Question about TP-LINK (TL-WN822N) Pre-802.11n Wireless Adapter
Lefonica.netI installed the software for the win 7 64 bit version of this adapter on my pc. It comes up on the wireless network connectionn 2 status as not connected to the internet but transmitting at 412.3gbps ???It also states the device is enabled. However when I go into diagnose it tells me there might be a problem with the wireless Network Connection 2 adapter can you help.( adapter is TL WN822N)
4 Suggested Answers
  • 289 Answers
SOURCE: Today, I was using my
There appears to be some interference from external sources. Check if:
  • Your router is near anything that can give any microwave radiation
  • Your router is anywhere near a freezer/refrigerator
  • Your router is near any device that gives off any interference
You might need to boost the signal in the router. Try using the device on a computer that is closer to the router and check if the fluctuations still occur. If they do you might have a faulty adapter and you may have to return/replace it.
Posted on Jul 06, 2011
SOURCE: I bought a TP-link TL-WN821N
Dear Joeri_troch This is Howard from TP-LINK Support Force. Could you please check if your desktop has recognized the wireless adapter? And can you see Wireless Network Connection icon?
TP-LINK Support Force http://www.tp-link.com/en/support/ http://www.facebook.com/TPLINK
Posted on Sep 19, 2011
SOURCE: I have Windows 7 64-bit
Dear ubose1, This is Howard from TP-LINK Support Force. Maybe the anti-virus software blocks the driver installation. Please disable the self-defense function and exit it. Then try to install the driver again.
Wireless adapter tp-link tl-wn321g dont install into win xp sp3---please send driver
There are 4 different versions op the TP-Link TL-WN321G.
Look on THIS PAGE how to find the version and download and install the correct driver.
Aug 31, 2011 | TP-LINK TL-WN321G - Network adapter -...
COMPUTER WILL NOT DETECT ADAPTER
Remove adapter and uninstall any software you installed for it.
Restart the computer.
Go to Netgear's website and make sure that you download the driver that matches your adapter model number and the version of Windows you are running.
Be aware that many computers today run a 64-bit version of Windows and that you need to download the 64-bit drivers if you have this version. (This will help you figure it out: http://forums.techarena.in/tips-tweaks/962178.htm)
Install the software and DO NOT connect the adapter until the install prompts you to connect it or after you finish the install.
Please vote for my solution if it helps.
Aug 08, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Installed this driver and everything installed ok except it can't aquire network address
Computer not able to acquire the IP address is not an issue with the wireless adapter all-together. Check the device status for this Wireless N Mini USB wireless adapter under the Network Adapter category. It should say: This device is working properly.
If this is the case, you may check for any driver updates with the manufacturer.
Check for any Firewalls like Norton, McAfee, Zonealarm, Comodo, etc. Turn them off or configure them properly.
Update the operating system using Windows Automatic Updates.
On the wireless transmitter, try changing the wireless security type as "WEP" preferably 64-bit WEP with a hexadecimal password.
Finally, if even that doesn't help, try to assign static IP on the wireless network connection by right clicking on Wireless Network Connections and click Properties. Now ensure a tick next to Internet Protocol version 4. Highlight it and click on Properties on this page. Refer to your wireless router or wireless modem vendor to get this assigned.
For further clarifications, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 08, 2010 | EnGenius EUB9707 Wireless N Mini USB...
How do i install my 2wire 802 11g usb wireless adapter without the installation cd
The Link im giving is for WIn 98,2000,XP etc and Vista.
Both Version of 2wire 802.11g USB Wireless Adapter Drivers are Here:http://www.youtube.com/watch?v=pgGovtiQp3g
Video Explains,Links you and comes with Installation Pdf manual.
Take care
Feb 23, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
Linksys wusb600n on windows 7
WUSB600N version 2 will work with Win 7 using the Win Vista drivers.
You may refer to this link for compatible devices that work with Win 7.
You may also use the Win 7 driver - Ver.3.1.0.1.0 (32-bit, 64-bit).
Here is the link for the instructions to manually install the drivers.
Hope this helps!
Dec 10, 2009 | Linksys WUSB600N Pre-802.11n Wireless...
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Cannot connect to wirless with adapter on new computer
Although this model appears to support Windows Vista according to the manual for it (ftp://downloads.netgear.com/files/WG111T_UM_04Feb07.pdf) the 64 bit version is not mentioned and, therefore, probably not supported. I'd take the wireless adapter back and find one that supports Vista 64 for certain. Some do.
Mar 27, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
I have installed software updates on my pc aand then i lost my wireless and other connectionns and it doesnt even show the icons
Hi!
Try to re install your driver for wireless adapter. It may have been removed to other locations. try to access it in the run command. type the name of the program and look for it by clicking run.
Thanks.
Nov 27, 2008 | Computers & Internet
Wireless Network Driver
Dezzie.
This software will work with your Toshiba Laptop. This software was created by Toshiba. You need to install the Network Adapter. So go to Toshiba's website and update your network adapter drivers for win XP SP2.
Please let me know how this works.
Thank you
Cabletech
Nov 22, 2007 | Computers & Internet
TP-LINK (TL-WN822N) Pre-802.11n Wireless Adapter Logo
184 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
