Question about Magic Chef Microwave Ovens
Microwave oven turns on by itself and powers off
  • designer4god Aug 18, 2008
    It happened three consecutive times in a row while I was standing in front of it. I was using the stove at the time. The microwave is above the stove. I don't know the model number because it is in the wall of the apartment I rent. I know it is brand new because it was put in when I moved here in March 08. I don't know the function that it used when it turned on but it seemed to be the same one. Just the time is displayed and the seconds start counting down. There is no error code at all that is displayed. It was a one time event because now I unplug it when I leave the apartment since I don't want it to run by itself while I am not there to cancel it or shut it off. (I don't want a fire!)
  • William Miller
    William Miller May 11, 2010
    This is most likely a bad keypad or it needs a reset.
    When does it happen? How often?
    When it happens, is it always the same function that comes on?
    Is there any fault or error code in the display when it happens?
    What is the model number?
  • Magic Chef Master
  • 9,098 Answers
It sounds like the keypad is shorting.
Glad you unplug it, since it can be very dangerous.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
Or refer your landlord to this info.
Posted on Aug 18, 2008
Will not turn on . Appears as though there's no power.
I'd try to unplug for a while. Could be a bad power cord for the microwave itself. I recently had a toaster problem. Bad wire right at the departure from the plug.
May 12, 2015 | Sharp R-930AK Convection/Microwave Oven
Microwave turntable wont turn
Hi - Possibilities of the turntable not spinning are either it is turned off, damaged or the support itself is damaged as well. Confirm that the power supply is not faulty or defective. Contact a professional to move forward accurately.
Oct 30, 2012 | Frigidaire FMV157GM Microwave Oven
After I entred the desired minutes, when I press START it does not work. And if I press the ADD MINUTES, it is not working. Please can you tell me any solution. Can this problem be due to not cleaning the...
HELLO.
The steps to the solution are as follows.
Off the microwave oven and it.
Then plug the microwave oven and power on the microwave.
Allow the microwave oven to load itself.
Then reset the timing program.
Test the microwave for normal operation.
NOTE:if the problem persist,cleaning the microwave is the next solution.Below is the solution to cleaning the microwave oven.
  • Remove oven racks and soak them in soapy water.
  • Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • Let the oven do its work; it will heat for several hours, charring off baked-on foods.
Thanks.
Sep 20, 2011 | Kenmore 63652 Microwave Oven
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
Son turned on the microwave with nothing in it, and looks like it shut itself down, no power on display now, and not sure what happened.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 26, 2010 | Maytag Appliances Over-the-Range Microwave...
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turned on by itself
Have you tried unplugging it than reapplying power ? Sometimes a power up reset will clear the logic on the control card and yes.. if it continues to run ...you have a potential fire hazard...
Sep 22, 2008 | Magic Chef MCD990W Microwave Oven
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Jan 22, 2008 | Thermador MBYB Microwave Oven
Newish oven powers itself off intermittently
I would look into the thermal shoutdown thermistor inside the micro. It's also posible it may be a bad switch, when power starts, the switch start reacting, not common but I see this posible.
I hope this helps.
Bob
Jan 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
