Question about Dishwashers
We have developed a fault with our Hotpoint aquarius FDL570 dishwasher. Both the 'On/Off' and 'Start/Pause' green lights start flashing together during a wash cycle. This means it does not finish or clean contents inside.
  • 11 Answers
SOURCE: Hotpoint dishwasher
Switch the machine off and unplug at the mains. Leave for ten minutes, then plug in and switch on. My dishwasher control panel had a mind of its own and did what it wanted including leaving water in the bottom of the machine. The electrics sometimes need re-booting! Hotpoint suggested the solution and it worked for me. Saved me £99 call out charge. Good luck.
Posted on Jun 12, 2009
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
  • 25 Answers
SOURCE: hotpoint aquarius dishwasher fdw60
Replace the timer control
Posted on Nov 16, 2007
SOURCE: hotpoint aquarius FDW60 FAULT
dishwasher runs for 1 min then stops and 40c indicator and 50c indicator flash on and off together it pumps water out then stops
Posted on Oct 25, 2009
  • 70 Answers
SOURCE: my dishwasher hotpoint fdl570 is full of water
1)check the blockage in drain.(any block in drain hose)
2)check the drain motor working.
3)remove the water manually and start up.(if it works may be on the drain pump problem)
Posted on Jan 08, 2010
I have a hotpoint fdl570 dishwasher, not working, machine pumps out sump water, starts to fill, and all the lights start flashing, and water pumps back out. any ideas?
It may be having water level sensing issues, so it drains to avoid an overflow... break out your multi-meter or call a decent technician
Nov 20, 2016 | Hotpoint Dishwashers
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Flashing lights on Hotpoint FDL570 Dishwasher
I had an identical problem with the salt and rinse aid lights on the left and the drying and end lights on the right flashing shortly after switching the dishwasher on. When I pulled it out, as this was the only way to look at the pipework, I noticed a big kink in the water hose. Removing this and obviously sorting out the flow problem has resolved the issue.
Mar 20, 2010 | Dishwashers
My dishwasher hotpoint fdl570 is full of water when i press the start button after about 10 mins all the lights on the display start flashing can you help
Jan 08, 2010 | Dishwashers
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius dishwasher
Oversudsing
This can be due to using a laundry or handwash detergent instead of a specific dishwasher detergent instead. It could also be due to excessive amounts of rinse aid in the dispenser or certain food soils that contain a high level of protein such as eggs.
Oct 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
770 people viewed this question
Top Dishwashers Experts
Owen Barnes
