Question about Toys
How to use the Total Tool Ultimate Cutter
How does the tool work?
    Scholar:
  • 132 Answers
Exactly cut straight or curvy lines with ease using the Ultimate Cutter. Safer to use than scissors, its cutting blade is enclosed by a plastic shield to keep it safely away from skin and fingers while in use. The shield also ensures perfect leveling by keeping the blade at the proper cutting angle at all times!
The Ultimate Cutter's swiveling head makes even rounded, intricate cuts easy anywhere on the page. A squishy comfort grip makes slippage obsolete.
Comment though > " I really thought this was going to be a cool item sadly it was not. The blade is not sharp and not that you would want it to be with children however ..."
Posted on Aug 16, 2008
Multiple tools in the tool bar aren't working
select ctrl+alt+delete togheter and startthe program, a windows is open then click yes and continue
Mar 14, 2014 | Adobe Photoshop 7.0 (321115627)
Tip
How to select slitter cutter material
Incase of slitting Cutter, the cutting quality is the main criterion for selection of the its raw material. Raw material for tool should be hardened than the metal to be cut so that there is no deformation of the cutting tool. The Steel used for manufacturing of the slitter cutter used in slitting line should be such that it can be hardened in depth and should have sustained dimension for a longer period of its usage.
on Feb 03, 2012 | Saws
My tube cutter won't cut
Mate sounds like the gear box is gone
If it's still under warranty take it back
If it's not get a normal brand non battery type you never go wrong
Jan 13, 2014 | Milwaukee tools Milwaukee 2471-20 12 Volt...
Superior tool 37100 blade replacement
From Superior Tool Website, look up the tool, then click on "How to Use".
Blade Replacement:
1. Remove large pivot bolt and nut
2. Slide blade down through handle
3. Remove one (1) end of coil spring
4. Remove "E" clip from 1/4" pivot pin,
remove pin and blade
5. Install in reverse order
6. Torque nut until tool ratchets correctly
Mar 13, 2013 | SUPERIOR TOOL CO superior tool 37100...
Want to reinstall total recipe search toolbar. I can`t find it
I did have total recipe as my tool bar and now, I don't have it, but when I go to install it , it says that I already have total recipe tool bar. I want to get it back up top and I don't see where to reset it.
Oct 27, 2012 | Computers & Internet
Is their any mp3 cutter for n2730c
Yes.
MP3 Cutter is an easy-to-use tool to split MP3 files.
You can download it on this website given below.
http://www.brothersoft.com/downloads/mp3-cutter.html
Jun 21, 2011 | Nokia Lands Phones
My pnumatic h.k porter 9190 cutter piston not returning to
Usual cause of stuck pistons in air operated tools is lack of lubrication. Most you have to either put drops into the air inlet before each day's use or use a mist oiler.
Lube your tool at least twice the amount recommended and try to get it to cycle. After it starts to work, make sure you lube it daily.
It is possible that the O-rings were damaged by insufficient lube oil.
Oct 01, 2009 | Tools & Hardware - Others
Cutting holes
My Dremel 300 came without any instructions, so I had to puzzle out how to use the circle cutter. None of the images I managed to find on the Web or elsewhere were any help. I directed my attention to the "spike" on the circle cutter, and eventually I realized that it was on the wrong (top) side of the cutter--perhaps for safety's sake. When I removed it and positioned it on the bottom side of the cutter, things became clearer. The next thing was to locate the correct cutting edge. I had never used Dremel before, so I didn't recognize the cutting "bit", since it looked like a drill bit. The final problem was how to attach the circle cutter to the Dremel tool. I couldn't see any way of fixing the cutter to the tool. I thought perhaps there was something missing--a connector, perhaps. Eventually I found a reference on the Web to "removing the cap" on the tool. I hadn't noticed a "cap", but when I gave it a turn, it began to unscrew, so I knew I was in business. Finally II tried the attachment out on a piece of scrap timber, I found that it worked. A simple instruction manual would have saved me a lot of time. Also, I now discover that the Dremel 400 would be much more useful than the 300. Dremel don't seem to be very customer friendly. I can access the US site, but the UK and Germany website won't let me in!
Sep 01, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Toys Logo
419 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
