Question about Echo Garden
Never used weed wacker before I have a Echo SRM225 how do you start the darn. thing..? :) I have pulled and pulled and no I am not out of gas. :)
    Problem Solver:
  • 5 Answers
You need to put it in full choke. If it is in full choke and still won't start, try pulling the trigger a bit. once you have it started in full choke, back it down to half choke and hold down the trigger until it catches. Once it catches take the choke off entirely WITHOUT removing your finger from the trigger.
Posted on May 20, 2011
My weedwacker was working fine. All the sudden it shut down. The rip cord won't pull out to start it up again. Need answer asap. Thanks
Jamie, could be a recoil problem, broken clutch, probable the engine has seized on your weed wacker. You can try and free up, rebuild or replace trimmer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Stops Pull Cord for Gas Weeder
How to unsieze 2 cycle Weedeater
Seized piston engines can run again but not for long What do you think
Fixing seized up echo weed eater
Aug 15, 2016 | Garden
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 | Echo Garden
Help my weed wacker string
Pull the spark plug out and try pulling it over if still won't move might have seized the motor possible not enough oil in gas You can try if not to much damage done pour some kerosene or stove oil down spark plug hole let sit over night try again
Jun 08, 2013 | Garden
I'm working on a echo gt-200 weed wacker and can't get it to start. I have compression, fuel and spark. what can I check
Use only FRESH gas. 2 cycle motors are sensitive and will not run on gas that will still power a lawn mower.
I fought with this for years before realizing how gas degrades over time - especially in plastic gas cans - as the important fuel molecules can evaporate right through the plastic.
Use a quality 2 cycle oil and mix to proper ratio for the saw.
May 22, 2011 | Garden
Weed wacker wont start
Try a new spark plug or checka and see if it is getting fuel
Jul 18, 2010 | Troy Bilt Tb70ss Gas Trimmer
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Ball will not prime
you can check the filter in the tank just blow the filter out if that don't work check the lines going to the bulb if you have change the bulb out change the lines around
Jun 27, 2009 | Echo Rapid Loader, Trimmer Head
Gas weed wacker will start, but won't hold significant power
if there 2cycle weed trimmers the high side needle valve should be one turn out from all the way in the low side should be about 3/4 of a turn out if it a 4cycle 1-1/2 turns try these it may help
Jun 06, 2009 | Garden
Will not start normally
Your carbeurator has crud in it from leaving gas in it over the winter.
You may be able to clean it using a carbeurator cleaner spray which you spray into the air intake after you remove the air filter, OR by using a gas additive such as seafoam which will clean the carb. as it runs. If you have any old gas in the tank of your weedwacker, discard it. Same goes for your portable gas tank. Gas deteriorates over the winter.
May 20, 2009 | Garden
Garden Logo
116 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
