Question about Canon Pixma MP450 All-In-One InkJet Printer
I have a canon mp250, it had a paper jam and now says error number 5100. Won't print, please help.
  • Canon Master
  • 4,338 Answers
It can have a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. The purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Also try:
Opening up the case so you can get to the side where the power pack is located and then disconnecting the small plug connecting it to the printer circuit boards, wait 10 seconds, reconnect the plugs again the printer and then re-connect the external power lead.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 20, 2011
My paper jammed, I (of course being inpatient) pulled it out and now the paper wont feed. Please help.
To fix the error 5200 or E2 or paper won't feed
1. Open the cover printer
2. The right side of the printer, there is a round plastic. Rotate the plastic or gears, as opposed to clockwise
3. Rotate the gears, until you hear the a voice from the right side of the printer (voice shifting gears on the right side of printer). Aiming to restore the position of the skid gear.
I hope this information helps. Thanks.
Oct 18, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code P03. It won't print, it doesn't make any noise when I turn it on, and I don't see any traces of paper.
Error code PO3 is caused by Timing Disk dirty / damaged.
Please use this methods
1. Check the timing disk sensor located to the left of the printer
2. Check and clean the board.
And start to print... thanks
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error message: Service error 5100 on my Canon MP160 Printer
The main reason of Canon Printer error code 5100 If you receive Canon printer error code 5100 message this means you need to reset the printer. This also signifies that your computer does not recognize the printer. Your printer will show this error code because the LED is blinking. If your PC does not recognized the printer then it will also affect your printing jobs and you will not be able to do any printing work.
When the error code 5100 appears in your Canon multi functional printer then the Printer LED light will blink. This also means that you need to reset your printer. You must fix this error as quickly as possible. For instant technical support please contact Canon Printer Technical Support.
Tips to Resolve Error Code 5100
  • The Canon printer will show error code 5100 to warn the user that there is some problem.
  • In order to fix the problem, you require to opens the top of the printer.
  • In the right side of the printer you need to search for the waste ink absorber pad.
  • The next step is to clean the waste ink absorber compartment with a paper or cloth. This also completes the resetting process of the printer.
  • Inspect the paper feed area of the printer and confirm that there are no obstructions or paper jams in the printer that may be responsible for the error.
Dial our toll-free number +1-800-213-8289 for quick online assistance for resolving technical issues relating to the Canon printers. Our Canon Printer Support Number service is available for fixing technical glitches of our customers. Please get in touch with our tech support team and will receive online remote technical help at highly reasonable charges.
Our Epson printer support technicians are always ready to sort out each and every printer related issue with latest solutions offered to its clients. We are a team of fastest printer tech support solution provider for every issues related to all printers such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc. If users are unable to solve this problem, they are welcome to drop us an e-mail and we promise to get back to them in short time span via our professional printer contact details. So, come and join us for tom experience our exceptional level printer solutions to your unexpected and critical issues. And also our Canon printer technical support technicians are always ready to sort out each and every printer technical issues with instant solution. We also provide instant remote support for Brother Printer technical support services for your common printer errors such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc.
How to Fix Error Code 5100 in Canon Multi functional Printers
Jul 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
MY CANON MP830 WILL DISPLAY A "ERROR 5100" USUALLY BEFORE OR AFTER PRINTING. IF I RESTART IT WILL PRINT ONCE, THEN DISPLAY "ERROR 5100." I CAN'T FIND ANY PAPER JAM IN PRINTER. HOPE YOU CAN HELP. RAY...
Other than:
1) checking that no paper is jammed in the printer (don't forget to check the rear access door for paper jammed internally)
2) holding the <On/Off> button until the display goes blank, then waiting ten seconds before pressing <On/Off> button again (to reset the unit) and
3) checking that the ink cartridges are properly installed,
if the problem persists, your Canon MP830 may require repair.
Dec 20, 2009 | Canon Office Equipment & Supplies
Service error 5100 on canon prixma mp198
Service Error 5100
Cause : Movement of the Print Head Holder is blocked.
Action "Clear the paper jam or foreign object that is preventing the Print Hed Holder from moving, cancel printing from your computer, then turn off the machine and turn it back on again.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 06, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Hi, I am trying to print a report and I get a service error 5100. I have cancelled print job and pressed ok, done this a number of times, still get the error, please help
Service Error 5100
Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response.
Thanks.
Have a good day. .top3Module { BACKGROUND-IMAGE: url(/images/Reviews/Top_3_BG_Asset.jpg); WIDTH: 310px; BACKGROUND-REPEAT: no-repeat; MARGIN-BOTTOM: 15px; HEIGHT: 361px } #RNR_rpt_div A { COLOR: #0033cc; FONT-SIZE: 12px !important; TEXT-DECORATION: none } #RNR_rpt_div IMG { VERTICAL-ALIGN: middle } .toptitleBest { MARGIN-TOP: 19px; FLOAT: left; COLOR: #4f81bd; MARGIN-LEFT: 19px; FONT-SIZE: 18px; FONT-WEIGHT: bold } .wrapperDiv:hover { CURSOR: hand } .wrapperDiv { FLOAT: left }
Dec 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Error 5100 I had a paper jam, and didn't turn the printer off before I pulled it out. Roller doesn't appear to be moving.
Service Error 5100
Hope this helps.
Thanks
Have a good day.
Nov 27, 2009 | Canon Office Equipment & Supplies
Paper jam under print cartridges
Stick a 9x12 piece of cardboard down into the tray to force out unseen pieces of paper.
Jan 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MP450 All-In-One InkJet Printer Logo
485 people viewed this question
old marine
old marine
