Question about Kitchen Ranges
My fiance and i just got this 5th wheeler. we hooked up the sewage but it seems to not be draining properly. when we bought it we did not recieve the proper manual. please help. For SUNDANCE 5th wheeler
  • 10,865 Answers
Hello ryan. get a plumbing snake and snake each of the drains right out through the end of the system. also physically check the roof sewer vent pipe as it is often a popular spot for wasp, bee and even bird nests. joe
Posted on May 20, 2011
Why do soap suds remain in the bottom of my Kenmore, model #665.13113K701, dishwasher at the end of a cycle? I have run several cycles without soap and there still are suds remaining.
My guess being I have not physically seen it:
A.Improper install and the system is not draining properly.
B.Clogging in the drain pipe at the sink to the sewage system.
C.Failing draining pump.
D.Water softener issues.
E.Someone you have over is pranking you.
Aug 06, 2014 | Kenmore Dishwashers
Tip
4 Tips for a healthy septic tank system
Living in a rural area and not having a connection to the sewage systems like houses in the cities or suburbs can make waste disposal a little difficult. That's where septic tanks come in they are made to take care of your sewage but if not cared for properly can result in a huge mess and stink. Following these 5 simple tips can help to keep your septic tank running properly and trouble free.
1. Keep rain water away
Make sure that you level the land around the tank so that rain water is diverted away from the tank. If you get too much water into the drain field it will become too soggy and won't neutralize liquid waste.
2. Trees mind their distance!
When trees grow too close to the septic tank their roots can cause damage to the system. A good rule of thumb is to not have any trees closer than 100 feet from the tank.
3. Toilet etiquette
This rule seems to be very obvious, you shouldn't be sending anything that shouldn't be going down the toilet must not go down the toilet. Things like wipes, or sanitary napkins and tampons will clog the septic tank and then you will have a big problem before you know it.
4. Stay away
For the system to function properly you have to make sure that it stays clear and undisturbed. This means don't drive over the drain field or build anything on top of it. Even pouring concrete or asphalt is a no, no.
If there is a problem with your system make sure to call an expert to come and look at it, under no circumstance should you open the tank yourself, there are harmful gases and bacteria in that require you to wear special gear.
on Dec 26, 2013 | Plumbing
Cant figure out how to roll the awning out on my 2009 rockwood 5th wheeler
www.rockwood-campers.com/rv/rockwood-5th-wheel.cfm
See if you can't get a manual for it. Camping world has some basic RV DVD that also show how to do it.
Jun 15, 2014 | Cars & Trucks
Water smells like sewage
The drain is connected to the sewage system, so the smell could come from there, install a trap valve
Mar 29, 2013 | H2O Audio H20 Vac Turbo Water Filtration...
I cant seem to hook my pioneer gr 470 equalizer to my pioneer receiver ( vsx-403) what is the proper connection sequence?
tape out from reciever to line in on the eq --then line out from the eq to tape in on the reciever --whenever the tape monitor will be used on the reciever the sound will then be equalized
Sep 02, 2010 | Pioneer GR-470 Home Equalizer
Clothes smell like body odor after washing. using tide ultra he2 detergent.
i had what sounds like a similar problem. i complained of our laundry smelling sour then finally like sour sewage and a flooded laundry room. i was told that when its not draining properly, it can create a siphon-effect and actually pull the dirty water back out of the drain lines-yuk! i hope this isnt true.
there was a baby sock stuck in the pump preventing it from draining properly. hope your problem can be remedied as easily.
as for the smelly clothes, i always add 1/2 cup white vinegar to each load. it does wonders for odors.
Aug 13, 2010 | Washing Machines
I have a bosch washer machine which has got a bras wire stuck in the drum i think.When i run the washer now water is coming out from under the machine.
possibility of such a bra wire stuck in the drain valve or drain hose, you can check, ranging from filter sewage water to the drain valve (with drain motor). you should open the drain valve / motor assembly. wire bra might clog there. so that the rubber water valve does not close properly
Aug 05, 2010 | Bosch Washing Machines
In 4th and 5th gear at full rev seems like
If it is hard to start after it stalls, it is probably getting too much fuel. Could be dirt in the float valve. Also try running a hotter spark plug
Jun 17, 2009 | 2005 Honda CRF 450 X
Keyboard issues
Yes there should be a button on the keyboard. Make sure the keyboard is on (if there is a button/switch) and look for a button on the keyboard. If there wasn't then it would have to 100% of the time be looking for the receiver.
Jun 02, 2017 | Kensington Comfort Type Wireless Optical...
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
