Question about Hobart A200 Stand Mixer
A200T mixer The problem with this mixer is that second gear rotats at the same speed as first gear, third gear works fine. What would be causing this problem and how do I fix it. also, what kind of gear grease should I use and how full of grease should the gear box be thank you doug wedgemountmechanical@yahoo.com
  • EatCake Oct 13, 2008
    My mixer has the same problem. 2nd gear and 1st are the same speed. 3rd gear is ok.
    I had the same problem about 3 years ago. A tech came in and fixed it. Of course, I was busy at the time and didn't see what he did.
    Next time, I have to call a tech, I will be watching!!
  • 49 Answers
On the bottom of the planitary the part where you put the beater. there is two nuts. one lookes like a Acorn nut and a thin one above it. By the book the top thin one should be finger tight. Not wrench tight. you need a thin wall 3/4" wrench you hold the thin nut with iot and tighten up the bottom acorn up to the thin one and they lack against each other so not to come losse .on some mixers this thin nut tightend down will mess with older parts and bind the centersahft parts.
Posted on Sep 30, 2008
Kitchenaid mixer motor noise at lowest speed
Hi,have you set you speed of your rotations,maybe it's set to slow.you have to Adjust the screws in the backof the mixer,so the rotation of the motor is a second apart on the speed setting three.i quite sure that's the right speed number,I have it written down somewhere,if I can find it and it's different il let you know.ty hopethatworks.
May 16, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Slowspeeds
Please submit more information of the actual problem.
One issue could be that 1st and 2nd are the same speed, but third is faster.That is caused by having the two nuts in the bottom of the planetary too tight. This pinches the bushings in the second speed gear which drives by friction faster than the gears of 1st causing 1st to slip. Back off the acorn nut and thin lock nut perhaps a half to a full turn. Hold the lock nut and tighten the acorn nut to it. You can tes the setting by pushing up on he planetary. You should see about a 1/16" movement.
If you only have one speed in all gears, either the internal gear selector is broken, or a key is sheared between a gear and shaft.
Mar 05, 2014 | Hobart A200 Stand Mixer
Hobart a200 first gear not working
slacken the big acorn nut away from the bottom of the planetary and then tighten the lock nut to the acorn nut. When adjusted and secured, the planetary should have a little vertical play, maybe 1/16".
That will stop the second gear driving from friction from being too tight.
Feb 27, 2014 | Hobart A200 Stand Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
A200T Slips in low and medium speed
Planetary gears worn from, #1 changing speeds while unit running, #2 over loading the bowl. batter & icing max 75% bowl capacity, Dough max 65% bowl capacity
Jul 17, 2009 | Hobart A200 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
Sound like bearings
Ist check your agitator shaft for looseness. the shaft you put the beater on. wiggle side to side. if tight no play. If in first its quiet but you can here a grumble under load but second gets louder. and third even louder. If the shaft is tight. your gears down there are warn. you can take that all off with the two nuts underneath. and check the grease on the gears but even with new grease on them it most likely stay loud. grease it with hobart grease from your loacal hobart for the A-200 planitary not the transmision they also fve grease for Trans. if you can take the noise run it that way if not decide which arm & leg you want to give hobart for new gears.
Sep 10, 2008 | Hobart A200 Stand Mixer
A200t ist gear
This is a lousy diagram for your purpose ...
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Page 14. The spring goes on the right with the hump against the roller.
Mike
Apr 27, 2008 | Hobart A200 Stand Mixer
Mixer has just stopped
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525
Apr 04, 2008 | Hobart A200 Stand Mixer
Hobart A200
amy, depending on how old your mixer is there are 2 types of clutches for 1st gear.these could be your problems--a key is sheared on the shaft--shaft/gear is broken.the bottom part of the mixer where you put on the attachements is called the planetary,does it look like it has moved down?you could tell if the dough hook,wire whip,ect,ect is hitting the bottom of the bowl.if this is the case its just simply tightening the 2 nuts next to the beater shaft.if this is not the case you would have to dissasemble the transmission.let me know.
Jan 11, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
115 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
