Question about ASUS A7S8X-MX Motherboard
Cannot change resolution
Hi, I have just installed ubuntu and I am unable to change the resolution higher than 960x800, I donot know which driver to download. I ddi download a driver file with *.o extension but cannot run it.
  • Faizal  Ali
    Faizal Ali Aug 14, 2008
    Motherboard has an onboard Graphic Card
    Motherboard: ASUS A7S8X-MX
    Operating system: UBUNTU
    Dual boot with: Windows XP Pro
    The graphics are perfect with WinXP.
  • Faizal  Ali
    Faizal Ali Aug 19, 2008
    no problem, I have fiddled around with and manage to sort through commands.
  • 1,800 Answers
If u wnat me to help u "replies" i need u to do this for me in first okay:
1/what is ur display cadr model or name or brand
2/which OS u got
3/hrry up!!^^
Posted on Aug 14, 2008
Testimonial: "I resolved this myself."
I see the icons and text in large size when I try to personalize the screen resolution do not apear the option to difine the size that i want
I have a feeling that you have not installed the drivers for the card, hence you cannot use the higher resolutions. Install the driver from the CD provided and then you will have access to all resolutions.Download the driver from if you donot have the cd.
http://www.nvidia.in/object/winxp_2k_71.89.html
These are legacy drivers for the RIVA TNT 2.
Jan 17, 2011 | Compaq NVIDIA TNT2 M64 (32 MB) AGP Graphic...
I am using ubuntu 10.04 linux operating system ,but it,s screen resolution is not good .is there any possibility to download and install any vga drivers to get better resolution
Go to System, on the top bar, then Preferences and select Monitors.
On the Monitor Preference screen there will be different resolution settings that you can choose.
If there are any resolution settings higher than 800X600 like 1024X768 etc. select it and apply.
If there is no other settings available go to System then Administration and select Additional driver.
When the Additional drivers screen appears check if it recommends a a driver to be downloaded.
If it does, download the driver and then you will be able to get higher screen resolutions.
If there is no additional driver to download it gets a bit tricky.
You will need to edit your /etc/X11/xorg.conf file.
The file will look someting like this:
Section "Monitor"
Identifier "Philips 190S"
ModeLine "1280x1024" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Option "PreferredMode" "1280x1024"
Option "DPMS"
HorizSync 30-82
VertRefresh 56-76
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Philips 190S"
Device "Default Device"
DefaultDepth 24
SubSection "Display"
Depth 8
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Module"
Load "glx"
EndSection
Section "Device"
Identifier "Default Device"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
It will be wise to make a backup of this file if you are going to edit it. (xorg.conf.old)
Inside the file you will see your screen and its resolution. (Preferred mode)
You need to change the resolution, save the file and restart your session.
If all went well your resolution will be set to what you specified, if your display freaks out replace the xorg.conf file with the xorg.conf.old file.
Hope one of these options solves your problem!
Regards
Nov 28, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
Unable to install driver and error it says is monitor resolution atleast it should be 800*600
This sounds familiar. What you need to do is download the motherboard INF setup or the motherboard drivers as they are sometimes called. Run that and windows will then be able to identify the hardware. At that point you can run the video driver and it should now install. When it is running you can change the screen resolution to higher as well as the colours to higher.
As a word of caution sometimes the drivers that you download from the manufactuers website won't work for the first install but the ones on the cd will.
Aug 11, 2010 | Gigabyte GA-8LD533 Motherboard
My screen resolution is changed when i installed ubuntu 9.10. It is not detecting my monitor.
your systems graphic may be Nvdia graphic,try to start in recovery mode or command line and install nvdia drivers manually in command line.
Jan 12, 2010 | Canonical Ltd. Ubuntu
When i go to the hardware drivers there is nothing there and it says at the top no driver in use
I have the Ubuntu installed on the machine , It does show NVIDIA driver installed in the list. I had to install the NVIDIA driver because of the UBUNTU installation didn't show the higher resolutions on my computer. I needed to download the NVIDIA driver installtion file from the internet and that made my computer work for better resolutions as my computer hardware supports.
Sep 17, 2009 | Canonical Ltd. Ubuntu
Unable to chnage resolution higher than 640x480 ( GF PX9600 gt)
I would definitely double check the make and model of the video card and make sure you have the correct driver.
Joe
Mar 23, 2009 | Nvidia GeForce 9600 GT,, PCI Express...
Ubuntu Screen Problem
try resolution change or refresh rate look in system files i know linux is hard the first time unbuntu forums .com helped me a lot a lot of questions answered there just trying to help with some sites i used without typing answers and don't want to confuse you
Sep 04, 2008 | Canonical Ltd. Ubuntu
Unable to set resolution to 1440 x 900
eric, YOur LCD support upto 1440X900. this could be true if you use higher resolution VGA adapter in you PC.
This matter in the Video Adapter.
may this help,
melnavz
PS:
pls donot rate me if this solution donot satisfy you. However; if this help, pls rate me reasonable rating. thank you.
thanks for using fixya.
Jun 11, 2008 | Balance CP4401 PC Desktop
Sis mirage 3 does not work on Ubuntu
what's the amount of vram on your graphics card
Apr 29, 2008 | NEC PGA370 SIS620 ATX Motherboard...
ASUS A7S8X-MX Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
