Question about Frigidaire Affinity ATF7000ES Front Load Washer
When Start button is pushed, a buzzer goes off, the same buzzer that goes off when the door is not completely closed. After repeated carefully closing, it still goes off. I suspect the switch where the door latch goes into (recessed, not light switch) is damaged. An error message "dr" is displayed. Recently, the door has been sagging a bit- hinges need adjustments - so users have been slamming the door, and possibly damaging that switch. That's my guess.
  • 4,323 Answers
Hi
You are right....dr is a door lock circuit error which means that the door lock-switch assembly has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 20, 2011
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Reason for door codes on a frigdaire front load dryer
Your door lock my be defective and need replacing. It has to send an input to the computer otherwise a door error will display
Mar 03, 2015 | Frigidaire Affinity FAQE7011LW Electric...
Door alarm buzzer goes off inadvertantly
in the door jam you should find the button for the buzzer some of these are adjustable the button might not be getting push in all the way if this doesnt fix the problem I would find that stupid buzzer and rip it out
Jan 25, 2013 | 1998 Ford Windstar
I have a Kenmore dryer 70 series. The buzzer won't turn off once the cycle is finished until I open the door. If I move the timer into the middle of the cycle and close the dryer, it will start again w/o...
It sounds like you have a faulty switch. The switch located behind the start button controls both the on/off setting and the buzzer. You can either replace this switch (which will likely take care of both problems) or you can take it apart and adjust the contacts. You can test them with a multimeter before and after to make sure you've got them adjusted properly.
Aug 21, 2010 | Kenmore 62602 Electric Dryer
Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
Oct 18, 2009 | LG WM-1290FHB Front Load Washer
Buzzer always on, drum won't start spinning
yes you lneed a motor 150.00 to 200.00
May 28, 2009 | Dryers
Batch complete sounds when start button is pushed
door switch or timmer or the knob on the timer may not be turning the timer
Nov 27, 2008 | Maytag PYE2300AY Electric Dryer
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Washing Machines Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
