Dear Sir/Madam my laptop cd rom is not working please find the message below Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) Driver detail - tsst crop cddvdw ts l633c - if you help me to fix this problem it will be highly appericiate
    Problem Solver:
  • 10 Answers
-- You need to go to the Registry Editor.
-- If you have XP: Press Start then go to RUN. Type REGEDIT and press ENTER.
-- If you have Windows Vista or Win7: Press Start then type REGEDIT (it should show on the start search box) then press ENTER or left-click on the item that shows on the top left of the menu as regedit
When you have the panel up you need to make sure you follow these instructions precisely.
Click on the plus signs (+) next to the following folders to get them expanded
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* 4D36E965-E325-11CE-BFC1-08002BE10318
Once you have made sure you are on the correct folder you need to look for the "upper filter" and "lower filter" and DELETE them. It needs to be specically as it is. Do not delete it if if it says .bak at the end of the name.
After this you MUST make sure the values are exactly like this:
(Default): DVD/CD-ROM drives
Class: CDROM
ClassDesc: @%SystemRoot%\System32\StorProp.dll,-17001
EnumPropPage32: storprop.dll,DvdPropPageProvider
IconPath: %SystemRoot%\System32\imageres.dll,-30
Installer32: storprop.dll,DvdClassInstaller
-- If any of them does not match you need to double click on the item name and change the value accordingly.
Close the page and RESTART the computer.
Posted on May 20, 2011
  • 4,338 Answers
A registry problem was detected. This can occur when more than one service is defined for a device, if there is a failure opening the service registry entry, or if the driver name cannot be obtained from the service registry entry.
Try these options:
  • In the Control Panel
  • Click on the CD/DVD entry in the device manager, right click, select Uninstall, and then click Scan for hardware changes to load a usable driver.
  • Or:
    If the device is a CD or DVD drive, follow the procedure in Article ID 929461
http://support.microsoft.com/kb/929461
Or:
  • Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
    Sergeant:
  • 228 Answers
Since it has something to do with the registry, you have 2 options to fix it. There are lots of forums that shows steps on how to edit the registry (make sure to back up registry files before editing it, mistakes on registry editing can cause further damage to the operating system). However, I do not suggest this to non-advanced users. If you are not comfortable with editing the registry, I recommend to just reinstall the operating system.
Hope this helps.
When i insert my cd in laptop it is getting rejected by my lap top and the message comes that PLEASC INSERT CD.now please help me it is very urgent.
the reason can be many, any way follow these steps; - clean the cd (Scratches, scuffs, break in the disc; they can all cause the problem you described.) 1) Right click on "My Computer" and click "Properties"
2) Go to the "Hardware" tab and Click the "Device Manager" button.
3) Find "DVD/CD-ROM Drives" and click the + to drop down your installed devices
4) Find your device and Right click, then choose "uninstall"
5) Reboot
6) When you boot back up, Windows XP will recognize you have a hardware device that isn't configured
7) Follow the prompts to setup the device (You can connect to Windows Update to allow it to search for a driver
If the laptop is recognizing any cd then it might be the drive is damaged/broken and needs to be replaced.Hope these information helps,
Please rate if the solution was helpful, thanks!
Jul 13, 2011 | Computers & Internet
My cd/dvd drive has stopped working it says- Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)- what can i do to fix it...
Click Start
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the CD/DVD branch of the tree.
Right-mouse click on the CD-ROM, and choose "uninstall" or "remove".
Restart your computer, and Windows should "find new hardware", and should load the correct device-drivers for your CD-ROM.
Dec 10, 2009 | HP Computers & Internet
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) For emachines windows vista atapi dvd a dh16a1p ata device stop...
Hello there:
First i would double check to make sure that the device is windows vista compatable and is compatable for your system next i would uninstall the device using device manager and than select view and select scan for hardware changes and let the computer reinstall the device and it will let you know that your device has been found and is installing than it will let you know that your device is installed and is ready to be used or it wil give you a error message if so than i would contact the manufacturer of the device and see what they say about the message ok?
best regards michael
Sep 08, 2009 | E-Machines emachines (emachinees) CD-ROM...
try to uninstall the cd rom.... then restart your computer
Jun 29, 2009 | Sony DDU1642/C1 Internal DVD Drive
Optiarc cd-rw crx880a ata device: This device cannot start. (Code 10)
Did you try to click "Troubleshoot" on the page that reported "cannot start" ?
Did you try to click on the device, and choose "uninstall" ?
Then, rebooting Windows should cause Windows to "find new hardware", and properly configure the DVD/CD drive.
May 22, 2008 | Microsoft Windows Vista Ultimate Edition
Not able to install webcam
Normal 0 Try disconnecting the Camera from the USB port and reinstallthe software program. When the program asks you to connect thecamera to the USB port, do so and it should work.
Hope this helps. Bud
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
