope that I helped. Best wishes to ya.
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
