SOURCE: Surging tecumseh engine on snow blower
Hi, You have gum or old gas in the main jet on the carb, turn your fuel off, stand the snowblower on the front blower housing with handles in the air, remove main jet from the bottom of the carb and clean. Jim
SOURCE: Hello. My John Deere mower has started surging at
I have a john deere 420 rider. It would surge at a higher speed. It is a hydrostatic and there were 2 bolts on the transmission that were loose. now it runs beautifully smooth,
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
SOURCE: john deere stx 46 wont move just howls
Hello carpenter552:
Check for the Belt being Off 1 of the Pulleys.
>>From your Description it Sounds like the Belt is Caught and Screaming and Not the Transaxle.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers STX46 and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.* Select the Power Train File.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: John Deere L120 appears to run out of gas
This is the most common problem with the L120 I'm told. The pin hole in the gas cap needs cleaning (top and underneath as well). I have replaced mine twice already and have only 140 hrs. on it. Starts right up after cleaning. (My symptoms were identical to yours)
