Question about LG GH22NS50 22X DVDRW SATA Drive OEM DVD-RAM Burner
The computer das not recognize it - LG GH22NS50 22X DVDRW SATA Drive OEM DVD-RAM Burner
  • LG Master
  • 27,725 Answers
You might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 20, 2011
Das komplette Oberteil wackelt beim Ruehren hin und her. Was kann ich machen. Der Bolzen der das Oberteil haelt war schon mal komplett raus gefallen
Sie mussen sicherstellen, dass der Gelenkbolzen ist dicht , schalten Maschine komplett auf den Kopf und ziehen Sie die Schlitzschraube im Inneren des Sockels . Wenn das nicht hilft , mussen Sie uberprufen, dass der Verriegelungshebel richtig in den Schlitz eingreift . Sie mussen moglicherweise " LEICHT " -Datei in den Schlitz im Sockel , die den Hebel in Eingriff steht. Wenn Sie mit der Datei verruckt konnten Sie den Steckplatz zerstoren.
Sep 13, 2014 | KitchenAid 5ksm150pseer Artisan Red For...
Lichtmaschine Alternator Harley street bob 2006
Hallo Anonymous , das ist eine Aussage nicht eine Frage , ich brauche weitere Informationen wenden Sie sich bitte sagen Sie mir, das Baujahr und Modell Ihres Fahrrades und genau das, was Ihre Frage ist und k?nnen Sie bestimmte sein und Details, wie , wo, wann , der ein, wie viel so kann ich richtig das Problem anzugehen. Vielen Dank und sch?nen Tag.
Aug 10, 2012 | Harley Davidson FXDBI Street Bob...
I got INSIGNIA TV model#IS-TVCA102212,remote das not work!
I like to connect my shaw satelite to my Insignia TV Model IS-TVCA102212.
What kind of settings I have to make with my TV remote?
I lost my manual
Jan 19, 2010 | Insignia Televison & Video
Screen is locked, nothing works to unlock it
If you see a lock on the screen. on the right side of the phone follow the lock and press the button on the outside right.
Sep 07, 2009 | LG Vu CU920 Cellular Phone
Das bild läuft nach unten (bild runs down)
ich meine das sie das cabel hinten am fernseher besser befaestigen sollten. Bitte ein commentar geben wen das nicht funktioniert.
hoffendlich klabt es fuer sie!
Jun 11, 2009 | Orion1934 19" TV
How to refill toner cartridges HP Q6000 black? (printer HP 2600n)
no holes are need it
check this video it is very easy with no special equipment
http://www.youtube.com/watch?v=iMiTopIVMxM
Dec 26, 2008 | HP LaserJet 1020 Printer
Bonilla
Se a tensão das saídas estiverem abaixo de +5 volts então muito provavelmente é um resistor queimado! Tente descobbrir algum resistor queimado que conduz a tensão positiva de +5v sb da fonte(fio violeta) às saídas ps2 e usb, ou ligar um resistor de 10 ohms da saída da fonte(+5v sb) ao +5v(fio vermelho) das saídas usb frontais na placa ou em qualquer outro lugar disponível.A tensão baixa não permite que o teclado seja reconhecido no início.
Boa sorte
Moisés.
Eu queimei o resistor da minha placa quando conectei um maldito mouse novinho da clone!
Aug 29, 2008 | MSI : P4MAM2-V (7095-010)...
APRENDER A MANEJAR PHOTOSHOP SOLO PARA GUARDAR FOTOS
Bajar fotos? Te refieres a abrirlas en Photoshop y luego guardarlas formato photoshop?
Si esto buscas, solo tienes que abrir el programa y seleccionar open, luego buscas la foto y le das a open.
O
Buscas la foto y le das un 'right-click' y le das a abrir con -- seleccionas photoshop.
Una vez tengas la foto en la aplicacon, para guardarla vas a l mismo menu y le das a guardar. Se te guardara formato photoshop.
Si quieres guardarla con otro formato entonces le das a save as y seleccionas el formato que quieras.
Apr 29, 2008 | Adobe Photoshop 7.0 for PC
Sound problem
Hello There Jaytee75
You need to has a 5.1 sound card at least to get the sound right on this particular speakers. and like sound blaster cards, Audigy, or X-fi, to has better connection and sound for speakers.
good Luck
Nov 28, 2007 | JBL CREATURE II Computer Speakers
LG GH22NS50 22X DVDRW SATA Drive OEM DVD-RAM Burner Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
